Infrabel compilatie door Remunj
Vandaag om 08:41:12
Digikeijs DR5000 Centrale, vragen en antwoorden door Remunj
Vandaag om 08:37:45
PB Models kondigt een NS Buffel aan! door Mitchell
Vandaag om 07:26:23
Vandaag om 05:19:49
Vandaag om 02:38:52
Vandaag om 00:32:31
Vandaag om 00:07:35
17 February 2026, 23:17:28
17 February 2026, 23:03:24
17 February 2026, 23:02:46
17 February 2026, 22:53:29
17 February 2026, 22:52:33
17 February 2026, 22:25:54
17 February 2026, 21:52:21
17 February 2026, 21:41:11
17 February 2026, 21:41:05
17 February 2026, 21:37:24
17 February 2026, 20:39:30
17 February 2026, 20:27:09
17 February 2026, 20:06:51
17 February 2026, 19:36:48
17 February 2026, 19:34:07
17 February 2026, 19:21:28
17 February 2026, 19:13:40
17 February 2026, 19:13:00
17 February 2026, 18:23:36
17 February 2026, 18:14:32
17 February 2026, 18:01:26
17 February 2026, 17:48:00
17 February 2026, 17:29:24
Auteur Topic: 3D/RM IG: Anycubic Photon en Resin printers voor modelbouw, gebruikservaringen  (gelezen 46552 keer)
Jan-Peter
  • Bnlx treinendokter.
Re: 3D/RM IG: Anycubic Photon en Resin printers voor modelbouw, gebruikservaringen
« Reactie #195 Gepost op: 21 March 2021, 17:08:00 »
\nu denk ik spontaan aan de onderstaande quote
Citaat van: JFK date:12 Sept 1962
We choose to go to the Moon. We choose to go to the Moon...We choose to go to the Moon in this decade and do the other things, not because they are easy, but because they are hard; because that goal will serve to organize and measure the best of our energies and skills, because that challenge is one that we are willing to accept, one we are unwilling to postpone, and one we intend to win, and the others, too
Bron JFK/Wikipedia/Nasa
En nieuwe preisertjes worden al zoo veel gemaakt .... ;D  (y)
Jan-Peter
Ad_M
  • N-Spoor
« Reactie #196 Gepost op: 21 March 2021, 17:46:19 »
Eens  ;D
Even terug on topic, kijk even hoe Joke het op pagina 11 het fietsje in de supports gezet heeft
Het is nog gelukt ook bij een exemplaar  (y)
Plat is niet de beste manier om een fiets te printen
Ad
Als je het niet meer trekt..., dan moet je duwen!
Bart Zegers
« Reactie #197 Gepost op: 21 March 2021, 18:02:14 »
Dit is ook met een resinprinter gemaakt, niet door mij overigens (het 3D model wel).
Bij het bordes dat al aan de wagon hangt heb ik achter elkaar alle supports weggeknipt (eerst de dunne, als laatste de dikste). Ik had het beter groepje voor groepje kunnen doen, dan houdt je nog even wat stevigheid in het model tijdens het wegvijlen van de laatste puntjes. Bij de linker is het al beter gegaan wat dat betreft. De dunste (horizontale) railing is trouwens 0.35mm dun. Het laddertje is met 0.15mm eigenlijk te dun om fatsoenlijk uit de supports te halen, maar het kan wel worden geprint  ;D.
Met vriendelijke groet, Bart
Een Roco NS
JohnT
« Reactie #198 Gepost op: 21 March 2021, 19:02:37 »
Beste 3D-printers,
ik begrijp heel goed dat jullie trots zijn op het bezit van zo'n printer. Maar waarom per se dingen willen printen die niet haalbaar zijn. Er zijn genoeg andere hele mooie dingen die dat wel zijn. Zie bijvoorbeeld de bruggen in schaal N. Een spaak van een wiel is 2 mm dik? In h0 is dat 0,023 mm. Zelf ge-etst is dat niet haalbaar. Het breek al als je er naar kijkt. Besteed je moeite om het 3D-printen onder de knie te krijgen aan wat minder filigraane objecten. De kans dat dat lukt en daarmee tot een positief gevoel leidt is vele malen groter dan een bij voorbaat onhaalbare kaart als een fiets met spaken in h0.
Veel plezier met het leerproces.
Ted
Het haalbare heb ik gedaan, wil nu graag zien wat mogelijk is. Dat het mogelijk is weet ik heb het gezien op Youtube dus voor mij een uitdaging.
JohnT
JohnT
« Reactie #199 Gepost op: 21 March 2021, 19:06:56 »
Eens  ;D
Ad
Ik weet het maar je probeert wat, denk alle standjes wel gehad te hebben  ;D
JohnT
JohnT
« Reactie #200 Gepost op: 21 March 2021, 19:30:48 »
Eens  ;D
Ad
Ik heb gekeken op pagina 11, een groot verschil in instelling ontdekt, bedankt voor de tip.
JohnT
« Reactie #201 Gepost op: 21 March 2021, 19:50:06 »
De opmerkingen gedaan onder Onshape cursus door mij zijn dus niet anders.
Als het uiteindelijke onderdeel niet te ontdoen is/vrij te maken is van de supports, wat heb je er dan aan.
Dus toch iets "verdikken" dus...
MO
    • nulpunt
« Reactie #202 Gepost op: 21 March 2021, 20:23:18 »
Wat je er aan hebt? Toch misschien wel.
