Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Projekt 083-338  (gelezen 3902872 keer)
jerrytrein
Re: Projekt 083-338
« Reactie #18810 Gepost op: 13 November 2019, 19:25:18 »
OK
Zaten de gaten dan al in de aspotten
Re: Projekt 083-338
« Reactie #18811 Gepost op: 13 November 2019, 19:52:45 »
Nou... niet echt:
Ik heb deze halfdiepe "potjes" opgeboord met met een soort kegelvormig freesje:
...zodanig dat de as wel voldoende ruimte heeft, maar er niet in rond kan zwabberen.
Zodra ik de messing lagertjes in huis heb, ga ik de aspot nogmaals te lijf, maar dan met een kogelvormig freesje, zodat er dan een gaatje van 2mm diep en 2 mm wijd ontstaat. Daar moet het messing lagertje dan in passen (even fixeren met een drupje CA of 2K-lijm).
jerrytrein
Re: Projekt 083-338
« Reactie #18812 Gepost op: 13 November 2019, 20:09:42 »
Heb ook een vraag aan GM&S gestuurd
Lijkt me dat je dan meteen van slijtage verlagingen afbent
Re: Projekt 083-338
« Reactie #18813 Gepost op: 13 November 2019, 21:33:26 »
Ja, die lagertjes wil ik er nog wel in hebben.
Aan de andere kant, er zijn tig wagens waarvan de assen gewoon in de plastic aspotten gelagerd zijn.
jerrytrein
Re: Projekt 083-338
« Reactie #18814 Gepost op: 13 November 2019, 22:08:38 »
De meesten
Maar ik heb ook redelijk wat ouder rijden,en ook wel andere merken die toch sneller slijten lijkt
Ook een aantal M die gewoon te laag staan door slijtage en door (iets) te korte assen
Denk dat je dat ook kan opvangen
Noordernet
Re: Projekt 083-338
« Reactie #18815 Gepost op: 13 November 2019, 22:38:37 »
Over die slijtage nog een late jeugdherinnering. Modelbouw- en Speelgoedcentrum Berger, aan het A-Kerkhof in Groningen, liet circa 1974 het eerste Roco-materieel rijden in de kerstetalage. Natuurlijk was dat een fantastische promotie voor het merk. Een DB-diesel serie 215 heeft weken achter elkaar rondjes gereden in de etalage, met een lange trein van goedkope wagentjes. Die hadden een plastic onderstel, waar de assen zo maar in draaiden. Dat kon volgens mij nooit goed gaan: Fleischmann en Märklin hadden in die jaren nog een metalen onderstel waar de assen in draaiden.
Nu, bijna 50 jaar later, weten we dat bij normaal hobbygebruik vrijwel nooit een aspot uitslijt.
Wolter
Falkenberg
Re: Projekt 083-338
« Reactie #18816 Gepost op: 14 November 2019, 11:04:57 »
Slijtage wordt bepaald door het gebruikte materiaal. Er zijn voldoende modellen geweest die niet van zelfsmerend plastic zijn gemaakt en dus wel bleken uit te slijten door het rijden. Franse groentewagens van LS Models zijn daarvan een voorbeeld, maar er zijn er meer. Gelukkig leert men en wordt er nu vaak lagers gebruikt als het plastic niet geschikt is als lager.
Re: Projekt 083-338
« Reactie #18817 Gepost op: 14 November 2019, 12:44:06 »
Precies. Ik heb legio wagens in het bestand waar de assen gewoon in het plastic van de onderbouw gelagerd zijn, maar ik heb geen idee of het plastic van deze onderbouw dezelfde samenstelling heeft als die andere. Kan best zijn van wel, kan best zijn van niet. Daarom gooi ik er voor de zekerheid maar van die messing lagertjes tegenaan. Beter voorkomen dan (niet te) genezen.
