om 01:45:30
Speedbuild; "Switch'n Play"
om 00:21:32
Dienstregeling IC+
om 00:04:58
janw
08 February 2026, 23:58:41
08 February 2026, 23:48:37
08 February 2026, 23:31:24
08 February 2026, 23:10:23
Roco h0, NS 1200
Duikeend
08 February 2026, 23:08:56
08 February 2026, 23:02:49
Duikeend
08 February 2026, 22:53:13
Peter Kleton
08 February 2026, 22:51:24
08 February 2026, 22:44:04
08 February 2026, 22:15:59
Zermitz
08 February 2026, 22:03:50
08 February 2026, 21:30:36
Carl
08 February 2026, 21:26:30
08 February 2026, 21:17:44
08 February 2026, 21:14:26
08 February 2026, 20:57:44
WesleyMunnik
08 February 2026, 20:50:26
Miniature Holland
08 February 2026, 20:40:30
08 February 2026, 20:34:49
CityNightLine 1:1, 1:87, 1:160 en 1:120
08 February 2026, 19:56:09
BrauWelt, fantasiebaan in H0
Brouwersbaan
08 February 2026, 19:52:43
Vitrineplankje
08 February 2026, 19:50:10
08 February 2026, 19:49:35
Wohnzimmer AW werkrapporten
08 February 2026, 19:48:11
Drijfwerk bouten losmaken
08 February 2026, 19:07:42
nighttrain1
08 February 2026, 18:52:36
TonM
08 February 2026, 18:43:55
hoe rails schoonmaken met wasbenzine?
Topic: hoe rails schoonmaken met wasbenzine? (gelezen 27058 keer)
Chiel
02 November 2007, 16:53:51 »
hallo
ik ben van plan om dit weekend mijn rails schoon te gaan maken met wasbenzine. ik heb weet dat dit het beste te doen is met wasbenzine maar ik heb nergens op het forum gelezen hoe je dat nou precies moet aanpakken (het kan zijn dat ik er overheen heb gelezen)
Hebben jullie wat tips?
alvast bedankt
Chiel
Re: hoe rails schoonmaken met wasbenzine?
02 November 2007, 17:12:15 »
Een doekje om je vinger, druppeltje wasbenzine er op en poetsen maar.
Dat druppeltje moet je regelmatig herhalen want wasbenzine vervliegt nogal snel.
Wesley
NS tussen WO2 en deklassering
02 November 2007, 17:13:03 »
Kan het ook met terpentine, ja toch?
Wesley
If I had stayed for other people to make my tools and things for me, I had never made anything.
Spoor-0 & Spoor-1
02 November 2007, 17:51:49 »
Jahoor mag ook. After Shave gaat ook goed...
manuelspot
02 November 2007, 17:54:23 »
Daar zijn helemooi schoonmaakblokjes voor. Onder ander van Roco en Fleischmann. Beter is er volgens mij niet en makkelijker.
Manuel
Spaar ze allemaal.
02 November 2007, 19:15:28 »
Ik poets op deze manier met wasbenzine:
Toen ik nog "klein" was en alleen nog oude Lima rails had, heb ik dit in elkaar geprutst en een wonder geschiedde; de trein reed !
Het is gemaakt van een gesloopte walkman (die had je toen nog) en een Lima wagon.
Ik ben er nog steeds wel trots op dat zoiets simpels zo goed werkt, dus die moet ik gewoon even laten zien.
De schijf met de zeem draait als een jekko rond en rust door zijn eigen gewicht (is verzwaard) op de rails.
Stephan
Adieu
**Jelle**
02 November 2007, 20:51:15 »
Gewoon een doekje om je vinger, je vinger in de fles wasbenzine, even fles omkeren en daarna poetsen maar.
