Syb030
om 01:18:54
om 00:44:07
om 00:20:16
Station Arnhem jaren '80'
DavidNS400 Grote sik
17 January 2026, 23:39:16
17 January 2026, 23:23:33
17 January 2026, 23:19:37
17 January 2026, 23:16:08
Tomasso
17 January 2026, 22:43:26
17 January 2026, 22:39:14
Grasmasters
17 January 2026, 22:36:28
Tandwielen Fleischmann BR 80
17 January 2026, 22:36:02
17 January 2026, 22:30:36
Cegielski
17 January 2026, 21:58:41
17 January 2026, 21:57:40
Hlv53
17 January 2026, 21:31:04
17 January 2026, 20:30:55
17 January 2026, 20:01:51
17 January 2026, 19:54:20
17 January 2026, 19:53:37
17 January 2026, 18:20:55
17 January 2026, 18:00:17
17 January 2026, 17:52:31
17 January 2026, 17:46:16
65 baanplannen
PeterNS
17 January 2026, 17:28:15
Gewoon wat busfoto's
17 January 2026, 17:24:12
Jouef 2026
ceuleer
17 January 2026, 17:17:10
17 January 2026, 17:11:13
Roco 2026
17 January 2026, 16:38:23
Arjen52
17 January 2026, 16:30:57
In Frankrijk met je EV oude spoorlijnen nieuw leven inblazen....
borotof
17 January 2026, 16:28:46
NS stoomloc (Maffei) in Spoor-1. Etsplaten, bouwproject.
Topic: NS stoomloc (Maffei) in Spoor-1. Etsplaten, bouwproject. (gelezen 64075 keer)
arnout
Re: NS stoomloc (Maffei) in Spoor-1. Etsplaten, bouwproject.
Reactie #180 Gepost op:
05 February 2022, 23:16:35 »
Je bent in ieder geval bezig Fred. En wen er maar aan je hebt altijd weer iets te kortom te weinig.
En inderdaad voorraad is belangrijk, beter mee als omverlopen zitten.
Gr Arnout.
Reactie #181 Gepost op:
05 February 2022, 23:28:14 »
@ Fred,
Klinknagels:
Hassler:
https://www.hassler-profile.li/index.php/produkte/schrauben-muttern-unterlegscheiben-nieten/nieten/messingnieten
Knupfer:
https://knupfer.info/shop/index.php/nieten-nietenschrauben.html
Micro-Modele
https://micro-modele.fr/fr/35-rivets-din660
Boortjes:
https://www.hbm-machines.com/producten/hbm-150-delige-cobalt-borenset-kleine-maten
https://www.hbm-machines.com/producten/hbm-10-delige-hss-borenset-05-22mm
https://www.hbm-machines.com/producten/hbm-150-delige-hss-borenset-kleine-maten
@Arnout,
Blauwe dozen:
https://www.google.nl/search?source=univ&tbm=isch&q=blauwe+kartonnen+dozen&fir=qE4xIxhwf2P_fM%252C5CeEu7ezx-oRxM%252C_%253BKlSzvHjVvA1cMM%252Cq20JtH4O4e48OM%252C_%253BbBUGapZIJ_bawM%252Cq20JtH4O4e48OM%252C_%253BfGgCjN6odUDUDM%252CRHoP9u2rUWL2RM%252C_%253BOXiE7j2kknQTRM%252CdneC222turkiuM%252C_%253BFbvILr4fyIKqCM%252CdneC222turkiuM%252C_%253B14lWHvthOYNCdM%252CdcG0bN94PHwjqM%252C_%253BqsxnEkxilFUU6M%252CXAIymvwU24RICM%252C_%253B2fwp5J3FDT5h4M%252CXjmZ9-P7UY50uM%252C_%253B7UnE0Hvpriv9WM%252C8-DQ1-RrMHj2JM%252C_&usg=AI4_-kStybTaoGI3ek0LQ2XuwObrOKXO8Q&sa=X&ved=2ahUKEwih7tmqzun1AhXEhqQKHTSgDfoQjJkEegQICRAC&biw=1536&bih=750&dpr=1.25#imgrc=qE4xIxhwf2P_fM
Geel schuimrubber,
https://www.plexideal.nl/pvc-schuim-geel-ral-1023-3mm/?utm_source=Google%20Shopping&utm_campaign=Shopping%20Feed&utm_medium=cpc&utm_term=57172&gclid=EAIaIQobChMIv-qyj8_p9QIVBeN3Ch0vswAgEAQYASABEgIWivD_BwE
Laatst bewerkt op: 05 February 2022, 23:44:24 door FritsT
arnout
Reactie #182 Gepost op:
05 February 2022, 23:59:28 »
Jij weet precies welke blauwe dozen en gele binnen voering ik bedoel
Reactie #183 Gepost op:
06 February 2022, 00:00:13 »
Ik zie dat de klinknagelpers van Metal Smith ook weer online staat........
Bestellen via email.
Indien ze kunnen leveren, koop dan direct de aambeelden PA4 PA7 en PA10 er bij. Kleine, middelgrote en grote klinknagels.
http://www.metalsmith.co.uk/rivet-embossing-tool.htm
Reactie #184 Gepost op:
06 February 2022, 11:27:52 »
De schortplaten EERST van klinknagels voorzien en dan pas buigen.
Ik heb een buigmal met een straal van 10 mm.
Testen op hoogte-instellingen op een strip uit de fret.
Soldeeropstelling met een plaatje 1,0 mm aluminium er onder en een L-profiel er achter. Twee zwaargewichten om schuiven te voorkomen.
