v140
om 11:59:43
Swird HO
Jeroen Vreeken
om 11:45:49
om 11:36:44
Bert V
om 11:21:45
Casmir
om 11:19:10
Botsing bij SGB 29-12-2025
v140
om 11:16:24
RikJ
om 11:09:43
Mehano ACTS 7102
om 10:50:18
Wandplanken, advies.
Martin Welberg
om 10:18:07
om 09:44:20
om 09:36:35
om 09:15:41
Luc2000
om 08:58:54
om 08:41:01
om 05:06:58
Noord-Hollandse Modelspoor Dagen 2026 - 28 februari & 1 maart
KoploperMau
25 February 2026, 23:16:48
25 February 2026, 22:24:31
Nieuw in de winkel!
25 February 2026, 20:47:23
25 February 2026, 19:57:09
AlbertG
25 February 2026, 19:51:57
VAM65
25 February 2026, 19:42:59
System-M
25 February 2026, 18:24:50
Zermitz
25 February 2026, 18:14:41
25 February 2026, 17:42:50
Casmir
25 February 2026, 17:09:16
BrauWelt, fantasiebaan in H0
Brouwersbaan
25 February 2026, 17:07:41
Anton Maris
25 February 2026, 16:54:55
25 February 2026, 16:18:29
25 February 2026, 14:17:04
25 February 2026, 13:41:42
Digitaal
MARDEC, de Multifunctionele ARduino dcc DECoder.
Topic: MARDEC, de Multifunctionele ARduino dcc DECoder. (gelezen 419930 keer)
Rien Ridderhof
Re: MARDEC, de Multifunctionele ARduino dcc DECoder.
Reactie #1425 Gepost op:
10 March 2020, 16:49:04 »
Nico, bedankt voor de tip het werkt perfect.
m.v.g
Rien
PrinzEugen
Nieuwe gebruiker
Reactie #1426 Gepost op:
12 March 2020, 08:12:15 »
hi, i have a problem with mardec.
when im using locomotive with esu loksound or acc.decoder with multiple funcions on diferent dcc address, mardec ddc Accessory not working (in this case servo)
mardec activates only when 2 functions are activated on esu decoder address. Does anyone has any clue ?
railcom is off. im using z21.
tnx.
Laatst bewerkt op: 12 March 2020, 13:58:53 door PrinzEugen
piksov
OpenDCC fan
Reactie #1427 Gepost op:
12 March 2020, 12:09:18 »
Hi Eugen,
Do you have railcom enabled?
OpenDCC fan
PrinzEugen
Nieuwe gebruiker
Reactie #1428 Gepost op:
12 March 2020, 14:01:36 »
railcom is off, sry it was mistypo.
when railcom is on, mardec not working at all.
pls, let someone try this with his locomotive (multiple functions enabled+ starting mardec dcc acc. ) maybe it is only case with mine mardec.
Laatst bewerkt op: 12 March 2020, 14:05:20 door PrinzEugen
MichelKuijpers
Reactie #1429 Gepost op:
22 April 2020, 22:05:59 »
Hoi Nico / andere Mardec gebruikers,
Ik gebruik Mardec (pin versie) onder modules van een clubbaan. Tijdens de laatste beurs hebben we onder de module met de laatste versie van Mardec best wat storingen gehad. Dit leek te liggen aan de gevoeligheid op de inputs, waarbij waarschijnlijk overspraak in de draden naar de Arduino voor high/low meldingen zorgde.
We hebben getest met en zonder externe pull-up weerstanden, dit gaf geen verbetering. Zowel niet als we deze dicht bij de Arduino plaatste en ook niet als we ze dicht bij de schakelaar plaatste (een relais in ons geval).
Zijn er andere die dit herkennen en zijn er wellicht tips hoe dit te voorkomen?
NTeering
Reactie #1430 Gepost op:
23 April 2020, 10:05:21 »
Hallo Michel,
Een extra pull-up weerstand komt parallel aan de interne pull-up weerstand van de Arduino. Daardoor wordt de totale weerstand verlaagd.
Wat wellicht wel helpt is een condensator van 100nF op de ingangspoorten van de Arduino. Hiermee kun je eventuele spikes afvangen die een valse laag/noog melding geven.
