Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Modules van Kees Gorter  (gelezen 108319 keer)
ca.gorter
    • Modeltrein spoor N
Re: Modules van Kees Gorter
« Reactie #375 Gepost op: 17 October 2021, 08:37:33 »
Hierbij mijn dank voor de leuke reacties.
Binnenkort weer meer bouwverslagen.
Kees
Jan1954
« Reactie #376 Gepost op: 17 October 2021, 09:00:51 »
Kees het ziet er altijd goed uit als ik hier op de site ben kijk ik altijd wel
Groetjes Jan
« Reactie #377 Gepost op: 17 October 2021, 09:47:39 »
Kees
Op de witte onderdelen zie ik een paar rode stippen.
Wat is het doel daarvan?
Te weten waar de onderdelen behoren te komen?
Ronald Visser
ca.gorter
« Reactie #378 Gepost op: 17 October 2021, 15:51:55 »
Ja, de stippen zijn voor de volgorde ( plaats ) te markeren.
Dat doe ik wel vaker. Zeker om de muurplaatjes in de hoeken met gelijke hoogte van de stenen lagen te krijgen.
Kees
ca.gorter
« Reactie #379 Gepost op: 22 October 2021, 20:17:49 »
Ik heb even wat minder tijd om te bouwen.
Ik ben alles weer aan het gereed maken voor de beurs in Lisse.
Zie ook :
https://forum.beneluxspoor.net/index.php?topic=99530.new#new
Kees
« Reactie #380 Gepost op: 22 October 2021, 20:54:08 »
Veel plezier, Kees!
ca.gorter
« Reactie #381 Gepost op: 24 October 2021, 20:51:13 »
Hoe het schilderen gaat.
Eerst het donkere houtwerk. En dan zit je er wel eens naast te kliederen.
Daarna het binnen deel. Ook hier gaat het wel eens mis.
Dus weer met donker en soms met wit totdat het naar wens is.
Het gaat om het resultaat, dus doe ik dat maar zo met een vaste hand.  :roll:
Kees
Anton Maris
  • Modelspoor is magisch
« Reactie #382 Gepost op: 24 October 2021, 21:04:00 »
Ziet er fraai uit Kees. Vaste hand is wel belangrijk. Zelf vind ik dit soort schilderwerk wel moeilijk om goed te doen. Vraag me af of eerst schilderen van de onderdelen, zoals hier de vakwerkbalken en de ondergrond, en dan pas op elkaar lijmen een optie kan zijn. Bij de HollandScale huisjes vind ik de kozijnen ook lastig te schilderen als het venster een andere kleur krijgt dan de rest van het kozijn. Dan zou het helpen als het losse onderdelen waren.
ca.gorter
« Reactie #383 Gepost op: 29 November 2021, 16:49:03 »
Het was al een tijdje erg stil!
Ik had geen zin om even met de hobby bezig te zijn.
Daar is nu gelukkig weer verandering in gekomen.
Ik zal nog even niet aan het laatste huisje werken maar aan een module dat al een tijd aan de beurt is.
Als de "Corona " regels het toelaten sta ik met mijn Engelse baantje in februari op de beurs in Alkmaar.
En deze keerlus module zal er dan zeker ook bij zijn.
Het module dat ik al in 2016 gemaakt had. Rails zit alleen met kleine spijkertjes vast.
De trein komt van de rechter kant en gaat rechtsaf bij de wissel.
Vooraan zit een diode stop, die met het omzetten van de rijrichting de trein verder ( naar rechts ) laat rijden.
De rails met strooisel vast lijmen, en gelijk de Diode stop wat aanpassen.
De rails zit vast en is met roestkleur geschilderd.
Natuurlijk daarna het loopvlak weer schoon gemaakt.
Zo gaat het ongeveer worden !
Ook dit is bij de Severn Valley Railway terug te vinden.
Deze halte heeft een " Pagode " wachtruimte wat bij de Great Western Railway vaker voor kwam.
Dit wachthuisje moet ik binnenkort nog gaan maken.
Ook mijn andere, laatste tijd, gemaakte huisjes komen waarschijnlijk ook op dit module te staan.
Plannen genoeg dus!
https://modeltrein-spoor-n.jouwweb.nl/engelse-modules/engels/module-northwood-halt
Kees
ca.gorter
« Reactie #384 Gepost op: 23 December 2021, 16:01:07 »
Verder met het mudule
De halte maken.
De halte opvullen.
Het landschap maken.
Schuiven met de huisjes voor de mooiste opstelling.
Gelijk de doorkijkjes plannen. De bomen denk ik er nog bij.
In het echt is het iets anders maar ik kan, met mijn beschikbare ruimte, het niet exact namaken.
Zowel achter de huisjes, als ook de heuvel voor de  huisjes, komen veel bomen.
Kees
  • NS tijdperk II(c)/III
    • Obdam in h0
« Reactie #385 Gepost op: 23 December 2021, 16:16:39 »
Het gaat om de sfeer Kees en die zit er zo te zien duidelijk in  (y)
Fotodijkje en fotodiorama
Obdam
ca.gorter
« Reactie #386 Gepost op: 23 December 2021, 19:58:27 »
Het halte gebouw moet ik ook nog gaan maken .
Zo gaat het worden, hoop ik.
Kees
    • Obdam in h0
« Reactie #387 Gepost op: 23 December 2021, 20:10:19 »
Jij bent bijzonder Kees, bij jou bieden in het verleden behaalde resultaten namelijk wél garanties voor de toekomst  ;)
Gaat zeker goedkomen  :)
Obdam
wpinkhof
    • Asse-Bad / Assche-les-Bains
« Reactie #388 Gepost op: 23 December 2021, 21:12:41 »
Dag Kees,
Welk type rails gebruik je, en heb je een plan van hoe je die leuke lus maakte ? Ik zit ook op zoiets te broeden.
Wouter Pinkhof
Verstuurd vanaf mijn Lenovo TB-X304F met Tapatalk
Jan D
« Reactie #389 Gepost op: 23 December 2021, 22:59:38 »
Dat wordt fraai Kees, ga het verder volgen. Benieuwd hoe het lijkt als de bomen er staan.
Groet Jan
