Vandaag om 00:27:57
Pantografen mDDM door System-M
Vandaag om 00:25:07
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Duikeend
Vandaag om 00:21:11
Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Heroplage Artitec Plan W? door Quinzeedied
27 January 2026, 23:12:25
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Minibaan Visserskaai H0 door Sven
27 January 2026, 18:11:17
Auteur Topic: BNLS-Werkspoor - Stalen Dg  (gelezen 129243 keer)
Huib
    • Magica Miniatura
Re: BNLS-Werkspoor - Stalen Dg
« Reactie #60 Gepost op: 15 October 2007, 15:39:47 »
In spoor nul moet er natuurlijk wel een compleet interieur met verlichting in  ;D
De binnenwandjes die in het H0 model dicht zijn, moeten dus open zijn en je hebt een plot nodig voor de complete vloer.
Grtn!
Huib
Buitenlust in 1:43,5 | professioneel prutser| www.prutsvlog.nl | www.magicaminiatura.com | instagram.com/magicaminiatura
    • sleutelspoor
« Reactie #61 Gepost op: 15 October 2007, 16:05:09 »
Zo zie je maar spoor O is toch anders dan Ho. Ga zo'n tankwagentje bestellen en dan kijken of we er iets moois van kunnen maken.
Gr. Gerco
Peter Korsten
« Reactie #62 Gepost op: 15 October 2007, 16:12:22 »
Punt 2 er staat naast jouw naam Administrator, betekent dat dat ik je dan anders moet benaderen dan normale leden  ??? of betekent dat, dat ik heeeel lief moet antwoorden omdat ik een beetje bang moet zijn voor een Admin ??? of bedoel je wat anders met wat er achter jouw naam staat ????
Nee, het betekent dat je bericht op een zogenaamd lollige toon geschreven was, waarmee je echter ook meteen de grens aan het opzoeken was van wat net wel en net niet kan. Als je de grens opzoekt, moet je ook niet verbaasd staan als je die vindt.
Wat betreft de inhoud, de opmerking dat je "in negen van de tien gevallen helemaal opnieuw moet beginnen" (dus zonder ook maar iets van de vorige tekening te gebruiken) slaat ook nergens op en je hebt die inderdaad ook genuanceerd.
Verder stel ik voor enige verdere discussie besloten te voeren, aangezien we wel erg van het onderwerp geraken.
- Peter
Huib
    • Magica Miniatura
« Reactie #63 Gepost op: 15 October 2007, 16:28:32 »
Gr. Gerco
Zo heb ik het gedaan bij de Pola Maxi's:
Verzaagd frame onder de kolenbak geplakt:
http://farm2.static.flickr.com/1107/687173602_8f11230687_o.jpg
De zijkanten afgewerkt met een strookje styreen
http://farm2.static.flickr.com/1245/686312633_d6cb6fef34.jpg
Met uiteindelijk dit resultaat:
http://farm2.static.flickr.com/1208/686314731_7fbb1367a7_o.jpg
Voor de Dg zou ik de delen van het frame naadloos tegen elkaar plakken op een basisplaat van styreen die gelijk de bodem van het karretje vormt. De opbouw kan daar met een aantal schroefjes (bijvoorbeeld vastgrijpend in hoekversterkingen) op worden vastgezet, zodat je altijd bij het interieur kunt.
Grtn!
Huib
« Laatst bewerkt op: 15 October 2007, 16:31:40 door Huib »
Marty
  • Het Achtergrondmannetje.nl
« Reactie #64 Gepost op: 15 October 2007, 16:40:36 »
@ Peter
Nee dank u, geen behoefte aan, als dit al jouw grens is. lijkt verdere discussie mij zeer overbodig.......
Gerco, was 1 mm niet te dik voor je machine?? dacht dat je een keer zoiets zei.
