Minibaan Visserskaai H0 door Sven
Vandaag om 00:14:58
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Harzwald Hafen Bahn (spoor 0)  (gelezen 269834 keer)
jerrytrein
Re: Harzwald Hafen Bahn (spoor 0)
« Reactie #1515 Gepost op: 09 March 2025, 16:27:59 »
Als je de tand kast bekijkt zijn dat hele fijne tanden op
Als je er 2 besteld kan je die tandwielen op de as gebruiken
« Reactie #1517 Gepost op: 10 March 2025, 16:16:19 »
Dat draadeind is zo te zien langer en dikker dan de as die jij nodig hebt ...
Wat te lang is: kan je afzagen ...
Wat te dik is: kan je afdraaien ...
Of denk ik nu te makkelijk?
Wat moet er in jouw plan op het uiteinde van dat asje komen?
Laat ons eens met je meedenken
Voor elk probleem bestaat een oplossing, is er echt geen oplossing, dan is het geen probleem, maar een feit.
Te lang is geen probleem,dat kan je i.d.d. afzagen/slijpen.
Afdraaien,daar heb ik hier de middelen niet voor,dus die optie is geen optie.
Op het uiteinde van de as (mits lang genoeg)moet een wormwiel komen,dat een tandwiel aandrijft op 1 van de assen van dat pruttelding.
Om daarmee aandrijving te verkrijgen.
@ Jerry,
Die bestelling doen,dat vind ik prima,maar dan moet ik wel zeker weten dat de motor met "draadeind" bruikbaar is,om de door jouw genoemde items bij te gebruiken.
En ik vrees dat dat een "probleem" op levert  ???
Zoals ik al zei,iets inkorten( de as) is geen probleem,maar verder dan dat kom ik niet.
Het is nou niet dat ik hier een winkel bezit met heeeel veeel diverse gereedschappen/hulpjes  ::)
  • NS tijdperk II(c)/III
    • Obdam in h0
« Reactie #1518 Gepost op: 10 March 2025, 16:25:03 »
De te lange as is voorzien van M4 schroefdraad, als je dus M4 in het asgat van het wormwiel weet (te laten) tappen, schroef je het zo op de ingekorte as.
Fixeren met een moertje/Locktite/secondelijm.
Daarnaast ... de as zit op een motor, dus kan draaien ...
As inkorten, motor ergens op vastklemmen, spanning erop en voorzichtig met een vijl van M4 3mm rond maken ...
Fotodijkje en fotodiorama
Obdam
« Reactie #1520 Gepost op: 11 March 2025, 17:24:27 »
Ben aan de hand van de suggesties. er ingedoken,en heb wat besteld(wederom)
Nu afwachten wanneer t aankomt  ???
  • Eens komt het goed.
    • MIL MOD
« Reactie #1521 Gepost op: 11 March 2025, 17:47:04 »
Eens komt het goed Floris  (y)
  • Spoor 0, dat wordt wel wat!
« Reactie #1522 Gepost op: 11 March 2025, 20:52:10 »
er valt in de tussentijd nog genoeg te doen:
fabriceren van stroomafnemers op de wielen. Aangezien deze grotendeels uit plastic bestaan
wordt dat nog een secuur werkje.
vr. groet,  Hans
« Reactie #1523 Gepost op: 12 March 2025, 16:43:59 »
Ik hoop t Wim  ::)
@Hans,
stroomafnemers op die wielen regelen is al "makkelijker"omdat de oorspronkelijke wielen en assen dr niet meer onder hangen.
Die zijn vervangen door schnellenkampf versies,ofwel  (zover ik weet) vol metalen versies.
Het vervaardigen ervan,die stroomafnemers dus,dat zal ik d.m.v. lief aankijken iemand anders t.z.t. moeten laten doen,dat is, geloof ik, iets waar ik geen kaas van heb gegeten  :-[
Wel ff uitzoeken waarmee ik dat gedaan kan krijgen,daarvoor heb ik nog niks zinnigs gevonden, t.z.t.  ???
