Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Probleem: ramen 'beslaan'  (gelezen 7021 keer)
VAM65
  • Nederland 1949-1963 in h0
Re: Probleem: ramen 'beslaan'
« Reactie #15 Gepost op: 25 March 2020, 10:43:32 »
Schoonmaken gaat ook met aceton of nagellak verwijderaar.
« Reactie #16 Gepost op: 02 April 2020, 11:49:53 »
Ik haak nog even in op dit draadje. Soms is het onvermijdelijk om ramen of andere transparante delen aan te brengen op materiaal wat daarvoor met secondelijm in elkaar is gezet. De beste aanpak hiervoor lijkt mij gewoon een tijdje te wachten met het aanbrengen van de ramen totdat de lijmdampen van de secondelijm zijn vervlogen.
Wat voor termijn zou ik dan aan moeten denken? 48 uur of eerder een week voor de veiligheid?
Mvg, Paul
« Reactie #17 Gepost op: 02 April 2020, 15:41:58 »
Ik hou slechts een paar uur aan.
Het verdampt heel snel is mijn ervaring.
Houtlijm gebruiken of c-clear voor het plastic "glas" ???
Ronald Visser
« Reactie #18 Gepost op: 02 April 2020, 15:51:27 »
Op 28 april is alles weer veilig....
Anyway. De beste toepassing van secondelijm is het niet gebruiken van secondelijm.  8)
Misschien wat flauw maar volgens mij is het gebruik van secondelijm vrijwel altijd te vermijden. Ik gebruik styreenlijm (Faller/Revell/UHU) of van die transparante Bison alleslijm, Eventueel de rand van het 'glas' waarop je lijmt opruwen met een schuurpapiertje voor een groter lijmoppervlak.
Modellbahnwagen
« Reactie #19 Gepost op: 02 April 2020, 16:15:45 »
Maar ook styreenlijm kan een waas achterlaten op doorzichtig plastic als het model gelijk wordt dichtgemaakt. 1 keer last van gehad door te snel klaar willen zijn. Sindsdien laat ik de lijmverbinding een paar uur uitwasemen en nooit geen problemen meer gehad, het glaswerk blijft helder.
Richard
« Reactie #20 Gepost op: 02 April 2020, 16:21:56 »
Daar heb je een punt.  (y)
Ik laat modellen inderdaad altijd goed 'open'/ademend drogen.
« Reactie #21 Gepost op: 02 April 2020, 17:28:00 »
Dank voor de antwoorden. Ik heb een bouwmethode waarbij ik onderdelen uit karton snij, met knutsellijm in elkaar plak en daarna verzadig met dunne secondelijm. Daarna is het materiaal keihard en niet meer vezelig. Ik ben nu op die manier een gebouwtje aan het bouwen en op een gegeven moment gaan daar ramen in.
Met deze methode is secondelijm onvermijdelijk dus.  8) Ik zal een flinke pauze inlassen om ellende te voorkomen. Het acryl lijm ik met Kristal Klear op het kartonnen kozijn.
Mvg, Paul
Duikeend
« Reactie #22 Gepost op: 02 April 2020, 18:54:32 »
er zijn denk ik nog wel wat meer methodes om het te voorkomen..
- Je zou iets anders kunnen gebruiken om het karton "hard" te maken. Zo zit ik te denken aan hard tex van de action, een soort kristal klear om textiel "hard" te maken.
- Ook kun je is kijken of je je seconden lijm kunt "blussen" met baking soda, iets wat ik vanavond even ga proberen. Vanmiddag speciaal daarvoor soda gehaald  ;D update plaats ik later in mijn duikeend knutsel draadje
- En als laatste gebruik ik ook regelmatig gewoon onder de kraan houden om de reactie van de secondelijm te stoppen. Deze lijm reageert namelijk met water waardoor hij meteen hard is. Misschien niet echt praktisch met karton  ;D
« Laatst bewerkt op: 02 April 2020, 19:00:20 door Duikeend. Reden: typo aangepast »
Groetjes, Ferenc
hondekop
« Reactie #23 Gepost op: 02 April 2020, 19:28:21 »
Ik gebruik lijm van Bergswerk.eu en heb geen last mee van wit uitgeslagen ramen.
