Pukkie
om 06:39:17
om 03:25:42
Inbouw Märklin decoder 60906
borotof
om 01:05:46
R v/d Hoven
26 February 2026, 22:57:04
26 February 2026, 22:44:46
26 February 2026, 22:32:52
Anton Maris
26 February 2026, 21:57:27
Roco 10764 overload
26 February 2026, 21:54:58
Nummerplaat stoomlocomotief NS 4700 vragen...
26 February 2026, 21:44:41
Viessmann straalantaan 6922
26 February 2026, 21:44:33
"Spoor op Vleugels" in H0
Pinkelpa
26 February 2026, 21:43:07
Daan in Las Vegas
26 February 2026, 21:33:20
26 February 2026, 20:45:12
Klarentrein
26 February 2026, 19:58:08
timtrein
26 February 2026, 19:58:04
Botsing bij SGB 29-12-2025
timtrein
26 February 2026, 19:52:19
26 February 2026, 19:36:07
26 February 2026, 19:12:39
Laatste baan in aanbouw
Debvd
26 February 2026, 19:02:10
De Hondsrugbaan
Jint Nijman
26 February 2026, 18:53:33
Mehano ACTS 7102
ceuleer
26 February 2026, 17:28:39
26 February 2026, 17:25:36
Wandplanken, advies.
26 February 2026, 17:23:25
Beekdaelen in H0
26 February 2026, 17:17:30
R v/d Hoven
26 February 2026, 16:13:36
Bor de Wolf
26 February 2026, 16:09:59
NME stuurstandrijtuig (was: Nieuw in de winkel)
26 February 2026, 15:36:26
H0e pizza layout
26 February 2026, 15:14:45
Te 2/2
26 February 2026, 13:07:05
Hatsune Miku
26 February 2026, 12:45:33
Oersik in schaal 1
Topic: Oersik in schaal 1 (gelezen 165495 keer)
WesleyMunnik
Re: Oersik in schaal 1
Reactie #345 Gepost op:
14 May 2018, 15:50:23 »
Eerder dan beloofd,
Spoor 1
https://www.shapeways.com/product/ZYD7D62WU/aspot-zonder-veren-spoor-1?optionId=65471202&key=354c520c99043d29fa2f70ed649d038b&li=shop-inventory
Spoor 0
https://www.shapeways.com/product/S7JKZ59U2/oersik-spoor-0-aspotten-zonder-verenpakket?optionId=65471348&key=d54307236a1b7748e00f9deaddce118d&li=shop-inventory
Groetjes,
Wesley
Wesley Munnik
www.modelspoordesign.nl
rolfm
Reactie #346 Gepost op:
14 May 2018, 16:14:27 »
@Frits Heb de draaibank nog niet zo lang en nog wat last soms van koudwatervrees maar je hebt gelijk ......kwestie van meer oefenen.
Bedankt voor de overzichtsfoto met , als ik het goed zie, een tapse bufferhuls en bolle bufferplaat
@Wesley TOP, Bedankt voor de aanpassingen, ik denk dat ik van deze aangepaste messing versies (dus aspot zonder de veren) gebruik ga maken.
Reactie #347 Gepost op:
14 May 2018, 19:33:11 »
Dus met een iets grovere vijl langs de kop van de messing staaf, terwijl die in de draaibank draait, vijlen en de ronde vorm geven. Later polijsten.
IMG_5302
by
Nulpunt0
, on Flickr
Reactie #348 Gepost op:
14 May 2018, 20:38:19 »
De proefbufferplaat was 2,0 mm dik..iets te dik. De serie heb ik met 1,5 mm gemaakt.
Gietdelen imitatiebouten. Losse exemplaren bij GHW.
IMG_5305
by
Nulpunt0
, on Flickr
IMG_5303
by
Nulpunt0
, on Flickr
Gemonteerd met "koude" lijm (10-secondenlijm) om doorvloeien en loslaten van de individuele componenten te voorkomen. KEN UW GRENZEN.
