Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Reinier Z.
27 January 2026, 23:58:17
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Heroplage Artitec Plan W? door Quinzeedied
27 January 2026, 23:12:25
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Faller 2026 door Scratchbuilt
27 January 2026, 20:47:14
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
27 January 2026, 18:28:47
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Minibaan Visserskaai H0 door Sven
27 January 2026, 18:11:17
Bouw graafmachine Artitec. door Herb73
27 January 2026, 18:10:14
Auteur Topic: Timer schakeling rondje h0  (gelezen 9508 keer)
Timo
  • Team encyclopedie
Re: Timer schakeling rondje h0
« Reactie #15 Gepost op: 16 September 2019, 21:26:23 »
Met een digitale schakelklok ben je denk ik te beperkt in hoeveel programma's je in kunt stellen. En een resolutie van een minuut is misschien wat grof. Simpelheidsprijs wint het zeker! (y)
@NL-modelspoor, die klinkt ook interessant. Ook al is mijn Chinglish vanavond even niet zo goed dus snap even niet of je hem ook zonder trigger aan en uit kunt laten gaan.
En natuurlijk is simpel relatief. Denk dat ik er ook redelijk snel een Arduino bij zou trekken en verwacht dat Klaas makkelijk naar wat discrete elektronica grijpt. Maarja, feature-creep (afremmen, langzaam optrekken, willekeurige wachttijd, seintje erbij) ligt dan ook op de loer ;D
Timo
« Reactie #16 Gepost op: 16 September 2019, 21:49:10 »
Timo krijgt gelijk.  ;D
Mijn oplossing:
Zal door velen herkend worden als de klassieke multivibratorschakeling. Verschil is dat er grotere waarden voor de weerstanden en condensatoren zijn gekozen dan gebruikelijk. En er zijn een transistor, een relais en een diode toegevoegd.
Met het contact van het relais schakel je een geïsoleerde sectie waar de loc in het station moet stoppen.
Ra en Ca bepalen samen de aan-tijd van het relais, Ru en Cu bepalen de uit-tijd.
Met de waarden van Ca en Cu moet je wat experimenteren om de goede tijden te krijgen. De aan-tijd moet lang genoeg zijn zodat de locomotief de tijd krijgt om de geïsoleerde sectie te verlaten. De uit-tijd is de rijtijd die de trein nodig heeft om zijn rondje te maken plus de wachttijd in het station.
Aan de leds kun je zien of de schakeling in de aan-stand of de uit-stand staat.
EricZmS
  • Buiten de lijntjes is veel meer ruimte
« Reactie #17 Gepost op: 16 September 2019, 21:50:41 »
Dit een idee?
1s-999 minuten programmeerbare timer signaal trigger 5 trigger modi uitgang schakelaar kan 3 V-220 V instrumenten
https://s.click.aliexpress.com/e/qhDbSgzQT
Met vriendelijke groet, Eric
ZmS staat voor mijn koffie, Zwart met Suiker.
3x links is ook rechtsaf
Harm Boer
« Reactie #18 Gepost op: 16 September 2019, 22:09:19 »
Ok, ik ben er inmiddels achter dat het niet eenvoudig is. Voor mij dan, helaas heb ik geen elektronica gehad oid.
Ik weet wat plus en min is en dan houdt het wel op. Ik zet het plan ff in de ijskast en ga maar eens een boek vragen voor kerst: elektronica voor dummies ofz.
Bedankt voorde reacties!
Groet
Harm
Arjen52
  • Oude meuk in h0
« Reactie #19 Gepost op: 16 September 2019, 22:30:12 »
Waarom neem je geen Fleischmann Aufenthaltsschalter of iets vergelijkbaars?
Op de Duitse eBay staan voldoende betaalbare aanbiedingen: https://www.ebay.de/b/Aufenthaltsschalter/bn_7005630630.
Wellicht ook op de Nederlandse versie van eBay.
  • NS tijdperk II(c)/III
    • Obdam in h0
« Reactie #20 Gepost op: 16 September 2019, 23:38:55 »
Of gewoon nieuw...
En hier de handleiding, opent als PDF.
Fotodijkje en fotodiorama
Obdam
ikbenerevenniet
« Reactie #21 Gepost op: 16 September 2019, 23:59:17 »
Dat wordt een teleurstelling! Je weet nl. niet wat de toestand van de multivibrator is op het moment dat de trein het station binnenrijdt. Het relais kan wel nét opgekomen zijn, waardoor de trein dus niet stopt! Bovendien raak je gestoord van het continue getik van dat relais, ook als de trein niet in het station is.
Met een monostabiele multivibrator zou het kunnen, mits die door de binenlopende trein getriggerd wordt .
    • Obdam in h0
« Reactie #22 Gepost op: 17 September 2019, 00:26:59 »
Als de astabiele ook maar assymetrisch genoeg is, zoals Klaas hem ontworpen heeft, gaat dat prima werken hoor.
Stel:
- ta = 5sec
- tu = 60sec
- rijtijd = 30sec
- de trein staat stil in de stopsectie en het relais is niet bekrachtigd.
