Noord-Hollandse Modelspoor Dagen 2026 - 28 februari & 1 maart door KoploperMau
25 February 2026, 23:16:48
25 February 2026, 23:09:43
25 February 2026, 22:48:29
Botsing bij SGB 29-12-2025 door 1200blauw
25 February 2026, 22:25:40
25 February 2026, 22:24:31
25 February 2026, 21:56:56
25 February 2026, 21:19:17
Nieuw in de winkel! door maartenvdb
25 February 2026, 20:47:23
Raadplaatje door Charles_
25 February 2026, 20:21:10
25 February 2026, 19:57:09
RailBOX Electronics RB1110 DCC Centrale uit Polen door AlbertG
25 February 2026, 19:51:57
Miniatuurcamera die fatsoenlijke foto's maakt door VAM65
25 February 2026, 19:42:59
PB Models, ICR-rijtuigen door Marcel Kirkels
25 February 2026, 19:12:45
Gekke/vreemde/rare filmpjes en video's met treinen erin. door Joz
25 February 2026, 19:06:55
25 February 2026, 18:30:31
Rheinburg, TP V/VI door System-M
25 February 2026, 18:24:50
Zermitz door maartenvdb
25 February 2026, 18:14:41
Pattex Plastic lijm, isolerend of geleidend? door Klaas Zondervan
25 February 2026, 17:42:50
Toon hier je pas gereed gekomen (model-)spoorbouwsels ... door Casmir
25 February 2026, 17:09:16
25 February 2026, 17:07:41
25 February 2026, 16:54:55
25 February 2026, 16:36:09
BNS-Thailand: Spoorbouwen onder de tropenzon door Montanbahn
25 February 2026, 16:18:29
25 February 2026, 14:17:04
25 February 2026, 13:41:42
25 February 2026, 13:28:59
25 February 2026, 13:01:28
25 February 2026, 10:03:24
25 February 2026, 07:58:16
25 February 2026, 07:56:58
Auteur Topic: Een digitale demo pendelbaan  (gelezen 682779 keer)
Rob Moerkerken
Re: BNLS Baanbreker - Een digitale demo pendelbaan
« Reactie #765 Gepost op: 20 September 2012, 15:23:06 »
Karst,
Welke kleuren, typenrs. van de verschillende merken heb je gebruikt?
Bij Polka zie ik bv veel verschillende kleuren groen.
groet, Rob
Rob Moerkerken
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #766 Gepost op: 20 September 2012, 16:07:15 »
Een beetje creatief geweest met Hekiflor,  Heki Wildgras en allerlei Polak blaadjes...
... met Wildgras en Flor zijn mooie 'Brummelbossn' ( Bramenstruiken ) te maken... Deze komen/kwamen in Salland veelvuldig langs de spoorbaan voor.
... ook de rechter module heeft iets meer begroeiing. Met een dotje spuitlijm en wat Polakblaadjes maak je heel makkelijk blaadjes aan ( te ) lange grassprieten (y)
.... Heki Flor is los op het gras te gebruiken of met een Wildgras onderlaag.
... met de 6mm Polakvezels als ondergrond en een dek van Flor komt er mooi struikgewas tevoorschijn :)
Zo.. eens kijken of het werk van vanochtend al voeldoende gedroogd is voor de volgende laag  :D
Grtzz,
Karst
Karst Drenth
« Reactie #767 Gepost op: 20 September 2012, 16:16:19 »
Citaat van: Rob Moerkerken
Bij Polak zie ik bv veel verschillende kleuren groen.
Heki, Noch, Polak en Mininatur.
Van Polak bijna alle kleuren en alle lengtes, van Noch de Wildgras varianten in alle kleuren en 4 en 6 mm.
