Vandaag om 00:48:20
Vandaag om 00:42:51
Vandaag om 00:15:48
13 February 2026, 23:59:24
PB Models, ICR-rijtuigen door MarkSpoor
13 February 2026, 23:57:00
13 February 2026, 23:55:09
13 February 2026, 23:30:44
13 February 2026, 23:08:59
Spoorwegmuseum in zwaar weer door Ferdinand Bogman
13 February 2026, 23:07:10
13 February 2026, 23:03:50
13 February 2026, 22:58:20
13 February 2026, 22:49:17
Roco 63421, hoe kom ik bij de stroomafname lipjes? door Albert de Heer
13 February 2026, 22:38:18
PT Trains 2026 door Chris Westerduin
13 February 2026, 22:10:50
Stub switches door Frank 123
13 February 2026, 21:50:55
13 February 2026, 21:49:12
13 February 2026, 21:41:19
13 February 2026, 21:24:24
13 February 2026, 21:13:45
13 February 2026, 20:31:01
Euronight 295 samenstelling door EN446
13 February 2026, 20:29:30
13 February 2026, 20:05:35
RailBOX Accessoire Decoder RB4400 door Etsmodelspoor.nl / Modelspoorbaanwinkel.nl
13 February 2026, 19:47:25
13 February 2026, 19:33:16
US diorama in H0 door Eric B
13 February 2026, 19:23:39
13 February 2026, 19:19:59
13 February 2026, 18:55:31
13 February 2026, 18:32:55
13 February 2026, 18:19:53
13 February 2026, 17:47:25
Auteur Topic: Mehano class 66 van ERS versus de ESU class 77 van ECR.  (gelezen 17252 keer)
Bert van Gelder
Re:Mehano class 66 van ERS versus de ESU class 77 van ECR.
« Reactie #30 Gepost op: 28 November 2012, 09:19:17 »
Allen,
Dit draadje is per abuis verdwenen in de prullenbak, geen idee waarom! Gelukkig nog boven water te halen, en bij deze weer terug!
Gr, Bert
Marcel van der Plas
  • MRCE 500 1607
« Reactie #31 Gepost op: 28 November 2012, 18:25:24 »
Mooi zo :D.
Bedankt weer tot dusver !
Laat de reacties / vragen maar weer komen.
Marcel
Eenerspoor
  • D813 Groningen 1972-73 grijs verleden met karakter
    • MSC-Roden
« Reactie #32 Gepost op: 28 November 2012, 18:40:51 »
Dit draadje is ...... bij deze weer terug!
Blij mee! (y) :D
Henk
H0 2-rail met  iTrain, Yamorc 7001, Digikeijs, Rosoft, LocoNet.
Ronald81
    • M'n treinbaan...
« Reactie #33 Gepost op: 28 November 2012, 18:46:06 »
Heeft deze ESU ook van die fijne wisselsensoren? ;)
Marcel van der Plas
  • MRCE 500 1607
« Reactie #34 Gepost op: 28 November 2012, 19:12:29 »
Hallo Ronald,
Check het filmpje in post 1. Daar hoor je b eide modellen rijden met alle toeters en bellen :).
AdrieE
« Reactie #35 Gepost op: 24 February 2013, 21:48:16 »
Ik hoor ook dat de Esu Class 77 uit de wissel loopt i.v.m de afstanden van de wielflenzen.
Dan is mijn vraag rijd hij wel goed op Piko-A rails.
Groet Adrie
Marcel van der Plas
  • MRCE 500 1607
Re: Mehano class 66 van ERS versus de ESU class 77 van ECR.
« Reactie #36 Gepost op: 12 February 2014, 22:27:03 »
Vandaag even mijn CS II geïnstalleerd en  aangesloten. Gelijk maar mijn laatste aanwinst, de ESU CapTrain 6602.
Nu samen op film met de ECR Class 77 van Esu :D :
http://www.youtube.com/watch?v=CHiZczS5cEk
Goosebirdy
« Reactie #37 Gepost op: 14 February 2014, 08:34:47 »
Ziet er leuk uit Marcel; ik moet mijn ESU Class 66 (HGK) ook maar eens gaan laten roken.
Groet, Gijsbert | Verzamelaar van metname H0 modellen welke in NL rijden / gereden hebben | Bouwt aan "Gijswijk", meer een testbaantje met wat aankleding dan een serieuze baan
« Reactie #38 Gepost op: 14 February 2014, 12:16:10 »
Beetje late reactie op deze vraag. In de beschrijving op de ESU site lees ik dit:
Die Class 66/77 ist ein Hybrid-Modell, das mit einem Radsatzinnenmaß von 14,1 mm einen sicheren Betrieb auf Zwei- und Dreileitergleisen ermöglicht.
Ze hebben geprobeerd om een tussenweg te vinden tussen de standaard wielafstand voor 3-rail en voor 2-rail. Dat is echt een misser van ESU, want dat kan gewoon niet. Voor 2-rail moet die afstand minstens 14,4 mm zijn. Dus je moet zelf aan de slag om de wielen iets verder van elkaar te zetten.
« Reactie #39 Gepost op: 14 February 2014, 13:12:03 »
Al politie aan de deur geweest vanwege geluidsoverlast?   ;D
Ik vind het wel jammer dat die CapTrain qua kleuren veel te licht is. Wat dat betreft zijn de kleuren van Classix beter getroffen!
« Reactie #40 Gepost op: 14 February 2014, 15:16:37 »
Totaal niet mee eensch! Ik vind het een TOP uitvinding van ESU. Mijn CR6311 heeft inmiddels al ontsporingsvrij gereden op marklin K-rails en op Roco Geoline en oudere roco zonder enig probleem. Echt een uitkomst dit systeem  (y)
« Reactie #41 Gepost op: 14 February 2014, 16:38:18 »
Nou, Floris, jammer dan.
Als de NEM zegt dat de afstand minstens 14,4 mm moet zijn, dan is 14,1 gewoon fout.
En als het goed gaat op Geoline en andere Roco wissels, dan zegt dat iets over die wissels. Namelijk dat ze ook niet deugen.
« Reactie #42 Gepost op: 14 February 2014, 18:07:31 »
Niks uitvinding. Compromis. ;)
Gr, Ben.
Olivier77
« Reactie #43 Gepost op: 14 February 2014, 21:22:32 »
Een goede avond,
Hoe zit met de flenshoogte, want dat is het grote probleem.
Bij Marklin wissels en vooral kruiswissels zakken te lagen flenzen door de wissel en schommelt de lok of
wagon.
Ik kan U vele voorbeelden tonen. B Models voor  3 rail (lok 5515), LS Models voor 3  rail (wagons wielen voor Benelux wagons).
Mvg
Olivier
Digitale 3-rail, K-rails,
Eenerspoor
    • MSC-Roden
« Reactie #44 Gepost op: 15 February 2014, 14:39:31 »
Volgens mij was de vraag of deze loks goed rijdenop rails van Piko. :-\
MVg,
Henk
