24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
Vandaag om 00:29:38
Vandaag om 00:00:32
Brawa 2026 door grossraumwagen
24 January 2026, 23:40:44
Doornvliet door Ronzol
24 January 2026, 23:34:13
Condensator - Binnenverlichting en Decoder. door bask185
24 January 2026, 23:13:01
Japanse 2C2, 4-6-4, Hudson locomotieven in vele schalen. door minilocomaster
24 January 2026, 23:06:10
Baan weer opgebouwd na vervangen dakraam door minilocomaster
24 January 2026, 23:05:13
Bahnstrecke 5867 door 741230
24 January 2026, 22:50:51
Spur 0 1 Tage 2026 in Giessen (D) door Marty
24 January 2026, 22:34:05
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door Hans1963
24 January 2026, 22:32:00
24 January 2026, 21:35:17
PB Models, ICR-rijtuigen door cor_b
24 January 2026, 21:12:14
Welke central is betrouwbaar? door Ronald Halma
24 January 2026, 20:13:51
Ontraxs 2026 door Ronald Halma
24 January 2026, 20:08:37
24 January 2026, 20:04:43
Baanplan De Oosthoek (h0, 360 bij 140) door Frans Peeters
24 January 2026, 19:28:07
Bruine NS 1200s - Treinsamenstellingen. door Ferdinand Bogman
24 January 2026, 18:54:47
Ervaringen met bezorgdiensten (PostNL, DHL, etc) door Charles_
24 January 2026, 18:51:22
Yamorc YD8116 & MP1 vraag door Bert_Apd
24 January 2026, 18:44:28
19 Toen door Keska
24 January 2026, 18:42:15
US diorama in H0 door gdh
24 January 2026, 17:19:28
24 January 2026, 17:11:28
Die Sauerlandbahn - Tijdperk III door Frank 123
24 January 2026, 17:00:50
heeft iemand ideeën voor een baan van 120CM bij 240CM? door Ronald69
24 January 2026, 16:47:55
24 January 2026, 15:50:12
Oudere Marklin S3/6 opleuken door Robkop
24 January 2026, 15:19:07
24 January 2026, 15:05:32
Handleiding Trix Express 2232 BLS 255 door stoombr38
24 January 2026, 13:36:46
ICR-rijtuigen, voor welk merk ga je? LSmodels, PBmodels, Exact Train of Piko? door Hammondman
24 January 2026, 13:28:12
Big Scale Trains - NS SLT in H0 door hmmglaser
24 January 2026, 13:11:19
Auteur Topic: Smalspoorbaan "Hinterhof" Heinenoord  (gelezen 45872 keer)
Almar
  • Huisman met een hobby 😉
  • TT-baan & LGB Smalspoorbaan
Re: Tuinbaan Heinenoord
« Reactie #15 Gepost op: 11 February 2019, 17:24:10 »
Hallo Alan,
Leuk dat je reageert en inderdaad wat een verschil hè zo tussen spoor G en TT.
Met het programmaatje wat ik gebruikt heb om het baanplan te tekenen kon ik geen objecten tekenen maar het spoor aan de uiterst rechter zijde zal grotendeels uit het zicht komen te liggen. Omdat de oppervlakte maar beperkt is heb ik geen ruimte om  een volledig stationsgebouw e.d. te plaatsen. Het idee is om het station in halfprofiel uit te voeren en het over dit spoor heen te zetten. Een rotspartij aan beide kanten van het station doet de rest. Het betreffende spoor zal dan rechts onderin op de tekening in een tunnel in verdwijnen om pas aan de achterkant van de tuin, voorbij het station, tevoorschijn te komen.
Verder is het inderdaad wel een vol baanplan maar omdat ik wil gaan rijden met niet te veel, korte treinen zal het waarschijnlijk nog wel meevallen. Wat de rust ook ten goede zal komen is de schakelaar waarmee de soundmodules kunnen worden uitgezet in de locomotieven ;D
Wordt vervolgd.
Naast 'TT Baan Heinenoord' vanaf 2019 ook 'Smalspoorbaan "Hinterhof" Heinenoord' in schaal 1:22,5
Pnarfk
  • Modelbouw is een kunst
    • www.alanjockmans.com
« Reactie #16 Gepost op: 11 February 2019, 18:03:07 »
Klinkt goed, ik ben benieuwd  :)
Dat zullen de buren waarschijnlijk ook appreciëren  ;D
Groet, Alan Jockmans
Almar
« Reactie #17 Gepost op: 11 February 2019, 20:09:26 »
Hallo allemaal,
Naar aanleiding van wat reacties heb ik geprobeerd om de tekening wat duidelijker te maken. Het spoor wat helemaal rechts loopt zal uit het zicht zijn. Deels door rotspartijen en in het midden vanwege het stationsgebouw wat vanwege de ruimte in halfprofiel zal worden uitgevoerd. In de linkerbovenhoek is nu zichtbaar dat het onderste spoor door een tunnel zal lopen en het bovenste spoor via een lange brug, over het watertje helemaal naar beneden toe.
