Vandaag om 00:27:57
Pantografen mDDM door System-M
Vandaag om 00:25:07
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Duikeend
Vandaag om 00:21:11
Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Heroplage Artitec Plan W? door Quinzeedied
27 January 2026, 23:12:25
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Minibaan Visserskaai H0 door Sven
27 January 2026, 18:11:17
Auteur Topic: BNLS-Werkspoor - Stalen Dg  (gelezen 129242 keer)
Huib
    • Magica Miniatura
Re: BNLS-Werkspoor - Stalen Dg
« Reactie #75 Gepost op: 15 October 2007, 20:29:34 »
Huib, ik zat te denkne om de bodemplaat uit 2 mm dik aluminium of messing te frezen, maar ik vrees dat ik dan bij lange na nog steeds niet die 250 gram ga halen, red je dat wel met lood dan ??
Wordt een ferme dikke plak dan, of prop je ook nog wat in het dak ??
Ja, dat wordt nog een uitdaging. Nou is het niet zo'n ramp als het iets minder is, maar aangezien je met verende buffers en echte koppelingen werkt, plus het feit dat al het andere wel zwaar is, heb je wel wat gewicht nodig. Lood in de bodem zal bij een plastic model wellicht niet genoeg zijn. In dat geval toch ook maar tussen de draagbalken wegmoffelen. Alle beetje helpen.
Grtn!
Huib
Toevoeging: ik heb het e.e.a. op de weegschaal gezet. Plak lood ter grootte van het onderstel is circa 130 gram. Mijn plastic kolenbakken zijn zonder lood/lading 135 gram. Bij elkaar dus ruim voldoende om de 250 gram te halen. Een Dg met lood in de bodem wordt zwaar genoeg.
« Laatst bewerkt op: 15 October 2007, 20:54:26 door Huib »
Buitenlust in 1:43,5 | professioneel prutser| www.prutsvlog.nl | www.magicaminiatura.com | instagram.com/magicaminiatura
Ries
« Reactie #76 Gepost op: 15 October 2007, 20:41:34 »
Ja, er waren grijze Dg's ten behoeven van de ijzelbestrijding.
MR
« Reactie #77 Gepost op: 15 October 2007, 20:47:59 »
IJzelbestrijding? Hoe dan?
Marco
WillemNS
« Reactie #78 Gepost op: 15 October 2007, 20:57:56 »
Waarmee reden die DG's?
Ik ben van plan om er een aan te schaffen, maar ik heb geen idee waar ze mee reden.
Met een shimmns zullen ze wel niet gereden hebben :P
Moet ik dan denken aan GS en GBS'en?
En is het mogelijk dat je de DG ombouwt tot Hot Hopper? ;D
Willem
  • Nervensäge.
    • belse roestkraam
« Reactie #79 Gepost op: 15 October 2007, 21:00:51 »
dat kon in t echt toch ook? ;)
    • nulpunt
« Reactie #80 Gepost op: 15 October 2007, 21:02:24 »
Zit ik toch even niet op te letten!!!!! Spoor 0 ontwikkelingen zonder dat ik mijn (lange) neus er tegenaan had bemoeid. Helemaal goed.
Heren ga zo door.
Dat met die OSM onderstellen gaat prima. Daar het ik in het verleden al  wat messing kitjes betaalbaar mee gemaakt/geleverd.
Een enkele opmerking..... de aspotten. Die moet je wegvijlen en er een ander model op plakken.
In mijn "beginperiode spoor 0" heb ik op een Pola onderstel een kartonnen bovenbouw gemaakt. Nog wat styreen stripjes en onderdelen. Hekwerk van draad. Bij elkaar (net even gewogen): 175 gram. Zwaar zat, ontspoort nooit.
Ik denk dat ik wel mee doe als er iets moois gefreesd kan worden.
OSM ketelwagen die ik heb, kan altijd gesloopt worden.
« Laatst bewerkt op: 15 October 2007, 21:10:09 door FritsT »
CorvK
« Reactie #81 Gepost op: 15 October 2007, 21:24:11 »
Willem
Willem de Dg's waar het hier om gaat zijn omstreeks 1958 (sorry moet 1954 zijn) op de rails gekomen (de onderstellen hadden er toen vaak al vele jaren opzitten 8)). Dus als de GS en GBS die jij op het oog hebt ook omstreeks die tijd gebouwd zijn, kan dat kloppen.
Ik dacht dat de Dg's tot ongeveer '64-'65 als zodanig dienst hebben gedaan.
« Laatst bewerkt op: 15 October 2007, 21:53:15 door CorvK »
Mvrgr Cor, die de grote vergeler maar niks vind. N(s) in II & III- kwarts country style
sneek
« Reactie #82 Gepost op: 15 October 2007, 21:25:25 »
Marco
Met een speciale panto op het dakje met daaraan ipv een koolsleepstuk om stroom af te nemen een soort van schraapsleepstuk om de ijzel van de bovenleiding te krabben. Vroeger had je dat; strenge winters haha.
e_p
    • N U L S P O O R
« Reactie #83 Gepost op: 15 October 2007, 21:53:00 »
ik doe zeker mee in 0, (mocht het nog niet duidelijk zijn)OSM onderstel ligt al te wachten.
Aspotten, MK modelbouwstudio levert naast messing aspotten SS glijlager, HSM Ag2 glijlager  en NS W1 glijlager deze ook in resin. W1-en moeten erop?
Nu zouden de Dg's moeten worden uitgerust met bladblazers, blow-hoppers of zo.
groet,
e-p
nu ook een blog!
http://nulspoor.blogspot.com/
fasteagle
« Reactie #84 Gepost op: 15 October 2007, 21:56:34 »
 ;) In 0 doe ik ook absoluut mee, leuk!
Groet
Martin
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #85 Gepost op: 15 October 2007, 23:21:49 »
Citaat van: Ries
...Zal ook wel weer een aardig draadje worden nu, met (op een later tijdstip) inbouw van interieur, binnenverlichting en een slapende conducteur??? ...
Hmmm, een week later en er staat nota bene al een compleet ingericht 0 model op stapel  8) 8)
Grtzz,
Karst
Berend
  • Nieuwe gebruiker
« Reactie #86 Gepost op: 16 October 2007, 12:01:43 »
leuk dit initiatief! Ook ik doe graag mee voor een stalen Dg in Spoor 0. Ik heb toch al een OSM onderstel.
« Laatst bewerkt op: 16 October 2007, 12:08:08 door Berend »
    • sleutelspoor
« Reactie #87 Gepost op: 16 October 2007, 14:53:04 »
20 jaar geleden begonnen, maar helaas nooit verder gegaan :-[
SK
Karst Drenth
« Reactie #88 Gepost op: 17 October 2007, 23:40:14 »
10 dagen geleden begonnen en wel verder gegaan  ;D
en dat natuurlijk terwijl de 0 spoorders nog liggen te dromen van een stalen Dg in hun schaal ;)
De transfers er op en de zaak in de zijdematte blanke lak...
... en vervolgens de ruitenzetter gespeeld  :P
Volgende stap zijn de treeplanken met handgrepen/leuningen.
Is met de tekening van Sobat erbij niet meer zo heel lastig ;)
Wordt vervolgd.
Grtzz,
Karst
Noud
« Reactie #89 Gepost op: 18 October 2007, 00:20:08 »
Ik doe ook mee met een 0 model.
Noud