Mvg
Nico
More DCC fun with ARCOMORA
https://www.ARCOMORA.com
More Analog fun with ASAR
https://forum.beneluxspoor.net/index.php?topic=69109.msg3221654911#msg3221654911
MichelKuijpers
Reactie #1431 Gepost op:
23 April 2020, 10:27:08 »
Hoi Nico,
Dat van de weerstand had ik ook bedacht en hielp uiteraard ook niet. Een condensator toevoegen ga ik doen en mee testen.
Dank je wel!
Reactie #1432 Gepost op:
23 April 2020, 12:55:53 »
Zit er geen anti dender regeling in de SW?
Train-Science.com
Train-Science github
It ain't rocket science ;-)
NTeering
Reactie #1433 Gepost op:
23 April 2020, 13:29:21 »
Niet zoals in de ArLoco. Daar zit een instelbare 'wachttijd' in alvorens een niveauwissel 'erkend' wordt.
In Mardec zit alleen een wachttijd nadat er een niveauwissel 'gezien' is alvorens de betreffende poort opnieuw te scannen.
Zou wel beter zijn. Alleen weinig ruimte in de code om nog wat toe te voegen. Zeker als je het instelbaar wilt maken zoals in de ArLoco.
Op de Okkie zitten ook condensators om spikes af te vangen.
Mvg
Nico
Fritsprt
Reactie #1434 Gepost op:
23 April 2020, 20:47:40 »
Citaat van: MichelKuijpers op 22 April 2020, 22:05:59
Zit er over het relais wel een blusdiode?
gr. Frits
Groet Frits
MichelKuijpers
Reactie #1435 Gepost op:
24 April 2020, 09:37:30 »
Er zit een blusdiode over alle relais die we gebruiken, maar wel aan de spoelkant uiteraard en niet aan de schakelaar kant.
Reactie #1436 Gepost op:
11 June 2020, 09:18:39 »
@mardec gebruikers.
Ik heb een vraagje.
Ik heb zelf een DCC centrale gemaakt met een arduino en mijn eigen software. Het versturen van nieuwe instructies (herhaal ik 60x) gaat goed. Wat iets minder goed gaat is het herhalen van alle instructies. Ik deel eerst alle snelheids instructies uit, dan F1-F4 en als laatste F5-F8. Volgens het log van de centrale wordt wel alles in de correcte volgorde verstuurd zoals ik wil. Het versturen zelf heb ik ook debugged en lijkt kloppend. Maar er zit dus ergens nog iets fout.
Ik gebruik verder geen andere DCC artikelen behalve LoPi's, en heb daarom geen SW gemaakt om DCC signalen af te luisteren. Mijn analoge oscilloscoop is ook niet bruikbaar. Uiteraard zou ik het zelf kunnen, maar omdat de SW alleen de centrale moet snoopen en nooit een andere toepassing zal krijgen, wil ik er niet te veel tijd besteden aan het opnieuw uitvinden van het wiel... alweer :-D
Dus mijn vraag. Is de mardec SW uitgerust om ontvangen DCC instructies op het scherm te printen? En is de SW makkelijk wijzigbaar om instructies voor locomotieven te ontvangen?
Indien niet, zijn er simpele alternatieve arduino programma's te vinden?
Train-Science.com
Hans sprinter
Vriend van vlaflip
Reactie #1437 Gepost op:
11 June 2020, 09:38:05 »
Hoi Bas, probeer eens bij Rudy Boer de Arduino sniffer. Werkt redelijk goed en geeft een goed beeld van alles wat over de DCC bus loopt.
https://rudysmodelrailway.wordpress.com/software
Remember, Google is your friend!
Greetz, en success, Hans
Reactie #1438 Gepost op:
11 June 2020, 09:38:47 »
Dit forum is ook my friend
Train-Science.com
John van Staaijeren
DSD
Reactie #1439 Gepost op:
11 June 2020, 10:42:50 »
Als je de ArCoMoRa software installeert en dan de Upload Tool gebruikt, kun je ook de DCC Sniffer laden op de Arduino.
John
n-spoor, Intellibox / ESU ECoS / SPROG3 en Koploper / iTrain 5.x met ArCoMoRa DCCNext, Mardec, ArLoco / RoSoft MDD, L.Net s88SD16-n
Digitaal