1- De schakeling 'klapt om' het relais trekt aan, de stopsectie krijgt spanning en de trein rijdt weg.
2- Na 5sec valt het relais weer af en de stopsectie is weer spanningsloos.
3- Na 30 sec komt de trein weer in de stopsectie en stopt.
4- Na nog eens 30sec zijn we weer terug bij 1 en begint het 'spel' opnieuw.
[edit] ta en tu overeenkomstig het verhaal van Klaas benoemd zodat e.e.a. beter op elkaar aansluit.[/edit]
« Laatst bewerkt op: 17 September 2019, 10:23:30 door Eric B »
Obdam
Timo
  • Team encyclopedie
« Reactie #23 Gepost op: 17 September 2019, 10:02:08 »
Met je vraag kan ik je niet helpen (geen verstand van helaas) maar de naam van je topic is leuk gekozen  ;)
Ik dacht eerst ook dat jij dit gestart was ;D
@Erik Baas, lees het tweede deel van Klaas en de uitleg van Eric ;) Dat je het getik van een relais zat kan worden kan ik wel in komen ;D Maar je hebt ook wel redelijk stille relais.
@Klaas Zondervan, mooie simpele schakeling (y)
@Eric B, Misschien moet ik jou toch de simpelheidsprijs geven ;D Valt me nog mee at een Fleischmann 6953 moet kosten. Schakelt hij ook weer een beetje snel af? En werkt dat ook beetje op lage spanningen?
@EricZmS, zoals eerder gezegd lijkt dat me een erg mooie oplossing. Heb jij daar wel eens mee gespeeld? Ik lijk te begrijpen dat een simpel continue aan-uit mogelijk moet zijn maar zeker weten doe ik het niet met de Chinglish beschrijving. Snap nog even niet precies wat de verschillende modi doen.
@Harm Boer, zoals eerder aangegeven is simpel relatief en je kunt het zo gek maken als je wilt. Maar denk dat het niet simpeler wordt dan een Fleischmann 6953. En als je iets meer controle wilt en het niet erg vind om wat te proberen zou ik voor zo'n timer relais gaan zoals @NL-modelspoor of @EricZmS (overvloed aan Eric/k's ;D) plaatste. Voor de prijs van minder dan 3,- kan je het altijd proberen zou ik zeggen.
Timo
    • Obdam in h0
« Reactie #24 Gepost op: 17 September 2019, 10:26:25 »
Eigenlijk géén idee meer van Timo, echt vele jaren geleden dat ik er wat mee gedaan heb...
Zal me niets verbazen als mijn exemplaar uit de jaren '70 nog ergens in een doos zit, maar welke  ???
Obdam
« Reactie #25 Gepost op: 17 September 2019, 12:59:47 »
Ik zie dat ik mijn schakeling niet meer hoef te verdedigen. Dat heeft Eric B al voortreffelijk gedaan.
Het enige probleem dat ik kan verzinnen is dat het bij het eerste rondje fout gaat. Maar bij het tweede rondje komt de zaak vanzelf in de pas. Je moet alleen eerst wat experimenteren om de juiste tijden te krijgen. De aan-tijd moet lang genoeg zijn om de loc uit de stopsectie te krijgen, maar hij moet naar de uit-stand vallen voordat de trein zijn rondje  heeft voltooid. En de uit-stand moet langer duren dan de tijd die de trein nodig heeft voor zijn rondje.
Wat de simpelheid betreft, simpeler kan ik het niet verzinnen. Maar als dat voor Harm te moeilijk is houdt het voor mij even op.
zuylen
« Reactie #26 Gepost op: 17 September 2019, 13:16:20 »
Yep, zoals Klaas die gemaakt heeft gaat het prima werken! Misschien moeten we ook even uitleggen hoe je de transistoren moet plaatsten met hun pootjes? Vaak spreekt dat wel voor zich maar het is handig dat dit misschien toch effe vermeld wordt.
Timo
  • Team encyclopedie
« Reactie #27 Gepost op: 17 September 2019, 13:23:16 »
Timo
EricZmS
« Reactie #28 Gepost op: 17 September 2019, 13:36:04 »
Timo,
Niet mee gespeeld en ook mijn chinglish is niet zo heel best, ik zou hem aansluiten als het tweede schema en de timer laten schakelen met een reed contact.
Qua timing gewoon lekker uitproberen.
Volgens mij heeft de timer de beschikking over  4 programma's die je kunt programmeren.
Het is dat ik op dit moment er geen bestemming voor heb anders zou ik hem voor de gein al bestellen en ermee aan klieren gaan.
zuylen
« Reactie #29 Gepost op: 17 September 2019, 15:06:04 »
Ennn als je het dan nog mooier wil maken kun je een NE555 gebruiken als timer. Maar misschien wordt het dan te ingewikkeld. Je kon vroeger zo'n NE 555 schakelingetje met relais kant en klaar kopen van Velleman.
« Laatst bewerkt op: 17 September 2019, 15:08:10 door zuylen »
