Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Heen, En en Weer
Topic: Heen, En en Weer (gelezen 207208 keer)
Re: Heen, En en Weer
Reactie #540 Gepost op:
26 June 2021, 22:58:20 »
Pleisterstructuur op de buitenmuren.
Duin aanZee II
Het leven op de weg.
Reactie #541 Gepost op:
26 June 2021, 23:02:18 »
Het is kliederig maar met Alabastine muurvuller gaat het best. Miss wat strooisel voor korrelig effect toevoegen.
Je kan het zo wegvegen of opschuren.
En lkkr verweren met pigment poedertjes.
Gr Koen.
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #542 Gepost op:
27 June 2021, 17:30:43 »
Bij hippel 634 slaan de koppelstangen vast. Ik heb geprobeerd die los te maken om de buitenste boutgaten wat op te ruimen, maar dat mislukt hopeloos.
Iemand een idee hoe ik dat los kan maken?
Duin aanZee II
Reactie #543 Gepost op:
27 June 2021, 18:44:26 »
De koppelstangen zien er gedemonteerd zo uit als op de onderstaande link. In principe 1 geheel daar je de pinnen er volgens mij niet zonder schade uit kan krijgen. De plastic nokken wel. Maar dan moet de bodem plaat er af en de wielen set er uit nemen. Weet niet of dat je vraag beantwoord.
https://images.beneluxspoor.net/bnls/B481421E-A55D-4A5B-849E-7359F92F74DA.jpeg
Arjan
NL baan in Canada
https://forum.beneluxspoor.net/index.php?topic=71130.msg3221692419#msg3221692419
Reactie #544 Gepost op:
27 June 2021, 19:02:51 »
Mij gaat t om de koppelstangen zelf.
Duin aanZee II
Reactie #545 Gepost op:
27 June 2021, 21:30:07 »
Rijdt beter, maar dat geknars. Niet om aan te horen. En dus verder zoeken.
Laatst bewerkt op: 29 June 2021, 16:03:39 door Huup
Duin aanZee II
Reactie #546 Gepost op:
29 June 2021, 16:06:22 »
En dan bedenk ik me opeens dat er een coreless motortje in zit. Maar natuurlijk!
Sven heeft t notabene op z'n site staan.......
Het resultaat:
cv61=10
Nu die gele nog......
Laatst bewerkt op: 29 June 2021, 21:17:56 door Huup
Duin aanZee II
Reactie #547 Gepost op:
20 July 2021, 09:15:33 »
Voor de gele zijn onderdelen besteld, waaronder assen en wielen. Rijdt ie na montage goed, dan komen ook daar decoder, motor en condensator van de tramfabriek in. De groene is een lust voor t oog, en t niet stotteren verhoogt het speelplezier aanzienlijk. Het geld meer dan waard!
Laatst bewerkt op: 23 July 2021, 21:22:06 door Huup
Duin aanZee II
Modellbahnwagen
Reactie #548 Gepost op:
20 July 2021, 11:13:07 »
Die rijdt best netjes 👍
Richard
Reactie #549 Gepost op:
22 July 2021, 21:44:05 »
10 tortoises gescored voor seinen en de twee tramwissels op Weer. Ik is blij😋😇
Duin aanZee II
Reactie #550 Gepost op:
27 August 2021, 11:18:51 »
Even in Odoorn geweest, dus plaatje eggie/eggieklein gemaakt. En nog wa aanvullende fotoos van het interieur.
Laatst bewerkt op: 29 August 2021, 16:50:48 door Huup
Duin aanZee II
Modellbahnwagen
Reactie #551 Gepost op:
27 August 2021, 11:54:34 »
Prachtig huisje
en met twee verschillende metselverbanden. Is dat in het echt ook? Mooi inieder geval.
Richard
Reactie #552 Gepost op:
27 August 2021, 12:58:04 »
Ja, dat is in het echt ook. Het rechter deel is later bijgebouwd. Van het oorspronkelijke pandje is bitter weinig over.
Duin aanZee II
Twentelijn 1968-1980
Reactie #553 Gepost op:
27 August 2021, 15:01:28 »
Het gedeelte voor de kijker rechts lijkt een latere aanbouw. Dat zou het afwijkende metselverband kunnen verklaren.
Hoe dan ook een fraaie weergave van de werkelijkheid
Reactie #554 Gepost op:
27 August 2021, 15:03:46 »
Klopt, en dank. Ik zie een fout.... 😔
Duin aanZee II
Heen, En en Weer