Re: Projekt 083-338
« Reactie #18818 Gepost op: 14 November 2019, 14:20:56 »
Nummertje drie op het lijstje met te versmallen onderstellen is een Gms54 van Roco. Hoewel Carstens schrijft dat het model nog van Röwa stamt en het onderstel veel te breed is, lijkt me dat laatste juist wel mee te vallen; het is beduidend smaller dan dat van de Gmms44 en de Gmmhs56, maar iets breder dan dat van de Gmhs53.
Zoals je ziet zijn hier de assen ook niet in zo'n "binnen-ashouder" gelagerd. Zou je dit chassis willen versmallen, dan zou je dus ook de ruimte voor de assen in de "originele" aspotten moeten verdiepen. De vraag is of daar wel vlees genoeg voor is. Afgezien daarvan zal ook de ruimte tussen ashouder en wiel kleiner worden, met het risico op aanlopen.
Dat alles in overweging nemende komt de mogelijkheid in beeld om de wagen zo te laten en eventueel alleen de verwering overnieuw te doen. Zoals die nu is, is het het resultaat van een actie van zo'n twintig jaar (of meer) geleden.
En dan nog iets geheel anders: in het voorwoord van GW 1.1 schrijft SC een geheel andere indeling te gaan volgen dan in Band 1 het geval was. In het begin kostte het me wat moeite om bepaalde wagens "terug te vinden", maar eenmaal gewend wordt het gaandeweg duidelijker. Waar in Band 1 nog een grofweg gezegd "numerieke" volgorde werd aangehouden, is die in Band 1.1 en Band 1.2 veeleer een chronologische. Toch wel logischer, vind ik.
Nog een opmerking: in GW2 werd het thema "Gedeckte Wagen-Sonderbauarten" behandeld, waarin wagens als veewagens, koelwagens, silowagens en zo meer werden besproken. In de nieuwe delen 1.1 en 1.2 treffen we echter "ineens" wel de veewagens aan, terwijl koelwagens, silowagens etc. etc buiten beeld blijven.
Ben benieuwd waartoe dat gaat leiden.
« Laatst bewerkt op: 14 November 2019, 14:39:32 door 44 »
Ric
Re: Projekt 083-338
« Reactie #18819 Gepost op: 14 November 2019, 15:41:18 »
Zal wel een commerciële reden achter zitten :angel:
Grt. Ric
Re: Projekt 083-338
« Reactie #18820 Gepost op: 14 November 2019, 17:52:14 »
Dat zou kunnen, wie weet.
Overigens, over commercieel gesproken: als je gaat zoeken op Güterwagen Band 1 en Band 2, dan kom je ze wel tegen redelijk "normale" prijzen tegen, maar soms worden er ook astronomische bedragen voor egvraagd. Meer dan € 200,= bijvoorbeeld.
Ric
Re: Projekt 083-338
« Reactie #18821 Gepost op: 14 November 2019, 18:33:21 »
Wat dag je hiervan? https://www.amazon.de/MIBA-G%C3%BCterwagen-Band-Gedeckte-Wagen/dp/3896106538
tweedehands 2 1/2 keer duurder dan nieuw
Grt. Ric
  • Schwarzburg-Neuffen-Bahn
Re: Projekt 083-338
« Reactie #18822 Gepost op: 14 November 2019, 18:48:51 »
Dat zal wel een typefoutje zijn, vermoed ik.
Re: Projekt 083-338
« Reactie #18823 Gepost op: 14 November 2019, 19:17:06 »
Jan, die verwering is supergeslaagd. Niks meer aan doen en op naar het volgende project 😋
jerrytrein
Re: Projekt 083-338
« Reactie #18824 Gepost op: 14 November 2019, 20:13:35 »
In 18819 heb je het over eventueel aanlopen van de wielen
Maar in18807 zitten de wielen bijna tegen de aspotten aan
« Laatst bewerkt op: 14 November 2019, 20:15:37 door jerrytrein »
