Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Marklin Booster 60174 werkt niet icm CS2 voor 3 wegwissels  (gelezen 6285 keer)
banne
« Gepost op: 17 May 2017, 08:01:44 »
Kent iemand dit probleem? De 3 wegwissels aansturen vanaf de CS2 is geen probleem maar diegene die in het gedeelte van de booster liggen werken niet. De normale wissels werken wel  ???
Bart
banne
Re: Marklin Booster 60174 werkt niet icm CS2 voor 3 wegwissels
« Reactie #1 Gepost op: 17 May 2017, 08:03:00 »
Sorry, kan iemand deze verplaatsen naar digitaal?  ;D
Bart
Timo
  • Team encyclopedie
« Reactie #2 Gepost op: 17 May 2017, 08:47:41 »
Misschien iets meer details. Welke decoder bijvoorbeeld? En werkt hij wel als je het booster deel even uit de CS2 voedt?
Timo
PS Voor iets als verplaatsen is de knop "Meld dit bericht aan de moderator"  ;)
  • Forummoderator
« Reactie #3 Gepost op: 17 May 2017, 10:11:25 »
Klopt. Van dat knopje worden we vanzelf wakker :)
("Meld aan moderator" is juist ook voor alle huishoudelijke zaken zoals verplaatsen, te lange links, een tag die verkeerd staat enzo)
Reinout-als-moderator
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #4 Gepost op: 17 May 2017, 11:21:28 »
Een 3-weg wissel zijn toch 2 normale wissels naast elkaar, wat is het verschil dan? Misschien de aansluitdraadjes even omwisselen.
Mvg
Wim.
banne
« Reactie #5 Gepost op: 18 May 2017, 11:35:28 »
Gaat om decoder 74465. Zoals gezegd als de CS2 het deel aanstuurt werkt het allemaal prima. Via de booster niet.
Bart
Timo
  • Team encyclopedie
« Reactie #6 Gepost op: 19 May 2017, 10:01:56 »
Hoi banne,
Je bent nog steeds wat schaars met informatie ::)
Voor de zekerheid, je hebt exact die wisseldecoder ook nog een keer direct aan de CS2 geprobeerd?
En hoe? Los of in de baan?
En om welke booster gaat het?
En heb je dus al geprobeerd de draden naar de decoder om te draaien?
In welk formaat stuur je hem aan?
Timo
banne
« Reactie #7 Gepost op: 19 May 2017, 21:59:17 »
Mijns inziens geef ik toch alle info, de decoder is genoemd en de booster in de titel. Als ik de wissel op de CS2 aansluit rechtstreeks of in de baan werkt alles prima. Als ik het aansluit via de booster werkt ie niet. Dit kan dus niks met draadjes wisselen te maken hebben. Het lijkt er gewoon op alsof het protocol voor het aansturen van de 3 wegwisseldecoders niet ondersteund wordt door de 60174.
Bart
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #8 Gepost op: 19 May 2017, 22:42:18 »
Je hebt 2 draadjes voor de baanspanning, die kun je goed aansluiten en verkeerd aansluiten.
De B aansluiting op de O aansluiting en de O aansluiting op  de B, en dan zitten ze toch echt verkeerd en aangezien Motorola polariteit afhankelijk is kan het zomaar zijn dat het dan niet werkt.
Dit is natuurlijk onzin. De 60174 is gemaakt voor dit systeem, en zal alle signalen die de CS2 kent uitzenden.
74465 is multi-protocol, en werkt met Motorola en met DCC dat kan je CS2 ook uitsturen, als alles op de juiste manier is aangesloten zal het gewoon werken, kan niet anders namelijk ;)
« Laatst bewerkt op: 19 May 2017, 22:56:42 door Wim Ros »
banne
« Reactie #9 Gepost op: 19 May 2017, 23:00:29 »
Als ik de CS2 aansluit (zoals het moet, ben op de hoogte van B en O) en alles werkt, ik trek de stekker uit de CS2 en steek deze in de booster en het werkt niet dan heeft het toch niets te maken met verkeerd aangesloten draden op de rail of een ander protocol?
Bart
« Reactie #10 Gepost op: 19 May 2017, 23:21:05 »
Dat lijkt me sterk. Een booster ondersteunt niks, die versterkt alleen maar het signaal wat hij van de centrale krijgt.
Het is zoals Wim zegt, deze apparaten zijn voor elkaar gemaakt. En als het niet werkt, dan zie je iets over het hoofd of er zit ergens een draadje los.
Bahn-AG
« Reactie #11 Gepost op: 20 May 2017, 10:59:59 »
Hoi
Of een draadje ontbreekt.
Heb je de massa van beiden (CS2 en booster) wel met elkaar verbonden?
Bart
« Laatst bewerkt op: 20 May 2017, 11:41:13 door Bahn-AG »
banne
« Reactie #12 Gepost op: 21 May 2017, 07:55:47 »
Ook dit klopt ook niet helemaal, de 60173 is ook gemaakt voor de CS2 maar ondersteund geen MFX signalen. De 74 zou dit wel ondersteunen. Het is dus zeker niet zomaar een dom doorgeefluikje, er zit wel degelijk iets achter wat iets moet ondersteunen.
« Laatst bewerkt op: 21 May 2017, 07:57:53 door banne »
Bart
banne
« Reactie #13 Gepost op: 21 May 2017, 07:56:39 »
Hoi
Bart
Die is verbonden via de rails (alleen de middenrail is onderbroken) zou je deze misschien rechtstreeks moeten verbinden?
Bart
« Reactie #14 Gepost op: 21 May 2017, 09:18:24 »
MFX is tweerichtingsverkeer. Daar heb je inderdaad iets meer voor nodig. Maar voor wissels is dat niet aan de orde, dat zijn alleen maar signalen van de centrale naar de decoder, en daarvoor is een booster niet meer dan een doorgeefluikje.
Daarmee wil ik niet zeggen dat ik een oplossing voor je probleem heb, maar normaal gesproken zou dit gewoon moeten werken.