Resultaat na het pas maken van de inkepingen voor verstevengingsdriehoeken en leidingen.
Laatst bewerkt op: 06 February 2022, 11:32:20 door FritsT
Reactie #185 Gepost op:
06 February 2022, 13:46:03 »
De verdikking (die in 0 scharnieren zouden moeten/kunnen weergeven) heb ik hier weggeslepen en ga andere exemplaren er stuk voor stuk opzetten.
Ik draai de luiken ook om. Binnenste buiten. Alles mooi vlak.
Achter de opstaptrede twee U-profieltjes
Bij de Schaal-0 versie heb ik onderaan L-profiel gesoleerd. Op foto's is het nauwelijks te zien, maar het is een half-rond profiel. Dat wordt dus een niet zo stevige onderrand, maar wel volgens 1:1.
Een extra profiel aan de binnenkant kan niet omdat daar de koppelassen vrij strak tegenaan lopen.
Dus het model tzt met beleid oppakken, bij de buffers.
en niet met je hand van bovenaf.
21G / 0,7 half rond. Dikker past niet onder de luiken door.
12371
Laatst bewerkt op: 06 February 2022, 14:05:20 door FritsT
Reactie #186 Gepost op:
07 February 2022, 19:22:17 »
Tijd om eens aan de bovenbouw te beginnen.
Eerst de rij klinknagels boven de deur....
En dan kan het spannende buigen beginnen.
Alles vlak op de ondergrond...loodrecht.
De andere kant kan niet vlak op het werkblad, dus de haakse hoek even er naast zetten.
mooi passende achterwand.
Gelijk de tweede loc ook gedaan. Nu zit het in de vingers.
12489
Reactie #187 Gepost op:
08 February 2022, 17:37:09 »
Omzetten van het dakdeel heb ik net zo gedaan als de methode die ik bij Spoor-0 gebruikte. Uitgloeien en ingeklemd (precies boven/onder de deuropening) over een ronde vijl buigen.
12698
Reactie #188 Gepost op:
08 February 2022, 19:43:57 »
De volgende uitdaging, alles aan elkaar perfect passend maken. Want dit is de kers op de taart.
Dus daar is dat U-vorige ding uit de laserplaat voor... een bodemplaat ter versteviging want dat dunne stripje onder de deur houdt alles echt niet recht.
Dit heeft de Spoor-0 versie niet. Was een leermoment zodat we het aan de Spoor-1 versie hebben toegevoegd. Groter van formaat kon niet vanwege de vuurkist/ketelfront met appendages.
Laatst bewerkt op: 08 February 2022, 19:49:05 door FritsT
Spoor-0 & Spoor-1
Reactie #189 Gepost op:
08 February 2022, 19:49:05 »
Reactie #190 Gepost op:
08 February 2022, 21:26:38 »
Ik heb geen haast om de loc af te krijgen, maar dit is toch wel even leuk om een begin te maken vanavond.
Bodemplaat en achterwand.
L-profiel 3x3 verticaal. Ook langs een haakse hoek of andere aanslag, dus strak en geen enkele naad of overstek.
Nog een keertje controleren, nooit fout......
en dan het eerste (tijdelijke) soldeerpunt. Ook aan de andere kant natuurlijk
tweede (tijdelijke) soldeerpunt. Ook dat aan de andere kant.
Nog een keertje controleren, helemaal niet fout......
Achterwand sluit naadloos aan de zijkant. Helemaal goed. prima
en dan vind ik het voor vandaag genoeg.
12809
Laatst bewerkt op: 08 February 2022, 21:30:43 door FritsT
Reactie #191 Gepost op:
09 February 2022, 09:17:52 »
De voorkant ook van U-profiel 3x3 voorzien en ook weer met 180 graden soldeer. Met 145 graden soldeer tegen de zijwanden gezet. Trapsgewijs solderen dus. Alles eerst met de Weller en daarna even de vlam er over (van binnenuit) voor het doorvloeien naar de voorkant.
Niks van buitenaf gesoldeerd. Alles van binnenuit.
Dakvluegels zitten nog los.
12895
Laatst bewerkt op: 09 February 2022, 09:20:38 door FritsT
Huib
Reactie #192 Gepost op:
09 February 2022, 10:58:21 »
Superstrak Frits
Buitenlust in 1:43,5 | BMD16N, BMD16N-SD | website:
www.avontuurinminiatuur.com
| vlog:
www.prutsvlog.nl
updates:
https://www.instagram.com/huibmaaskant/
Reactie #193 Gepost op:
09 February 2022, 13:10:29 »
Dakje rollen met de wals.
Past mooi.
Weer een uitdaging om dat, met de dakvleugeltjes, tot een mooi geheel te maken.
12983
Reactie #194 Gepost op:
09 February 2022, 19:22:42 »
En dan de dakvleugels en de bewerking daarvan.
Soldeer ze van binnenuit vast en ook goed in de ronde hoek. Mag best een beetje doorvloeien. (dat haal je later weer makkelijk weg).
Maar die over lap met het dak...die moet weg.
Je moet precies zagen. Onder het dak moet alles weg en de vleugel mag geen gat openlaten. Daar soldeer je zo meteen de regengoot op en op lucht kan je niet solderen.
Dat moet dit worden.
Van voren gezien, vóór het uitsnijden,
Na het uitsnijden en glad vijlen.
Die inkeping waar de vleugel in viel...waar ?
En het doorgevloeide soldeer in de hoek steek en glasvezel je weg.
