HS 4de klasse Staatsspoorstation door Sven
Vandaag om 01:15:06
Multimaus Zwart door Sven
Vandaag om 01:10:26
Ontraxs 2026 door Marty
Vandaag om 00:50:22
Vandaag om 00:36:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door borotof
Vandaag om 00:29:24
Houten Plus zaterdag 21 februari 2026 door p-kokkie
19 February 2026, 23:36:38
Vraagje over digitaliseren Hamo Motorpost door borotof
19 February 2026, 23:21:45
US diorama in H0 door Jelmer
19 February 2026, 22:45:52
19 February 2026, 22:26:14
Duitse/Belgische tegenhangers van Beneluxspoor/3railforum? door sncf231e
19 February 2026, 22:15:30
Aachenau West door Peter J K
19 February 2026, 21:58:27
Stub switches door Hans1963
19 February 2026, 21:54:31
Onlangs gespot - gefotografeerd, de foto's door Menno de Vries
19 February 2026, 21:24:50
Trein Eindhoven Brussel? door Hlv53
19 February 2026, 21:09:45
19 February 2026, 21:01:31
19 February 2026, 21:00:55
Fabrieksplaten NS E-lok 1600 en 1700 door Kees-Jan
19 February 2026, 20:52:45
PB Models, ICR-rijtuigen door De eerste Ivo
19 February 2026, 20:49:36
19 February 2026, 20:40:09
19 February 2026, 20:30:26
19 February 2026, 19:55:44
19 February 2026, 19:15:50
19 February 2026, 18:34:04
Vraagje over servo aansluiting door Joost O
19 February 2026, 17:19:49
Fleischmann 1898 set analoog>digitaal door Robert uut Salland
19 February 2026, 17:15:26
Cv instellingen Fleischmann Sprinter door 008200
19 February 2026, 17:08:22
19 February 2026, 17:01:54
19 February 2026, 16:47:17
H0e pizza layout door Sven
19 February 2026, 15:39:10
NSB 20b en 21b door Simplex
19 February 2026, 14:49:30
Auteur Topic: MARDEC, de Multifunctionele ARduino dcc DECoder.  (gelezen 418607 keer)
Fritsprt
Re: MARDEC, de Multifunctionele ARduino dcc DECoder.
« Reactie #420 Gepost op: 26 June 2016, 11:51:08 »
@Frits
Ja dat kan ook. Waar heb je die vandaan?
 ??? Ik had de link er in gezet. Bij deze de link nog eens (y) ;D
gr. Frits
« Laatst bewerkt op: 26 June 2016, 11:53:25 door Fritsprt »
Groet Frits
NTeering
    • ARduino Controlled MOdel RAilway
« Reactie #421 Gepost op: 26 June 2016, 12:10:24 »
@Frits
Ja stond er in. Over het hoofd gezien. :-\
jowi
« Reactie #422 Gepost op: 26 June 2016, 17:00:06 »
Ik begrijp die 2 adressen 1000 en 1001 niet.
Ik zie dat als ik adres 1000 selecteer mbv de multimaus, dat de mardec in configmode  raakt (als die in runtime mode is), en als ik tijdens runtime 1001 met de multimaus verander, worden de settings nog een keer gesaved. Ik begrijp niet waarom... is dit een dcc eis/feature die ik niet ken?
Waarom zou ik mbv een dcc commando de mardec's settings willen saven, en waarom zou ik via een dcc commando de configmode aan willen zetten, als ik daarna vervolgens met putty en toetsenbord verder moet voor de settings?
De settings worden toch ook gesaved zodra ik mbv Putty de configmode verlaat? Dat is toch voldoende?
Een hoop vragen ;)
NTeering
« Reactie #423 Gepost op: 26 June 2016, 23:23:05 »
@Jowi,
Maar al die vragen zijn al een aantal malen beantwoord in dit draadje.
Bij mij werkt het wel, verschil kan zitten in de hardware. Ik heb een originele uno
Maar kun je dan ook nog commando's ingeven?
Hoezo 'nog een keer'? Met adres 1000 wordt er NIETS gesaved. MARDEC wordt alleen maar in configmode herstart.
Dat was t/m versie 2.1 de enige methode. De 'C'-toets methode is pas in versie 2.2 toegevoegd.
Zelfde denkfout als bij Henk? Zie hiervoor. Het save-commando slaat GEEN Mardec instellingen op. Dat gebeurt ALLEEN in configmode. Het save commando (alleen in bedrijfsstand beschikbaar!) slaat alleen de toestand van de servo's en accessories op zoals ze op dat moment zijn. Dat is dus heel iets anders dan configuratie instellingen.