Volgens mij is het nu duidelijker (en anders gewoon weer vragen  ;))
Almar
« Reactie #18 Gepost op: 23 February 2019, 20:21:14 »
Hallo allemaal,
Vakantie in de achterhoek, dus gisteravond de eerste knutselavond. Ik ben begonnen aan de blokpost. Voor het eerst werken met Forex en Guttagliss is een nieuwe ervaring. Mooi materiaal, alleen de lijmkwast van het potje polyesterlijm vind ik een beetje te groot, daar moet ik nog even wat op gaan bedenken. Het eerste resultaat is zichtbaar;
Het steenmotief aan de onderkant is een kunststof folie die geleverd wordt door Jacksons Miniatures in Engeland die het op zijn beurt weer importeert uit Canada, zie https://www.jacksonsminiatures.com.
Vanavond de schilderdoos maar eens te voorschijn halen om de eerste kleur op de gevel te zetten.
Wordt vervolgd...
  • Eens komt het goed.
    • MIL MOD
« Reactie #19 Gepost op: 23 February 2019, 20:58:30 »
Hoi Almar,
Zelf met je vakantie nog wat bouwen  (y)
Peter Soonius
« Reactie #20 Gepost op: 23 February 2019, 21:25:27 »
Dag Almar,
Dat ziet er goed uit. Nog een fijne vakantie gewenst. Als je vragen hebt over de bouw van een LGB baan kun je ook terecht bij de vrijwilligers die de afgelopen twee jaar h
Peter Soonius
« Reactie #21 Gepost op: 23 February 2019, 21:28:59 »
Dag Almar,
Vervolg van mijn vorige bericht: er ging iets fout. Je kunt ook contact opnemen met de vrijwilligers van Stoomtrein Katwijk Leiden die de afgelopen twee jaar hard gewerkt hebben aan een grote LGB baan bij de ingang van het museum. Zij werken elke dinsdag en donderdag aan deze baan en zijn van harte bereid ervaringen met je te delen. Stuur me anders even een PB. Leg ik een lijntje voor je uit.
Almar
« Reactie #22 Gepost op: 24 February 2019, 00:18:34 »
@ Wim, juist in de vakantie is het erg leuk om 's-avonds lekker te kunnen hobbyen, Suze heeft gisteren haar eerste poppetje (made in china) geschilderd dus lekker tegenover elkaar aan tafel, muziek, drankje... we genieten ervan!
@ Peter, wat een leuk aanbod! Tijdens de model smalspoor dagen hebben we de baan staan bewonderen en de natuurlijk ook al het andere moois wat er te zien was. Ik stuur je morgen even een PB-tje (nu inmiddels een beetje laat)
Hallo allemaal,
Vanavond zoals gepland een avondje schilderen. Vanmiddag eerst het geheel in de grondverf gezet dus vanavond kon ik van start;
Nu eerst verder met de andere gevels en als alles in elkaar staat nog wat kleine onvolkomenheden wegwerken. Ben niet ontevreden met het resultaat  :)
Wordt vervolgd !
Almar
« Reactie #23 Gepost op: 04 March 2019, 00:39:04 »
Hallo allemaal,
In de vakantie was de bouw toch wat gestagneerd, dus gisteren en vandaag maar even een flinke inhaalslag gemaakt.
Gisteren heb ik de ontbrekende gevels afgemaakt en geschilderd. Omdat het een eerste bouwsel is maak ik gebruik van diverse materialen. De gevels zijn allemaal gebouwd met Forex en de natuurstenen onderrand is gesneden uit kant en klare kunststof sheets die ik in Engeland vond. (je moet ze nog wel zelf schilderen)
Vandaag heeft in het teken gestaan van het bouwen van de dakconstructie uit Guttagliss, veel schilderwerk en het afbouwen van de natuurstenen onderrand. Er moet nog steeds heel wat gebeuren maar onderstaande foto's geven een goede indruk van de stappen die vandaag gezet zijn.
Nadat ik het schilderwerk het afgerond en de accentuering op het "hout" had aangebracht zijn de vier muurdelen samengevoegd.
Vervolgens het ik een plaatje Guttagliss tevoorschijn gehaald voor de bouw van de dakconstructie. Het werken met Guttagliss is me erg goed bevallen, het enige wat af en toe wat lastig is is het verwijderen van de beschermfolie, maar verder een echte aanrader! (De dakconstructie is nu nog afneembaar omdat ik nog verlichting wil inbouwen)
Nadat de dakconstructie klaar was kon begonnen worden met de bekleding van het dak. Ik heb hiervoor gebruik gemaakt van dakpan-sheets die ik in Engeland besteld had. Sterk, niet te dik dus goed te verwerken met zowel schaar als mes, het verlijmen op de Guttagliss eenvoudig met PVC-lijm.
