Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: NS-6000 in Spoor-1  (gelezen 104711 keer)
    • nulpunt
Re: NS-6000 in Spoor-1
« Reactie #90 Gepost op: 07 March 2023, 15:33:28 »
Het ganghandel.
Geruime tijd zitten overleggen hoe en waar te beginnen en wat er gezien moet gaan worden. Belangrijkste detail is de schijf met inkepingen.
We zijn dus met die schijf begonnen en zijn gaan kijken wat de minimale afmetingen zouden kunnen zijn. De kunst van het aanpassen  ;D
En dan verder als leidraad de tekeningen in  Labrijn en de foto van de 3737.
wordt vervolgd.
7824
« Laatst bewerkt op: 07 March 2023, 15:35:07 door FritsT »
    • nulpunt
« Reactie #91 Gepost op: 08 March 2023, 14:36:31 »
Het "aangepaste" ganghandel is inmiddels besteld als test in plastic.
Bevestigen aan de ketel met de 2 staafjes. Voor het verschil tussen SS en NS haal je de staafjes weg die niet gebruikt worden.
7955
Ivo tB
« Reactie #92 Gepost op: 09 March 2023, 12:34:47 »
Frits,
Prachtig als statisch onderdeel. Ik kan pas zien als ik het ding in huis zou hebben of het ook werkend te maken is. Daardoor heb ik eigenlijk een andere vraag. Zou je dit onderdeel ook in verschillende stukken (stukjes) kunnen printen, waarbij je het schroefdraad gewoon van tapeind of een lange 1mm bout oid maakt in een frame en het ganghendel met schijf met inkepingen aan het tapeind vastmaakt. De hendel boven waarmee je de stand vastzet moet dan wel los, anders draait het niet. Heeft te maken met mijn idee om de binnenliggende schuifbeweging ook functioneel te maken in de zin dat je die met het ganghendel kunt verstellen. Als ik de onderdelen van de schuifbeweging die je hebt getekend en geprint goed interpreteer is dat daar allemaal mogelijk.
Je hebt bijvoorbeeld ook de voorwarmer (veel groter onderdeel dan dit) ook in verschillende stukjes geprint.
P.S., nee, ik ga geen stoomaandrijving in dit model maken  ;D
Ivo
    • nulpunt
« Reactie #93 Gepost op: 09 March 2023, 12:46:27 »
Alles kan (is dat wel zo?), maar realiseer je dat iedere print een basistarief van 15-16 euro heeft. En hoeveel zit er al in het hele model en gaan er nog komen? Dit onderdeel komt pas in een later stadium van de bouw aan de orde en we moeten nog eerst nog heel wat andere onderdelen ontwerpen. Verfijningen komen dan pas. Alles op zijn tijd.
Ik heb  tapeind M2 tijdens het ontwerp ingepast. Zie je niks van. Vandaar dat we een spiraal getekend hebben. (kunst van het aanpassen  ;D)
« Laatst bewerkt op: 09 March 2023, 12:49:17 door FritsT »
    • nulpunt
« Reactie #94 Gepost op: 09 March 2023, 13:00:55 »
Dit hoort gezien de afmetingen in het spoor-0 draadje, maar is eigenlijk een vervolg van wat hier staat. Weer een dilemma.... maar ik neem aan dat beide draadjes door dezelfde bouwers/lezers worden gelezen.
Verschalen vanuit de 1:32 naar 1:43,5.
In FDP plastic lijkt het ongestraft te kunnen.
In messing......zal er om hangen  ???
of de gele vlakken 0,1-0,2 mm dikker maken, maar kloppen de verhoudingen dan nog wel? en wat zegt de handmatige controleur bij Shapeways?
Eerst de testprint in FDP afwachten.
1e aanpassing: de vork aan het uiteinde van massievere en afgeronde delen voorzien.
Ivo tB
« Reactie #95 Gepost op: 09 March 2023, 21:01:40 »
Snap ik, maar als je de losse onderdelen van het ganghendel in een print combineert zoals deze https://www.shapeways.com/product/9LDBCM36X/6000-32-v1-5-voorverwarmer?optionId=291663169&li=shops van de voorwarmer dan is dat toch een print? Of zijn dat van de voorwarmer er 6? (Heb niet geteld, maar kop en staart en ik dacht 4 aansluitingen apart).
Ivo
    • nulpunt
« Reactie #96 Gepost op: 09 March 2023, 21:34:59 »
Die voorverwarmer is ontworpen als losse componenten, klopt. Deze (en vele andere) zijn dat niet, daar lopen de onderlinge componenten in elkaar over om een sluitend 3D model te krijgen want met een open vlak is het niet printbaar. Als je die toch los van elkaar aan een gietboom zou zetten heb je dus NIET de componenten om er een geheel van te maken. Het heeft echt met de techniek van het 3D tekenen te maken en ook met de tijd die je ervoor nodig is om het te tekenen.