Voorbeeld: als een accessory type double steady voor een seinpaal een rood licht heeft op moment van 'saven' zal MARDEC bij een herstart in bedrijfstoestand dat sein ook weer op rood zetten.
Dat is nou precies je denkfout. Je verwart de toestand van een servo/accessory met z'n configuratie.
Toestanden worden verandert in bedrijfstoestand en instellingen worden verandert in configmode.
Bovendien is het niet juist dat de instellingen worden gesaved bij verlaten van de configmode. Dat heb ik hiervoor toch ook al aan Henk uitgelegd. Dat gebeurt per pin!
Nico
jowi
« Reactie #424 Gepost op: 27 June 2016, 00:27:19 »
Ik denk dat we een beetje langs elkaar praten. Ik begrijp niet waarom je daar een 2 tal dcc adressen voor nodig hebt... Dat gebruik van dcc adressen impliceert dat je dus ZELF actief dat commando moet geven (op adres 1001) bijv. met een multimaus? Of is dat iets wat je centrale automatisch doet als de spanning uit gaat ofzo? Is het deel van een dcc standaard die ik niet ken of waar ik geen weet van heb?
Ik heb de code nu aangepast zodat die 2 adressen niet gevraagd, gesaved en/of opgehaald worden, en ik merk geen verschil in werking... allles doet het nog prima.
NTeering
« Reactie #425 Gepost op: 27 June 2016, 08:54:00 »
Ja natuurlijk moet je die twee adressen zelf ingeven via dcc-centrale, handregelaar of computerprogramma. Hoe anders?
Heeft niets te maken met de dcc standaard. Het enige bijzondere is dat MARDEC die adressen voor zichzelf gereserveerd heeft en dus niet bruikbaar zijn voor servo's en accessory's.
Het 'save'-adres kun (moet niet!) je bijvoorbeeld gebruiken alvorens je baan af te sluiten.
Het 'config'-adres moest je t/m versie 2.1 gebruiken om naar configmode te gaan. Vanaf 2.2 kan dat ook met de 'C'-toets.
En natuurlijk werkt alles nog goed als je die adressen in MARDEC niet meer gebruikt. Er is immers geen noodzaak om ze te gebruiken. Alleen ontzeg je dan jezelf de functie van het 'save'-adres. Maar in plaats daarvan kun je ook in je computerprogramma een initialisatie procedure uitvoeren bij het opstarten van de baan. Het is een keuze.
Nico
« Laatst bewerkt op: 27 June 2016, 09:00:18 door NTeering »
jowi
« Reactie #426 Gepost op: 27 June 2016, 10:11:19 »
Ja precies... ik begrijp nu de gedachte er achter. Ik zou er zelf niet op deze manier voor gekozen hebben.
Het lijkt mij dan logischer, als je zou willen dat alles na uitzetten (of kortsluiting!) weer terug zou gaan naar de staat waar het vlak daarvoor was, om dan telkens als de status van een uitgang wordt veranderd, die meteen in de EEPROM op te slaan, en bij opstarten die status weer uit te lezen. Dat geeft dan wel veel meer EEPROM schrijfacties, en die dingen zijn 'beperkt houdbaar', er is een grens aan het aantal keren dat je er in kan schrijven ;) ik weet niet of dat dan wel zo'n goed idee is...
NTeering
« Reactie #427 Gepost op: 27 June 2016, 11:33:09 »
Uiteraard heb ik dat ook overwogen. Maar dat gaat wellicht inderdaad teveel schrijfacties kosten.
Daarom is er voor de 'save'-optie gekozen.
In configmode wordt er natuurlijk wel een hoop geschreven. Maar configureren is een eenmalige zaak en daarna ben je doorgaans alleen in bedrijfstoestand.
Nico
jowi
« Reactie #428 Gepost op: 27 June 2016, 23:09:28 »
Hoe dan ook, het is in ieder geval een mooi stukje werk (y)
AlbertG
    • Modelbaan Den Akker / Rocrail / DCC-EX
« Reactie #429 Gepost op: 29 June 2016, 18:38:48 »
Als leek op het gebied van elektronica een vraag: hoe sluit ik de servo's aan?
Moet ik daarvoor de stekker van de servo afknippen en de draadjes afzonderlijk vastsolderen?
In de handleiding wordt gesproken over Dupont kabels maar het is me niet duidelijk of deze voor de servo's gebruikt worden of alleen voor de analoge toepassingen (zie pagina 4 van de handleiding)
Alvast bedankt voor de reactie.