Toen de dakbekleding gereed was heb ik de eerste laag verf opgebracht en de boei-borden aan voor en achterzijde gemaakt.
En als laatste ben ik verder gegaan met de natuurstenen onderrand. Aan één zijde moet die nog worden afgemaakt maar dat wordt morgen, eerst moet de plastic-plamuur voldoende uitgehard zijn om de hoekstenen ook aan die kant vorm te geven zodat ze in de hoeken "doorlopen".
Al met al weer heel wat uurtje aan het bouwen geweest. Ik ben tevreden met het resultaat en ben erg benieuwd naar jullie reacties!
Wordt vervolgd.
    • MIL MOD
« Reactie #24 Gepost op: 04 March 2019, 08:41:58 »
Dat is een fraaie tuinhuisje geworden Almar  (y)
Nu nog even goed weer en dan ook buiten aan de slag. Maar vandaag maar even niet.
Ben benieuwd straks naar de eerste buiten foto's!
Almar
« Reactie #25 Gepost op: 04 March 2019, 10:17:58 »
Hallo Wim,
Ja ik ben zelf zoals ik schreef ook wel tevreden met dit eerste bouwsel. Wel grappig want de uitgangspunten zijn volstrekt anders. Alles moet weerbestendig worden, dus alles uit kunststof en straks het hele boeltje in een aantal lagen blanke vernis. Kleuren juist allemaal wat feller (hoewel de foto's geen goed beeld geven hoor ;)) en verweren hoeft niet wat dat doet de natuur straks... Geen openingetjes want je wilt geen insectenhotels maken etc, etc. Is dus echt een andere tak van sport. Voor mij is één van de grootste voordelen dat ik alles goed kan beethouden met mijn "kolenschoppen"  ;D
Ik hoop dat het weer nog wat hersteld want van de week wil ik de tuin leeg hebben...
Almar
« Reactie #26 Gepost op: 08 March 2019, 23:41:34 »
Hallo allemaal,
Toen we vorige week op vakantie waren in de Achterhoek zijn Suze en ik met de aanhanger naar Bocholt gereden om stenen op te halen. We hebben er in totaal 85 mee genomen, goed voor 18,5 meter spoor fundering.
Sinds ze in de achtertuin liggen begint het steeds meer te jeuken, ik wil aan de slag! Vandaag heb ik samen met Lasse, onze tuinman, de eerste belangrijke stap gezet. We hebben de achtertuin volledig ontdaan van beplanting, border-randen en schuttingen.
We hadden super mazzel met het weer en op dit moment is het net een nieuwbouwtuintje (alleen de paaltjes met ijzerdraadje ontbreken nog :D ).
De volgende stap is het plaatsen van een schuur in het verlengde van de bestaande schuur en het maken van de keerwand die de grond aan de achterzijde moet gaan tegenhouden. Het begin is er!
In de avonduren gaat de bouw van de blokpost verder. Inmiddels staat het volledige gebouw enkele keren in de blanke vernis en heb ik het bordes aan de voorkant gemaakt. Op dit moment ben ik met de verlichting bezig.
Op het bordes een verlicht bord met hierop de naam van de blokpost ,de verlichting bestaat uit met een ledstripje met 4 gele smd-ledjes die ik nog had liggen. De lantaarn komt uit China. Rest nog de verlichting bij de bordjes aan de zijkant en de interieur verlichting. De blokpost is dus bijna klaar, en voor een eerste bouwsel op deze schaal ben ik wel tevreden  ;)
Wordt vervolgd!
    • MIL MOD
« Reactie #27 Gepost op: 08 March 2019, 23:48:07 »
Zo Almar, jullie hebben flink je best gedaan. Eerst ruimen en dan bouwen.
Zo te zien is het toch een behoorlijk stuk grond waar je wel een leuke baan kunt "neerleggen". Ben erg benieuwd hoe het er straks uit gaat zien!
« Reactie #28 Gepost op: 09 March 2019, 02:32:05 »
Hallo Almar,
Je hebt het weer mee zie ik. En je hebt een goede hulp. Dat gaat helemaal goed komen. Veel plezier tijdens de bouw van je nieuwe baan.
Eegtrain
  • Lid Modelspoorgroep Eindhoven
    • Project Tauernbahn
« Reactie #29 Gepost op: 09 March 2019, 12:40:08 »
Sow wat een tof project dit zeg!! (y)
Groeten Jake