Deze ganghandel was in feite zo klaar, die voorverwarmer kostte veel meer tijd omdat het juist alemaal losse delen zijn.
Voorbeeld.
Stel we gaan een bezem tekenen. Dat is in 3D een rechthoekig blok (bezem zelf) en een cylinder (steel/handvat).
De cylinder schuif je in het blok, klaar. De cylinder moet je aan de kant van het handvat dicht maken anders heb je een open object en als je daar niks aan doet is het niet printbaar. Dat is in dit geval maar 1 extra handeling, maar bij de ganghandel in losse componenten heb je vele handelingen nodig en die moeten ook nog eens naadloos aansluiten.
Alles kan, maar dat is een karwei wat je niet wilt weten.
Daarbij, welke marges ga je aanhouden om alles passend / beweegbaar te krijgen en dan heb je nog eens de (variabele) krimp bij de gieter.
Binnenliggend drijfwerk..... uren uren en nog eens uren (en testexemplaren).
Tekenen in 3D kan tot in nanometers, maar vormen in 3D maken is al een stap verder en uitvoering in messing is echt wat anders.
Controle scherm bij Shapeways: Loose shells.....als dat geen groen vinkje krijgt heb je een probleem en kan je gaan zoeken zoeken zoeken (en mopperen).
Ter info; het koste ons circa 3-4 uur om de ganghandel te tekenen.
« Laatst bewerkt op: 09 March 2023, 22:01:18 door FritsT »
    • nulpunt
« Reactie #97 Gepost op: 14 March 2023, 15:35:44 »
De snelheidsmeter (vlg. Hassler) bestaat uit 2 gedeelten. Onder de voetplaat de overbrenging vanaf het achterste wiel en in het machinist de aflezer.
De overbrenger moet nog voorzien worden van een Albion-buisje zodat daar een beweegbare as in kan worden aangebracht. Voor de  montage leek het bij het ontwerp makkelijk om een losse bodem te hebben. Die zit weer bovenop het gietdeel
Dit is de aflezer, (in duplo, voor/achterzijde)
Het gietdeel is uitgehold en de bevestingsplaat naar/tegen het plafond machinistenhuis zit er niet op. Dat is tijdens de bouw te bepalen.
8452
« Laatst bewerkt op: 14 March 2023, 15:47:54 door FritsT »
Ivo tB
« Reactie #98 Gepost op: 15 March 2023, 01:11:36 »
Bijzondere print. Dit is niet te klein en printbaar? Staat me zo voor de geest vanuit mijn 6100 in H0 dat dit ding kleiner is dan het ganghendel of vergelijkbaar. En beweegbaar met een as en Albion buisje klinkt helemaal goed  (y)
Ivo
Ivo tB
« Reactie #100 Gepost op: 15 March 2023, 18:18:33 »
Ja, dat mooie filmpje kende ik al. Maar omdat je het Albion buisje noemt bij de print van de kast van de snelheidsmeter wek je bij mij de indruk dat zelfs de snelheidsmeter wordt aangedreven en je een bewegende wijzer ziet. Leek mij wat erg ver gezocht, maar ik laat me graag overtuigen (y)
Ivo
    • nulpunt
« Reactie #101 Gepost op: 15 March 2023, 19:22:47 »
Alles kan, maar dat krijg ik niet voor elkaar. Als het jou zou kunnen gaan lukken.....zou prachtig zijn. Noem dat dé uirdaging.
Ivo tB
« Reactie #102 Gepost op: 15 March 2023, 23:31:27 »
Was niet van plan hier tijd in te steken eerlijk gezegd. Eerst maar eens een rijdende en puffende 6000 bouwen voordat ik hier energie in steek. Nogmaals ik was op het verkkerde been gezet door het Albion buisje. Ik ga wel door met nadenken of ik de vullingsgraad kan gaan verstellen tijdens het rijden.
Ivo
    • nulpunt
« Reactie #103 Gepost op: 16 March 2023, 10:18:41 »
Ik ben niet in de gelegenheid om komend weekend naar het Spoorwegmuseum te gaan, dus nog even geduld.
8840
« Laatst bewerkt op: 16 March 2023, 10:32:55 door FritsT »
    • nulpunt
« Reactie #104 Gepost op: 21 March 2023, 12:17:39 »
We zijn er achter gekomen dat er onderop de overbrenging van de snelheidmeter twee "iets" zitten en nog twee verschillende "iets" ook. Wat ze precies voor functie hadden? Ik heb een idee, maar dat is speculatie. Wie?
Vooralsnog zijn ze wel op het 3D ontwerp gezet en is inmiddels in bestelling.
9031
Addendum  23 maart 2023: In een apart draadje wordt de werking van de snelheidsmeter besproken.
https://forum.beneluxspoor.net/index.php?topic=106654.0.html
« Laatst bewerkt op: 23 March 2023, 11:29:08 door FritsT »
