Swird HO door Jeroen Vreeken
Vandaag om 02:12:34
Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
Auteur Topic: Oersik in schaal 1  (gelezen 163668 keer)
guest7823
Re: Oersik in schaal 1
« Reactie #270 Gepost op: 10 May 2018, 15:14:08 »
Naar Breda gaan .... yup, is best een grote klus, maar .....doenbaar  ;D
guest7823
« Reactie #271 Gepost op: 10 May 2018, 15:19:10 »
En dat afdraaien van de wielen...... dat is erg afhankelijk van hoe hard / taai / lastig (af)draaibaar de wielen zijn. Maar als het een beetje makkelijk draaibaar ijzer is ........ moet het binnen een uurtje wel gedaan zijn (eerder minder).
Maar als het echt hard is kan het wel even duren want dan moet het met (hele) kleine stapjes
becasse
  • http://becasse-weathering.blogspot.nl/
« Reactie #272 Gepost op: 10 May 2018, 17:15:04 »
Ok. Dan is er hoop!
Waar gaan we heen voor spoor 1?
becasse
« Reactie #273 Gepost op: 10 May 2018, 17:24:59 »
Beste Beneluxers,
Vandaag tussen de bedrijven door even aan het stoeien geweest met het maken van sluitseinhouders: uit een stuk T profiel de vrij forse arm gezaagd ( zijn ook vrij lang vanwege de overstek v/h dak), en dwars hierop een plaatje 0,5 mm gesoldeerd. Aan het uiteinde een viekant-holprofiel er op en klaar. Een sein ga je er niet inprikken, maar ik wil ook alleen op de bufferbalk 1 grote lamp per zijde.
Ome Frits doet het vast mooier, met schroefjes of zo, maar ik vind het wel ok voor een beginner...
@Edwin,welk deel op de plaat is gedacht voor de seinhouders op de bufferbalken??
@Frits; je hebt een pb.
Michiel
« Laatst bewerkt op: 10 May 2018, 17:37:12 door becasse »
    • nulpunt
« Reactie #274 Gepost op: 10 May 2018, 17:44:43 »
Hoi Michiel,
ik ben vanavond thuis...dakjes rollen dus.
Frits.
becasse
« Reactie #275 Gepost op: 10 May 2018, 17:48:33 »
A propos sluitseinen; de NS had zijn eigen daglicht-sluitseinen in allerlei bonte kleuren en vormen. Er stond ooit in een railmagazine (railhobby?) een artikeltje over de verschillende soorten. En nog in Maarn op het rangeeerterrein gefotografeerd!
Zou het niet leuk zijn een setje te etsen, en dan waterslides er op? Weet iemand afmetingen en meer info?
Michiel
becasse
« Reactie #276 Gepost op: 10 May 2018, 17:49:09 »
Hoi Michiel,
Frits.
Gezellie!
    • Raamsdonk spoor 0
« Reactie #277 Gepost op: 10 May 2018, 18:02:54 »
sorry, geen.
Ben in de 0 versie uitgegaan van de verkrijgbare philotrain lampen. (loklampen of sluitseinen), dan heb je geen seinhouder nodig. En anders, het is niet meer als een staafje...
    • nulpunt
« Reactie #278 Gepost op: 10 May 2018, 22:56:31 »
Wederom werkbespreking vanavond.
Nu hebben die andere twee Oersikken ook een rond dak en geklinknagelde regengoot.
Verder lekker ouwebeppen.
IMG_5271 by Nulpunt0, on Flickr
guest7822
« Reactie #279 Gepost op: 10 May 2018, 22:58:11 »
Hela, dan zou ik zo maar eens een bezoekje kunnen brengen aan Breda City (y)
Is dat trouwens een grote klus?
U bent welkom!
Walter
MB6400
« Reactie #280 Gepost op: 11 May 2018, 07:34:43 »
Jullie gaan echt als de brandweer  (y)
Welke diameter hebben de klinknagelkopjes als ze zijn ingeperst ?
    • nulpunt
« Reactie #281 Gepost op: 11 May 2018, 10:14:39 »
IMG_5273 by Nulpunt0, on Flickr
Ferry As
  • Spoor 1
« Reactie #282 Gepost op: 11 May 2018, 10:15:34 »
Frits,
Hartelijk dank voor de gastvrije ontvangst en de tips, tricks en onderdelen !  (y)
Was zeker een gezellige beppende avond.
Het rooster op de huif zit ondertusssen goed  ;)
Grt.
Ferry
    • nulpunt
« Reactie #283 Gepost op: 11 May 2018, 10:18:03 »
Zat je wel dwars hé.
Maar bij mij gaat ook lang niet alles in één keer hoor.
« Laatst bewerkt op: 11 May 2018, 10:22:50 door FritsT »
Ferry As
  • Spoor 1
« Reactie #284 Gepost op: 11 May 2018, 10:23:24 »
Eh, ja !
Viel het op ?  ;)