IMG_5304
by
Nulpunt0
, on Flickr
Laatst bewerkt op: 14 May 2018, 20:41:45 door FritsT
WesleyMunnik
Reactie #349 Gepost op:
14 May 2018, 20:47:40 »
Ondertussen het luchtfilter getekend en geupload bij shapeways.
De Luchtfilters zijn best prijzig als ze los geprint/gegoten worden, dus mijn mening is dat ze samen met de aspotten/lampen/buffers moeten komen om de kosten te drukken.
Spoor 0 kan op 14,50 en spoor 1 op 16,75 uit.
Gr,
Wesley
Wesley Munnik
rolfm
Reactie #350 Gepost op:
14 May 2018, 21:17:22 »
Hoi Wesley,
Goed bezig
Je had al eerder ook de sluitlantaarns getekend volgens mij, komen deze ook nog beschikbaar bij Shapeways?
Gr. Rolf
Reactie #351 Gepost op:
14 May 2018, 21:20:16 »
Maak nou iets zelf....... geeft voldoening.
het hoeft niet snel
en anders heb je toch alleen maar een doos vol onderdelen. Juist als je besluit specifieke dingen te gaan maken is dat een stimulans om het hele project te doen.
Laatst bewerkt op: 14 May 2018, 21:22:29 door FritsT
Ad Cleijsen
Reactie #352 Gepost op:
14 May 2018, 21:34:55 »
Bij Edwin vanavond de etsplaat opgehaald en
Na wat stuntelen, proberen, oefening voor het echie gegaan
chassis - stap 1 ben best tevreden met mezelf.
groet Ad
Laatst bewerkt op: 14 May 2018, 23:39:58 door Edsko Hekman
Reactie #353 Gepost op:
14 May 2018, 21:43:53 »
Goed bezig, messing is niet eng of moeilijk. Sterker nog, als het niet goed is, doe je het gewoon opnieuw!!
Is Ad zijn eerste messing model!!
MB6400
Reactie #354 Gepost op:
14 May 2018, 22:48:07 »
Ook ik ben gisteren begonnen met de Oersik kit en kan dan natuurlijk niet achterblijven met plaatjes.
Ik ga het tempo van andere bouwers hier zeker niet bijhouden maar het eerste begin is er
Alles gechecked en ge-dubbel-checked met blokhaakjes om ervoor te zorgen dat alles haaks is.
Nu de andere zijkant.
Reactie #355 Gepost op:
14 May 2018, 22:53:26 »
Dat zijn er dus al 7.....
Reactie #356 Gepost op:
15 May 2018, 08:00:42 »
Het lijkt erop, dat de spoor 1 bouwers fanatieker zijn dan de spoor 0 bouwers!!!!
becasse
http://becasse-weathering.blogspot.nl/
Reactie #357 Gepost op:
15 May 2018, 10:25:54 »
Ha Tinsnuivers,
Goed begin Ad! En Edwin, als die 1’ers eenmaal los gaan, hou je dan maar vast.
Ons voordeel is dat er in 1 überhaupt geen kits zijn. Een de nullers hebben vaak nog zo’n stapel kits liggen die nog gedaan ‘moeten’ worden....dat is niet erg motiverend, denk ik.
Dus een zandwagentje als opvolger zou toch zo fijn zijn
Michiel
Waar gaan we heen voor spoor 1?
Ivo tB
Reactie #358 Gepost op:
15 May 2018, 11:21:34 »
Graag: GTG, GL, GLG of HTM(K) lijken me wel wat (zijn overigens kolenwagens en geen zand). En natuurlijk een echte CHD. GLY en HTM zijn misschien wel om te bouwen van een duitse versie als die op de markt zouden zijn.
Ivo
P.S. eerst maar eens een Oersik bouwen
Ivo
WesleyMunnik
Reactie #359 Gepost op:
15 May 2018, 11:46:53 »
Citaat van: 1795 op 15 May 2018, 08:00:42
Deze Zijsprong nuller wacht in spanning op de Etsplaat
Gr,
Wesley
Wesley Munnik
Oersik in schaal 1
