Train o Matic smart power pack
om 00:52:58
om 00:45:14
om 00:41:10
Beekdaelen in H0
Ruben90
om 00:26:31
Ruben90
om 00:23:21
Op Zuid (NL H0)
Ruben90
om 00:15:50
06 January 2026, 23:34:14
willyTEE
06 January 2026, 23:18:29
3 januari NVBS oliebollenrit
FreekH
06 January 2026, 23:09:38
Frans loodsje et cetera
T.Spat
06 January 2026, 22:52:38
06 January 2026, 22:38:58
Bf Kibronn
06 January 2026, 22:37:37
06 January 2026, 22:31:04
06 January 2026, 22:22:21
06 January 2026, 22:15:08
06 January 2026, 22:09:45
Minitrix wissels verbranden
Patrick1977
06 January 2026, 21:52:43
Grappige foto's
06 January 2026, 21:47:54
Boosters en keerlus
06 January 2026, 21:36:32
06 January 2026, 21:34:08
06 January 2026, 21:14:08
De kleur van de Rail4Chem (BR185 locomotieven)
Bahn-AG
06 January 2026, 21:08:52
Update: baan in de tropen
Eric v C
06 January 2026, 20:56:14
Maasmuiden Haven
Christoph
06 January 2026, 20:40:18
06 January 2026, 20:07:21
NS Gs Goederenwagons
sneek
06 January 2026, 19:40:10
06 January 2026, 19:20:26
Onshape gebruikersgroep
Boertje
06 January 2026, 19:17:26
Vraag stoomlocomotieven
Overet
06 January 2026, 18:54:24
Roco wissels schakelen maar één kant op (DCC), maar analoog 14-16VAC beide kante
Ardin
06 January 2026, 18:49:41
Topic: Projekt 083-338 (gelezen 3870595 keer)
tuurtje
Reactie #9015 Gepost op:
10 December 2015, 22:42:58 »
Hoi Jan,
Maar hoe maak je dan de afrastering voor de varkens en kippen
Arthur
Team forummoderators
Reactie #9016 Gepost op:
10 December 2015, 22:46:53 »
Van de restjes.
Forummoderator
Reactie #9017 Gepost op:
10 December 2015, 22:48:31 »
... en dan gaan de varkens rechtstreeks de stortkoker in van de leverworstfabriek ...
O nee, dat zal niet gaan, want dan heb je geen spoorvervoer.
Reinout
Bouw v/d EifelBurgenBahn
(h0, zijlijn in de Eifel)
Eifelgeschiedenis
Luit
Reactie #9018 Gepost op:
10 December 2015, 23:08:09 »
Zeker wel , rollen blik voor de blikjes en pallets met blikjes leberwurst.
Reactie #9019 Gepost op:
11 December 2015, 10:10:07 »
Vannacht werd me in een helder moment ineens duidelijk waar die varkens en kippen ineens vandaan kwamen.
Ik weet eerlijk gezegd niet waar dat hok wel voor is, maar vast en zeker niet omdat er kippen en varkens, en/of ander vee, op het dak van de luchtmatrassenfabriek worden gehouden, maar ik vermoed dat het begrip "hok" geleid heeft tot het plotseling opduiken van de veestapel.
Ik verkeer in de veronderstelling dat het hok een ander doel dient. Om luchtmatrassen een zeker comfort te kunnen laten bieden, moet je ze volproppen met lucht, dan voelt het wat zachter aan als je er op gaat liggen. Nu zit er lucht genoeg in de lu... euh, atmosfeer om ons heen, maar je kunt die lucht maar lastig vastpakken, laat staan door een trechter in een luchtmatras proppen. Een compressor kan uitkomst bieden. Een stuk of twee van die dingen moet voldoende zijn om de behoeften van de fabriek te kunnen dekken. Op het dak in een daartoe bestemd hok geplaatst vinden ze voldoende lucht om uit te kunnen putten (vandaar ook de ventilatieroosters in de wanden van het hok) en bovendien wordt het lawaai, dat onvermijdelijkerwijs door de functioneringswijze ontstaat, buiten de deur gehouden.
Ziedaar de functie van het hok.
Beetje verder gefröbeld:
Forummoderator
Reactie #9020 Gepost op:
11 December 2015, 10:18:33 »
Ziet er goed uit. Het brengt inderdaad wat variatie op het dak. Dat wordt wel wat!
