om 01:40:35
Spoorwegmuseum in zwaar weer
tinus
om 01:09:59
EifelBurgenBahn
12 February 2026, 22:30:31
12 February 2026, 22:25:10
12 February 2026, 22:11:03
Cegielski
12 February 2026, 22:02:11
12 February 2026, 21:55:06
Stub switches
12 February 2026, 21:28:45
12 February 2026, 21:15:21
Steven Loosman
12 February 2026, 21:15:20
reinderlf
12 February 2026, 21:12:47
12 February 2026, 21:09:20
Bediening OOC terminal Oss
timtrein
12 February 2026, 19:50:02
12 February 2026, 19:42:24
12 February 2026, 18:50:46
12 February 2026, 18:42:35
Roco 70788 2400 met Zimo MX645 acceleratie settings
Steven Loosman
12 February 2026, 18:12:17
Station Weesp
virmfan
12 February 2026, 18:05:15
Foto's station Weesp gezocht
virmfan
12 February 2026, 18:01:04
Voordelige treinkaartjes
12 February 2026, 18:00:49
12 February 2026, 17:46:46
Mijn LEGO modellen.
12 February 2026, 17:29:22
12 February 2026, 17:18:29
12 February 2026, 17:03:17
4 april Het Stoomgenootschap naar Köln
Seinhuis
12 February 2026, 16:55:32
Minstens 5 jaar geen treinverkeer Groningen-Leer [D]
Noordster
12 February 2026, 16:51:57
12 February 2026, 16:42:09
Spoor vernieuwing Oisterwijk
12 February 2026, 16:42:05
12 February 2026, 16:41:07
Daan Knoben
12 February 2026, 16:25:59
Materieelbespreking
Artitec vs C rail.
Topic: Artitec vs C rail. (gelezen 3140 keer)
arnout
Artitec vs C rail.
04 February 2018, 13:17:08 »
Goedenmiddag,
Vraagje:
Hoe rijden Artitec treinstellen op Marklin C-rail wisseld
en bogen vanaf radius 3. En met wissels bedoel
ik dan slanke wissels. Gaat dit soepel en zonder problemen?
Gr Arnout.
Jan-Peter
Bnlx treinendokter.
Re: Artitec vs C rail.
04 February 2018, 13:43:15 »
DE1 en DE2, zo uit de verpakking geeft geen probleem zelfs om de standaard (360) en parallel bogen (437). Evenmin de standaard wissels en kruizingen.
Mijn DE3's moet ik nog testen, maar standaard wissels (in de pendelbaan) geen probleem.
Jan-Peter
Laatst bewerkt op: 04 February 2018, 13:44:53 door Jan-Peter
Martin Hornis
04 February 2018, 14:31:40 »
Wel uitkijken met de wissellantaarns.
Märklin K-rails met boogstralen > 500 mm; NS-lichtseinen met cijferbak: 4, 6 en 8 in één bak; iTrain; Intellibox I; OC32;
eigen treindetectiesysteem aangesloten op OC32;
controleprogramma voor OC32.
arnout
04 February 2018, 14:45:33 »
Ok. bedankt voor jullie reactie.
Ik heb geen wissellantarens. Ik heb eigenlijk een BLS/zwitserse verzameling.
Maar vind de aangekondigd hondekop wel erg mooi eigenlijk evenals een DE I of II.
Gr Arnout.
JSRail
05 February 2018, 13:01:59 »
Heb de DE-2 en plan U rijden op m'n baan met marklin c-rail. Ook hier geen problemen. Zelfs bij m'n schaduwstation met her en der R1 gaat goed
BTW ook de roco plan T gaat prima !
Laatst bewerkt op: 05 February 2018, 13:03:39 door Haarlems Spoor
05 February 2018, 16:02:51 »
Ik heb zelf de 2-rail versie, maar ik mag toch aannemen als je de 3-rail versie hebt, dat er wielen onder zitten met een Märklin profiel.
Jeroen Water
NS tijdperk IV (1973/1974)
05 February 2018, 16:48:02 »
Ik rijd dan weliswaar op K-rail, maar ook hier na enkele kleine aanpassingen geen problemen met de DE-1, 2 en 3.
Wat bij AC wel eens tot problemen kan leiden zijn de metalen 'snuffels' op de scharfenbergkoppelingen. Deze kunnen wel eens tegen de middencontacten op wissels botsen. De snuffel wat inkorten is dan de makkelijkste oplossing.
Ook wil de bodemplaat onder het aangedreven draaistel wel eens te laag hangen en op wissels het draaistel wat optillen, zodat de wielen onvoldoende grip hebben. Het plaatje eat dunner vijlen helpt dan vaak.
arnout
05 February 2018, 19:17:12 »
Hoi klaas,
Daar kan je wel van uit gaan ja.
Waar het eigenlijk om gaat is eigenlijk wat jeroen water aangeeft , dat er onderdelen blijven hangen/stoten tegen
de middencontacten of de bodemplaat. Ik heb eigenlijk geen zin in dat soort gesleutel. Ik heb 3 Rivarossi loks en die
lopen met de baanruimer bv ook tegen de middencontacten.
Nou is het zo dat de contacten bij C-rail bij mijn ervaring lager zijn als K-rail en er daar dus geen last van heb.
Het geval wil dat ik eigenlijk best meerdere Artitec modellen wil aanschaffen omdat ik ze gewoon mooi vind.
ondanks dat ik een Zwitserse verzameling heb zou ik toch graag een aantal NL modellen willen hebben.
Vandaar deze vraag en ik rij momenteel 3-rail.
Gr Arnout.
Materieelbespreking
Artitec vs C rail.