Albert.
Hartelijke groeten,
Albert.
Mijn Youtube kanaal: https://www.youtube.com/@Albert-DenAkker
jowi
« Reactie #430 Gepost op: 29 June 2016, 19:37:13 »
Ik vind dat ook wel een nadeeltje; ik zou bijv. heel graag het eerder getoonde shield/board willen zien met 3 polige stekkers voor de 1e 8 servo's, zodat je de servo's er direct op kan prikken, aangezien ik het ding 100% voor servo's met frogrelais wil gaan gebruiken, al die effect uitgangen heb ik niet zo'n behoefte aan in 1e instantie. Misschien ga ik zelf een poging wagen voor een dergelijk board, lijkt me ook wel eens leuk om te doen.
Fritsprt
« Reactie #431 Gepost op: 29 June 2016, 20:24:35 »
Je zou volgens mij de print van de AdServo van Timo Engelgeer kunnen toepassen. Daar kan je 8 servo's op 3 polige headers prikken/aansluiten. De uitgangen voor je relais moet je er dan zelf bij bastellen.
gr. Frits
« Laatst bewerkt op: 29 June 2016, 20:26:25 door Fritsprt »
Groet Frits
NTeering
« Reactie #432 Gepost op: 29 June 2016, 23:30:21 »
@AlbertG
Je sluit de servo's in principe geheel met Dupont kabels aan.
De servokabel verleng je met Dupont kabel. Doorgaans is de servokabel toch te kort om direct op de Arduino aan te sluiten
Van die verlengkabel steek je de signaaldraad in de Arduino en de voeding en gnd kun je aansluiten op een verdeelprint met Dupont stekkers:
(foto Henk Boshuyzen)
Het nadeel van deze methode is dat Dupont verbindingen niet zo betrouwbaar zijn. Na een tijdje gaan ze losser zitten.
Veel beter is dan het gebruik van schroefconnectors. Daar kun je prima een Dupont steker in vastklemmen. Zie foto's eerder in dit draadje.
Ook de verdeelplaat kun je beter voorzien van schroefconnectors. Die verbind je eenvoudig met de +5v en gnd van de dcc-print.
En het is inderdaad het beste als je de stekker van de servokabel af knipt en er een drie-aderige kabel aan soldeert en er krimpkous over doet. Het andere eind kun je vertinnen of er een Dupont steker aan solderen of aanklemmen met een speciale krimptang.
@Jowi
Om bovengenoemde reden ben ik geen voorstander van 3 pins connectors op de dcc-print. 8 Is te weinig als je 12 servo's wilt gebruiken.
En waarom dan ook niet 3 pins connectors voor de relaismodules? Die gebruiken immers ook 3-aderige Dupont kabel. Dat is 'discriminatie' ;D
Bovendien geeft het een hele spaghetti van draden.
Als je alleen maar accessory's aansluit heb je er niks aan.
@Frits
De print van de Adservo is niet geschikt omdat:
- Er een Pro Mini gebruikt wordt (Bootloader aanpassen is niet voor iedereen weggelegd)
- Er maar acht servo's op kunnen en geen accessory's
En omdat we niet willen 'bastelen' heeft Servé juist zo'n mooie print gemaakt.
De huidige print is prima geschikt. Er is ook niet echt ruimte voor 3 pins headers. De print zou dan weer bijna opnieuw ontworpen moeten worden.
Mvg
Nico
jowi
« Reactie #433 Gepost op: 30 June 2016, 06:26:24 »
Het is maar net hoe je het ding wilt inzetten. Ik ga alleen servo's met puntstukpolarisatie toepassen, dan zit ik aan 8 servo's max. + relais. Gezien de prijs van alles is dat prima... die wirwar van kabels valt denk ik wel mee, het alternatief met het verdeelprintje is alleen maar het verplaatsen van de kabelspaghetti :) relaisaansluiting had ik nog niet aan gedacht, goeie tip. Ik ga er mee aan de slag, uberhaupt erg leuk om te doen, een board ontwerpen! Misschien wordt het niks, zien we dan wel weer.
Er zijn overigens verlengkabels te koop voor de servo's. Al zijn die bijna net zo duur als een losse Arduino ;D
« Laatst bewerkt op: 30 June 2016, 08:08:15 door jowi »
AlbertG
« Reactie #434 Gepost op: 30 June 2016, 07:55:03 »
Bedankt voor de reacties. Ik heb servo verlengkabeltjes liggen. Dupont kabels zijn onderweg.
Albert.
Hartelijke groeten,
Albert.