Reinout
Eifelgeschiedenis
Basilicum
Prae-adviseur
Reactie #9021 Gepost op:
11 December 2015, 10:55:10 »
Compressoren met een complete batterij filters om de lucht te zuiveren. Daarvoor heb je wel zo'n hok nodig, ja.
Wordt de luchtmatrassenlucht los met de matrassen meegeleverd of koop ik die dingen opgeblazen en wel? Kan ik dan later een navulverpakking kopen om de luchtmatras opnieuw of bij te vullen?
Deining in Dönsdorf
Dahinterhofen im Bau
Reactie #9022 Gepost op:
11 December 2015, 13:00:19 »
De luchtmatrassen worden wegens logistieke redenen zonder lucht geleverd. Elke luchtmatras wordt geleverd met een gratis waardebon voor onbeperkt luchtgebruik (zolang de voorraad strekt).
Natuurlijk kon ik weer niet wachten tot het dak er een beetje compleet bijlag, dus even kijken hoe het er uitziet met een likje verf erop:
Dirk J
Reactie #9023 Gepost op:
11 December 2015, 15:32:09 »
Als je je fabriek nog wilt
uitbreiden
Reactie #9024 Gepost op:
11 December 2015, 17:00:02 »
Dat zou wel leuk zijn, maar twee meter gevel in dezelfde stijl is misschien iets teveel van het goede. Er moet nog wel een stuk gemaakt worden, maar architectonisch gezien moet dat wel een iets ander karakter krijgen.
Hoe en wat weet ik nog niet, die geest heeft me nog niet bevlogen.
Nog even een picturaaltje van de stand van zaken mbt het onderhavige project (nr.298A sub b):
KJB
Reactie #9025 Gepost op:
11 December 2015, 17:58:07 »
Dat is geen gebakken lucht, Jan! Zet je er ook nog buffervaatjes naast voor de gecomprimeerde lucht??
Klaas Johannes
Reactie #9026 Gepost op:
11 December 2015, 21:33:12 »
Nee, die staan binnen. Anders zou er een slot op moeten.
Volgende keer maar weer eens met mijn camera zonder telefoniefunctie aan de gang. Die met telefoniefunctie levert bij kunstlicht nou niet direct de allerbeste kwaliteit.
Reactie #9027 Gepost op:
12 December 2015, 21:45:57 »
Vandaag mijn kleinzoon van drie op bezoek gehad. Fantastisch leuk, maar het joch heeft in z'n kleine lijfje tien keer zoveel energie als opa nog uit z'n ouwe botten bijelkaar kan sprokkelen, dus behalve erg leuk ook zeer intensief.
Het kleine wicht had van StNiklaas een heuse "elektrische" trein gekregen. Die moest natuurlijk mee naar opa, want dan konden ze fijn samen spelen.
Vandaar dus dat ik de knieën van een toch al iets versleten spijkerbroek grondig uitgesmeerd heb over ons laminaat, al spelend met een trein van.... Märklin MyWorld.
Daar sta je dan met je goeie gedrag.
Maar het was wèl erg leuk!
Tulpendaal
Westlandbaan-Delft
Reactie #9028 Gepost op:
12 December 2015, 22:13:34 »
Hoi Jan
en wie heeft er werkelijk met de trein gespeelt?
Gr Joke
ps Dat dak ziet er beter uit dan ik verwacht had, eerst had ik de verdacht gehad dat je er een vlakdak van wou maken. Zo ziet het er veel beter uit. Zag laatst op het net een 1:1 linoleumfabriek voorbij flitsen die veel weg had van jou fabriek of omgekeerdt.
Nog een paar schoorstenen enzo en nog zon verhoogde metaal plaat (geen idee waarom die daar zitten) en dan begint het te leven.
Groetjes Joke
TRAM
Reactie #9029 Gepost op:
12 December 2015, 22:33:06 »
Hoi Joke,
nou, allebei natuurlijk! De klein man was natuurlijk de Fahrdienstleiter. Opa heeft echt
mee
gespeeld.
Ik moet bekennen dat ik, vanwege het gemak, in den beginne wel met de gedachte heb gespeeld er een vlak plat dak van te maken. Maar inderdaad, dat zou wel erg eentonig geworden zijn.
Wat schoorstenen en ventilatiedingen en zo moet inderdaad nog, dat zal nog wat meer variatie geven.
Wat voor verhoogde metalen plaat bedoel je? Ik kan me daar even geen voorstelling van maken.
Een linoleumfabriek! Die staat ook genoteerd op m'n lijstje, er moet nog wat hoog fabriekachtig spul komen, dus wat inspiratie is nooit weg!