Grtzz,
Karst
mat64
« Reactie #768 Gepost op: 20 September 2012, 16:34:45 »
ziet er heel mooi uit !  :o
m'n complimenten (y)
Arjan
Patrick Pontier
« Reactie #769 Gepost op: 20 September 2012, 18:56:50 »
Prachtig  (y)
Je hebt de vaart er flink in zitten
Patrick
Karst Drenth
« Reactie #770 Gepost op: 20 September 2012, 20:42:50 »
Nou, de tip van Martin opgevolgd. Worsteprikkers... wel te dik, maar ja, stevige palen zullen we maar zeggen ;)
... 1.5x10mm onderin een 0.5mm gaatje geboord waarin een stukje verenstaal van 0.5mm past, verder alle palen ong 2.5mm onder de kop een 0.5mm gaatje geboord voor de 0.27mm dikke staaldraad. Veel te dik ( beide, paal en draad ) maar het moet ook nog een beetje 'Messetauglich' zijn ;)
En een paar plaatjes van de ( toekomstige ) bewoners...
... palen moeten uiteraard nog in de creosoot. Maar eerst eens wat grind rond het huisje aanleggen...
Grtzz,
Karst
Hendrik Jan
« Reactie #771 Gepost op: 20 September 2012, 20:47:47 »
 (y)
Zijn wel hele nette koeien.
Nergens een vlaai ;D
Hendrik Jan
-Billy Connolly
martijn v m
  • Heerwijk in H0
    • vames
« Reactie #772 Gepost op: 20 September 2012, 20:52:20 »
dit word is een mooi baantje Meneer Drenth.
Ik vind het ook erg mooi en gedurfd hoe U die Philotrains rijvaardig maakt met prachtig resultaat altijd.
Ik hoop dit baantje eens een keertje te mogen aanschouwen.
Groet Martijn
Karst Drenth
« Reactie #773 Gepost op: 20 September 2012, 22:44:48 »
Nou.... er gaat ook wel eens wat mis...  :D
... het grinderf aangelegd... Standaard methode: Tams N-ballast gemengd met AD-geel poeder. Netjes verdelen, aanstampen met een houtje... Natmaken met ontspannen water ( daarbij wel het huisje afgeschermd...  :P ) en daarna indruppelen met voorstrijk... Na enige minuten, trekt het vocht in het karton van het huisje...  >:( >:( Hopen dat het wegtrekt wanneer het opdroogt.. :-\ :-\ Zo niet, was dit het laatste kartonnen kitje ooit... ;)
... ook het zandpad gelijk meegenomen...
... en hier komt het op de weg uit.
Grtzz,
Karst
Sparrow
    • Treinen Fotografie
« Reactie #774 Gepost op: 20 September 2012, 23:27:08 »
Mooie plaatjes, lekker Hollands!
ATB
  • Modelrailroading is fun
« Reactie #775 Gepost op: 20 September 2012, 23:35:40 »
Jezus Karst, zelfs het optrekkend vocht op schaal nagedaan. Jij bent wel van een andere planeet hoor op modelbouwgebied ;D ;D
Karst Drenth
« Reactie #776 Gepost op: 21 September 2012, 00:11:32 »
Nee hoor,
gewoon van Mars, net als alle andere mannen ;) ;D
Grtzz,
Karst
P.S. Het vocht begint al weer een beetje weg te trekken.... dus ik heb weer een beetje hoop ;)
Tomasso
« Reactie #777 Gepost op: 21 September 2012, 00:27:29 »
Oh da's mooi. En daarna gaat het bobbelen :P ;D
Spoor 0 adept
Martin Welberg
  • FYA !!!
  • OO. Organisatie OntraXS!
« Reactie #778 Gepost op: 21 September 2012, 01:14:30 »
Van een afstandje gaat het nog wel, closee up..................veel te vet...........was maar een idee, ben 0 gewend..
Martin Welberg
  • FYA !!!
« Reactie #779 Gepost op: 21 September 2012, 02:12:53 »
Korte vraag Karst, wat mag zo'n DE1 2e hands kosten ?