Rob
« Reactie #24 Gepost op: 02 April 2020, 19:30:18 »
Hmmm, ik had nog nooit van ‘hard tex’ gehoord, maar de Action is de vaste hobbywinkel, dus ik ga er morgen maar even naar op zoek. Ze laten nog steeds klanten binnen al is het gedoseerd. Dank voor de tip.
Mocht dat het niet worden ga ik over op de andere tips, maar volgens mij hoeft het niet zo ver te komen.  :)
Mvg, Paul
Duikeend
« Reactie #25 Gepost op: 02 April 2020, 20:26:18 »
even zodat je weet wat je zoekt:
voor wat betreft de mix van de secondelijm en baking soda: wow! dat werkt goed!!
Was zo enthousiast dat ik vergeten ben foto's te maken maar er komt nog een 2e kant dus herkansing.  ;D
voor diegene die het niet kennen hier een heel leerzaam videootje. het is wel een beetje een wat hillbilly manier van uitleggen maar het werkt goed!:
https://www.youtube.com/watch?v=alyzGrgL6So
Edit: overigens werkt dat Hardtex vrijwel net als KristalKlear alleen droogt het net ff minder helder op. je kunt het wel gebruiken om ramen in te lijmen maar ze er van maken is niet aan te raden.
« Laatst bewerkt op: 02 April 2020, 20:30:12 door Duikeend »
Groetjes, Ferenc
hondekop
zuylen
« Reactie #26 Gepost op: 03 April 2020, 14:45:56 »
Ik hou 't op die Christal clear ;).
phdirk
« Reactie #27 Gepost op: 03 April 2020, 16:35:23 »
Hallo Duikeend,
Heb je nu soda (Natriumcarbonaat (Na2CO3) of baking soda (Natriumbicarbonaat NaHCO3) gehaald. Dat kan nogal verschil maken in de reactie die je krijgt.
De isocyanaatlijmen (secondelijm/superlijm) werken allemaal op het principe dat ze de vochtlaag wegzuigen. Dat is hetzelfde principe als het schoteltje op een nat aanrecht. Je kunt het er haast niet vanaf trekken, maar wel het hele aanrecht over schuiven. Daarom maakt een overdosis water ook meteen een einde aan de isocyanaatlijm. Het hydrolyseert en is verdwenen.
Met beste groeten,
Dirk Meijer
Duikeend
« Reactie #28 Gepost op: 03 April 2020, 16:55:48 »
ik heb de Natriumbicarbonaat gebruikt. dit is al langer bekend als een prima "katalysator" voor isocyanaatlijmen. ik ben nu nog volop bezig maar zal vanavond even een paar fotos plaatsen en hier de linkjes vermelden. ik ben er in ieder geval super enthousiast over omdat het zowel beter lijmt maar ook perfect plamuurt  ;D
wat betreft je opmerking dat het secondelijm wegspoelt.. dat ben ik niet met je eens. het klopt dat het de sterkte niet ten goede komt maar in de hierboven gevraagde toepassing voor het verharden van karton denk ik niet dat het zo'n vaart loopt. ik gebruikte die methode om te zorgen dat de lijm meteen uitharde bij het gebruik als plamuur. alleen werkt dat dus met baking soda velen male beter  ;D dit was natuurlijk allang bekend, alleen niet bij mij  ;D
Groetjes, Ferenc
hondekop
phdirk
« Reactie #29 Gepost op: 04 April 2020, 15:19:21 »
Hoi Duikeend,
Bedankt voor de aanvullende informatie.
Met beste groeten,
Dirk Meijer