Ik ben eigenlijk nog aan het zoeken naar een mogelijkheid/ idee om de schoonmaakwagen van Fleischmann zo om te bouwen dat er een automatische wasbenzinetoevoer op de viltjes zit. Dan ben je helemaal binnen
NS, DDW, Edits booster, LocoNet met LbServer, besturing met eigen geschreven software in VB
02 November 2007, 21:42:48 »
Als de stukjes "poets" vast zitten, blijft het vuil er ook. Vol=vol. Vuil=vuil.
Voor mijn 0 baan (2 x 40 meter) heb ik een loc omgebouwd. In de onderzijde is een gat aangebracht waar een gewoon potloodgum in past. Zit helemaal los. Als de loc een rondje heeft gereden til ik de loc op en stop er een ander gummetje in. Het vuile gummetje wordt gereinigd met aceton/papier. Binnen 10 seconden weer brandschoon en klaar voor gebruik als de loc zijn rondje weer gereden heeft.
Dat doe ik een stuk of vijf rondjes en ga dan naar het andere spoor. Duurt dus ongeveer 10 minuutjes per keer.
Het gummetje is aan de zijden schuin gemaakt om niet op wissels te blijven hangen.
Sta je op een beurs zoals Europoor, dan moet je dit 3-4 x per dag doen.
Dat hebben we vorige week eens overgeslagen, maar na een uurtje kon je de loc er af halen want die deed het gewoonweg niet meer.
Afgelopen week kostte het me een avond en een
heel pakje
wattenstaafjes om de boel weer schoon te krijgen.
Mijn ervaring is dat wasbenzine goed werkt, maar aceton werkt beter. Alleen uitkijken dat je er niet mee op geverfde delen (ook de wielen zelf dus) komt.
Laatst bewerkt op: 02 November 2007, 21:44:29 door FritsT
Han Zijlstra
The Right Track, Your track!
02 November 2007, 22:02:50 »
wasbenzine etc is slecht voor je spullen. gewoon railgum gebruiken en iets harder poetsen.
Verder altijd met een railreiniger wagen rijden . Gewoon in je goedren trein opnemen.
Of als je luxer wil dan neem je LUX
02 November 2007, 22:28:32 »
Han,
wat is je reden dat wasbenzine slecht is en voor welke spullen bij welk gebruik.
Ik vind wasbenzine wel erg stiken en de walm blijft binnenshuis lang hangen. Aceton heeft dat vele malen minder.
Bert Snijder
02 November 2007, 23:07:25 »
Ik hoor niemand over SR24. Is dat uit?
GerritM
03 November 2007, 00:32:25 »
Aceton is wel heel gemeen spul, het tast vrijwel alle kunststoffen en verfsoorten aan. Ik zou m'n baan en materieel er niet aan wagen.
Groet Gerrit
H0, 2-rail DCC, Lenz
Railpassie
De laatste Trein stopt niet aan het perron......
03 November 2007, 01:28:21 »
Inderdaad,als je aceton gaat gebruiken,kun je binnen de korste keren je (kunstof bielzen) rails in de kliko gooien.
Het is idd grote rotzooi,en niet erg goed voor je lak.
Ik raad het iig niemand aan,je gaat toch ook geen zoutzuur op je messing modellen aanbrengen.....het reinigt wel.....
Laatst bewerkt op: 03 November 2007, 01:32:40 door Railpassie
Chiel
03 November 2007, 08:06:11 »
dus je kunt t ook met een gewoone potloodgum proberen?
bedankt voor de reacties tot zover
Chiel
Servé
Team encyclopedie
Niks kan tippen aan een E1700
03 November 2007, 15:18:17 »
ik doe het met de normale railreinigingsblok, daarna wikkel ik wat keukenpapier om mijn vinger, en ga nog een de hele baan af.
mijn roco-cleanwagen rijdt met een goederentrein mee, dus die poetst ook.
(als ie niet vuil is......)
NOCH heeft ook een soort borsteltjes in zijn assortiment, kun je onder alle voertuigen klemmen.
zal even zoeken naar een plaatje.
Servé
Laatst bewerkt op: 02 December 2007, 15:06:45 door servéDB
Vriendelijke groet, Servé.