In onze bouwgroep werken we met messing in schaal 0. We printen in afgietbare was. De print gaat bij het afgieten verloren, maar er komt een messing afgietsel voor in de plaats.
Komende week laat ik een H0 onderdeel waarvan ik de supports niet af durf te snijden gewoon met alles er op en er aan afgieten en ik verwacht dat je het messing afgietsel prima van de "supports" (of hoe je ze dan mag noemen) af kunt slijpen. Maar eerst zien, dan geloven.
De klepkast voor de LTM-51 tramloc in H0.
IMG_0160 by Nulpunt0, on Flickr
  • Eton Wick, UK
    • Ga naar de Tramfabriek
« Reactie #203 Gepost op: 21 March 2021, 20:35:35 »
Anti-Aliasing gebruik ik niet. Als ik het goed heb, rond deze instelling de scherpe kantjes af. Wij zijn zo gedetailleerd aan het printen dat bij gebruik van deze instelling onze detaillering waarschijnlijk te niet wordt gedaan.
Daarnaast gebruik Chitubox als Slicing programma en deze ondersteund deze instelling niet.
Dan moet jij je Chitubox eens updaten, want dat ondersteunt al meer dan een jaar anti-aliasing (in het tabblad dat al door Ad_M wordt aangehaald). Ik heb die voor mijn Photon standaard op 2x staan. Alleen als je 8x doet, worden de scherpe details wat afgerond, maar op 2x gaat het prima. Ik zie het verschil niet echt, maar de prints zijn prima. Je hebt wel nog steeds wat nabewerking nodig, maar als ik dat niet doe en er met een primer overheen ga, komt het mooi van de gieter terug.
Is het nadeel van een was model printen niet dat je voor elke afgietsel die je wilt hebben een wasmodel nodig hebt? Ik lever een 3D print aan en kan dan onbeperkte aantallen bij laten maken. Zeker als je het origineel nog na moet bewerken, scheelt dat een hoop werk.
    • nulpunt
« Reactie #204 Gepost op: 21 March 2021, 21:06:05 »
@Sven.
Voor de productie van grotere aantallen kan je dat doen (en doen we ook) maar dan heb je daarbij een rubber mal nodig. Die zijn niet gratis. Heb je  1 enkel exemplaar nodig...printen in afgietbare was. Heb je twee exemplaren nodig, dan maken we twee printjes.
We zijn die weg ingeslagen omdat op onze modellen veel onderdelen zitten en de "omzet" in aantallen modellen heel erg laag is. En daar we zowieso willen bouwen , is dit de weg die we gevonden hebben. Waar het omslagpunt zit... nog geen idee.
Zo dus ook dat ene H0 onderdeel. Tekening was er toch. Als dat goed lukt, wordt er iemand heel erg blij (en dat ben ik niet)
« Laatst bewerkt op: 21 March 2021, 21:08:17 door FritsT »
    • sleutelspoor
« Reactie #205 Gepost op: 21 March 2021, 22:05:38 »
Ik krijg de spaken alleen geprint als ik de fiets horizontaal print. Bij verticale print worden de spaken in 0.03 mm lengte geprint en en ze zijn heel dun en daardoor heel fragiel. D e  vloeistof is tijdens het printen in beweging vanwege het in en uit trekken van de print. De spaken zijn zo dun dat deze door de beweging kunnen afbreken. Door de print horizontaal te plaatsen hard de spaak in een keer uit. Hierdoor zit hij aan twee kanten vast en zal daardoor veel stabieler zijn tijdens de beweging van de vloeistof.
@ Ted. De fiets is met spaken te downloaden van het internet en niet zonder spaken. Die moet je dan zelf tekenen. Is op zichzelf niet zo'n probleem, maar het leert je wel wat je mogelijkheden zijn wat het printen betreft. De fiets van John ging niet alleen fout met de spaken en ik denk als we wat meer zien van zijn supports en instellingen dat we hem wel weer wat tips kunnen geven waardoor hij betere printresultaten kan halen.
Rondingen in verticale richtingen zijn veel moeilijker te printen want dat gebeurd in de dikte van de uithardingsdikte per stap. Bij horizontale belichting wordt de ronding in een keer geprint en daardoor is de kans op verspringende lijnen veel kleiner.
« Reactie #206 Gepost op: 21 March 2021, 22:07:25 »
Kijk dat zijn hele goede tips.
Klinkt eigenlijk ook logisch.
Met hartelijke groet.
Dave
Rheinburg tijdperk V/VI
JohnT
« Reactie #207 Gepost op: 22 March 2021, 09:19:00 »
Dit was ook mijn gedachte om de fiets plat te leggen, meer aanhechtingen voor support. Vandaag een poging met nieuwe instellingen. Plaatje van support volgt als deze print mislukt .
JohnT
JohnT
« Reactie #208 Gepost op: 22 March 2021, 11:08:55 »
Weer mislukt.
Support automatisch gegenereerd en hier en daar aangepast. Bijvoorbeeld support op een spaak gewijzigd.
De fiets op de fep folie.
Support op de printplaat.
Moet ik misschien medium support gebruiken? Ik heb nu light.
Instellingen gebruik van pagina 11.
JohnT
« Reactie #209 Gepost op: 22 March 2021, 15:46:07 »
Maar hier heb je de fiets toch niet plat liggen?
Dave