Is de noodzaak voor het uitfrezen van nog dikker styreen, je weet me te vinden  :)
Lijkt me wel leuk om me eens op een andere schaal te wagen
    • sleutelspoor
« Reactie #65 Gepost op: 15 October 2007, 16:57:15 »
Marty,
Twee keer 0,5 is ook 1 mm (heb je meteen de graveerlijnen aan de binnen en buitenkant)  en binnenkort ga ik eens kijken hoe het met 0,75 mm gaat  ;)
Gr. Gerco
Marty
« Reactie #66 Gepost op: 15 October 2007, 17:01:02 »
Heuhhh, daar heb ik niks tegenin te brengen  ;D
Ries
« Reactie #67 Gepost op: 15 October 2007, 17:09:52 »
Ik had tegen Gerco gezegd, nee, nee geen Dg 1:32 (nog niet), maar ja, als jij het echt wil Marty  ;), ik heb natuurlijk nog spoor 1 onderdelen genoeg liggen.
  ;D
« Laatst bewerkt op: 15 October 2007, 17:30:43 door Ries »
Huib
    • Magica Miniatura
« Reactie #68 Gepost op: 15 October 2007, 17:19:36 »
PS. vergeet niet dat rollend materieel bij de grote schalen een veel hoger gewicht moeten hebben dan in H0. Eigenlijk zou je de bodem dubbel moeten uitvoeren, zodat er een plak lood over de volle lengte en breedte van de wagen past (richtwaarde: 250 gram voor een twee-assige wagon). Een andere optie is om enkele kleinere plakken op elkaar onder de wagon tussen de stelbalken te plakken, maar da's minder mooi.
Grtn,
Huib
Ries
« Reactie #69 Gepost op: 15 October 2007, 17:25:29 »
Zijn "stalen" stoelen en tafels en een "gietijzeren" pot, misschien een idee voor het te plaatsen gewicht?
    • sleutelspoor
« Reactie #70 Gepost op: 15 October 2007, 17:30:24 »
Nu had ik hele mooie foto's van de Dg  bij Goes Borsele en je raad het al die stonden op een schijf die gecrashed is. Kan er misschien iemand foto's inclusief detailfoto's maken van een Dg bij een van onze musea.
Het idee is zich al aardig in mijn hoofd aan het vormen hoe te bouwn. De wanden gaan bestaan uit 3 lagen. Hierdoor krijg je een heel dun uiterlijk van de wand terwijl deze toch heel stevig is. Voorhet gewicht een dubbele bodem maken is natuurlijk geen probleem.
Gr. Gerco
    • sleutelspoor
« Reactie #71 Gepost op: 15 October 2007, 18:22:32 »
Ga ik wel doen-SK
nederbelg
  • Tijdperk IV, NS, vishaken en blauwe banen.
    • http://www.msvleuven.be/
« Reactie #72 Gepost op: 15 October 2007, 19:53:44 »
Beste,
Even een andere vraag tussendoor, is er van de Dg geen railhopper te maken of zijn dat verschillende type's?
dave
DCC, NS, Koploper, Loconet Tijdperk IV
Marty
« Reactie #73 Gepost op: 15 October 2007, 19:56:25 »
Huib, ik zat te denkne om de bodemplaat uit 2 mm dik aluminium of messing te frezen, maar ik vrees dat ik dan bij lange na nog steeds niet die 250 gram ga halen, red je dat wel met lood dan ??
Wordt een ferme dikke plak dan, of prop je ook nog wat in het dak ??
sneek
« Reactie #74 Gepost op: 15 October 2007, 20:21:16 »
Beste,
dave
je bedoeld waarschijnlijk een 'hothopper' zo'n Dg die op de Wgm stond als verwarmingswagen voor rijtuigen. Het ding staat nu in de STIBANS-loods opgeslagen. Zie http://picasaweb.google.nl/wimhoekema/20071013/photo#5120956469977543906
Waren er trouwens ook niet Dg's in grijze kleur als ontijzelwagen of ben ik daar mis mee en werden daar alleen ouwe goederenwagentjes voor gebruikt???