We zien wel wanneer hier een frans pruttelding oversteekt :
Vooralsnog komt die nieuwe motor niet (op z'n vroegst) voor 4 april,dus ik heb tijd zat  :angel:
Om maar te zwijgen over wat er dan nodig is om t ding te plaatsen en werkend te krijgen :o
« Reactie #1524 Gepost op: 12 March 2025, 16:47:40 »
We gaan het wel beleven Floris.
Kees.
Br 41 Weinert loop of sloop
« Reactie #1525 Gepost op: 16 March 2025, 15:17:47 »
@ Hans1963,
Dat schotje waar je t over hebt,dat is ondertussen al verdwenen,al was de reden voor verwijdering ervan eigenlijk bedoelt voor een ander idee wat ik had maar niet uitvoerbaar bleek.
@Kees,
Op een bepaald punt,zal dat vast waarheid worden Kees,de vraag is echter wanneer kom ik op dat punt  ???
Nu even iets anders waar ik toch steeds sterker over na aan het denken ben.
Zou het een idee zijn om voor het omzetten van alle wissels,terug te keren naar iets wat ik op m'n HO baantje heb gebruikt ?
Ofwel terug naar verenstaal met knoppen om die dingen om te zetten,het is simpel,handmatig,altijd werkend,geen geklooi met elektronica die op den duur gaat weigeren.
Wat is jullie gedachte daarover  ???
    • MIL MOD
« Reactie #1526 Gepost op: 16 March 2025, 15:20:53 »
Ik zou zeker gaan voor het genoemde wissel systeem. Makkelijk, handig, altijd werkend en ook nog relatief goedkoop!
« Reactie #1527 Gepost op: 22 March 2025, 12:13:26 »
De kans is groot Wim dat dat ook terug zal keren,ben her en der al aan het zoeken naar verenstaal in rechte stukken die lang genoeg zijn en niet te gek duur kosten incl verzenden.
Dat blijkt nog een aardige opgave,ook moet ik nog achterhalen hoe dik t maximaal mag zijn.
Het liefst zou ik de bestaande gaten in de stelbalken van de wissels,die nu een motor hebben,willen gebruiken,maar ik heb momenteel geen idee hoe dik het daarbij geleverde staafje is,en of dat ook geschikt is qua dikte om over langere afstanden de beweging over te brengen naar de wissels om ze om te zetten  ???
Normaliter is t dan een kwestie van even onder de baan hangen en opmeten met een schuifmaat,maar aangezien ik al een week een rechtse voet heb die verstuikt lijkt te zijn is lopen en ergens onderhangen nu niet echt een optie  :-X
Bovendien verteld het antwoord op de vraag over die dikte me niet,of het ook bruikbaar is op langere afstanden en hoogte verschillen die ik hier heb onder de modules  ???
Ook is er nog een nieuw probleempje komen bovendrijven,nu ik eindelijk weer een nieuwe schuifmaat heb(die oude is onvindbaar),ben ik is wat gaan nameten,en vond een probleempje.
De assen die het franse pruttelding voort moeten gaan drijven,zijn 4mm dik.
Aandrijving met ketting en tandwielen zijn bruikbaar al zal ik tandwielen daarvan moeten opboren,die zijn nu 3mm,maar dat gaat.
Dat telt echter niet voor het setje tandwielen en wormen wat ik heb gekocht,de worm en tandwiel die ik heb,die zijn niet op te boren naar 4mm,zou ik dat doen dan raak ik tandwielen kwijt,en van de worm blijft niks over,die is buitenmaats zo goed als 4mm  :'(
Altijd fijn dit soort ontdekkingen :-X  ::)
« Reactie #1528 Gepost op: 22 March 2025, 17:40:03 »
Ach Floris.
Ook dit kom je wel weer te boven, bij mij gaat het ook niet altijd van het leiendakje.
Kees.
« Reactie #1529 Gepost op: 27 March 2025, 16:33:24 »
Nieuw tandwiel gevonden en bezorgd.
Nu nog afwachten wanneer die nieuwe motor verschijnt  ::)
