Piko NS 5/600 Hippel 2025 door Pukkie
Vandaag om 06:39:17
Vandaag om 03:25:42
Inbouw Märklin decoder 60906 door borotof
Vandaag om 01:05:46
26 February 2026, 22:57:04
26 February 2026, 22:44:46
26 February 2026, 22:32:52
26 February 2026, 21:57:27
26 February 2026, 21:54:58
26 February 2026, 21:44:41
26 February 2026, 21:44:33
26 February 2026, 21:43:07
26 February 2026, 21:33:20
26 February 2026, 20:45:12
26 February 2026, 19:58:08
26 February 2026, 19:58:04
26 February 2026, 19:52:19
26 February 2026, 19:36:07
26 February 2026, 19:12:39
26 February 2026, 19:02:10
26 February 2026, 18:53:33
Mehano ACTS 7102 door ceuleer
26 February 2026, 17:28:39
26 February 2026, 17:25:36
26 February 2026, 17:23:25
Beekdaelen in H0 door ruudns
26 February 2026, 17:17:30
26 February 2026, 16:13:36
26 February 2026, 16:09:59
26 February 2026, 15:36:26
H0e pizza layout door Sven
26 February 2026, 15:14:45
26 February 2026, 13:07:05
Raadplaatje door Hatsune Miku
26 February 2026, 12:45:33
Auteur Topic: Piko NS1100, materieelbespreking  (gelezen 249121 keer)
Harold34
Re: Piko NS1100, materieelbespreking
« Reactie #315 Gepost op: 20 June 2020, 22:32:10 »
Hoe kan ik het geluid van de 1100 zachter zetten? In welke CV is dit te regelen?
Mug
« Reactie #316 Gepost op: 21 June 2020, 01:39:57 »
Dat kan met F 22. (Functietoets)
Grtz. Frits
Grtz. Frits
VAM65
  • Nederland 1949-1963 in h0
« Reactie #317 Gepost op: 21 June 2020, 09:20:55 »
Zat er geen gebruiksaanwijzing bij ???? Zo niet, dan kun je de NL-versie daarvan per mail opvragen bij Scaletrading https://www.scaletrading.nl/modelspoor/piko/handleidingen/.
Hieronder staan de Engelse benamingen, gevonden op www.piko.de
F0 Light
F1 Sound on/off
F2 Horn high
F3 Horn deep
F4 Driver Cab light FS1
F5 Driver Cab light FS2
F6 Interior room light
F7 Shunting mode
F8 Horn double
F9 Fan
F10 Compressor
F11 Pantograph up/down
F12 Driver Cab Door open / close
F13 Driver Cab window open / close
F14 Train brake
F15 Auxiliary compressor
F16 Main switch
F17 Braking test
F18 Curve squeal sound on/off
F19 Rail clank sound on/off
F20 Train lighting: the loco pulls
F21 Train lighting: the loco pushes
F22 Volume control
F23 Soundfader
Harold34
« Reactie #318 Gepost op: 21 June 2020, 09:31:45 »
Mijn Multimaus kan maar tot F20  :o
« Reactie #319 Gepost op: 21 June 2020, 09:50:41 »
Via CV:
Volume-instellingen
Het totale volume van het PIKO SmartDecoder 4.1 Sound kan worden gewijzigd in SUSI Bank 2 (CV 1021 = 2) met behulp van de CV 900. Hiervoor wordt CV 1021 eerst op de waarde 2 gezet
geprogrammeerd en vervolgens de CV 900 naar de waarde van het gewenste volume, tussen 0 - 255.
Harold34
« Reactie #320 Gepost op: 21 June 2020, 10:28:21 »
Bedankt @Ben,  het is gelukt. CV 900 stond op 180. Ik heb hem op 35 gezet. Laat ik CV 1021 gewoon op 2 staan?
« Reactie #321 Gepost op: 21 June 2020, 10:46:08 »
Dat mag je laten staan.
Fritsprt
« Reactie #322 Gepost op: 21 July 2020, 19:06:14 »
Leuke promotiefilm van Piko van de schaal N versie
« Laatst bewerkt op: 21 July 2020, 20:55:50 door Fritsprt »
Groet Frits
Chrisjantje
  • I'm always keep TRAINing!!
« Reactie #323 Gepost op: 21 July 2020, 19:52:28 »
Leuk filmpje en inderdaad zijn de logo's aangepast op de N-versie. Piko is toch echt goed bezig.
Als ik vroeger wist wat ik nu weet, had ik liever vroeger geleefd!!
Rondje_HO
« Reactie #324 Gepost op: 22 July 2020, 17:00:58 »
arnout
« Reactie #325 Gepost op: 22 July 2020, 20:19:29 »
Als ze hem nou ook nog in het blauw maken.
Rondje_HO
« Reactie #326 Gepost op: 23 July 2020, 01:03:32 »
Die komt heus wel (denk ik ;) ) Ik heb het idee dat Piko's NL modellen best aardig verkopen  :)
Taigagaai
    • Flickr
« Reactie #327 Gepost op: 23 July 2020, 10:46:38 »
Als ik naar de foto's kijk op de facebook pagina van Chris, dan vallen mij de vissenogen van koplampen op bij het front aanzicht. Ik denk dat de lampringen nog wat donkerder aangezet mogen worden.
Spoorgroet, Martin
  • Bestuur
« Reactie #328 Gepost op: 23 July 2020, 12:09:15 »
Mooie lok, maar ben idd nog niet helemaal overtuigd om de roco's aan de kant te gooien eerlijk gezegd
« Reactie #329 Gepost op: 23 July 2020, 12:16:27 »
De gl/gr 1100 van Roco verkocht goed, de blauwe met gele neus is nu nog op diverse plekken in de dump. Piko doet er beter aan om gl/gr nummervarianten te maken (bv 1115 heeft ook tot het eind gereden)
Wat ik persoonlijk minder mooi vind zijn de vrij grove ruitewissers, had voor mij prima geweest als die waren meegegoten. Ze vallen erg op nu.
