Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
Minibaan Visserskaai H0 door HenkN
26 January 2026, 22:56:10
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Projekt 083-338  (gelezen 3900349 keer)
Re: Projekt 083-338
« Reactie #20025 Gepost op: 05 June 2020, 16:53:42 »
QED, zou ik willen zeggen
Re: Projekt 083-338
« Reactie #20026 Gepost op: 05 June 2020, 17:03:11 »
Maar:
F0v sluitsein achteruit
F0r sluitsein vooruit
Aux1 Frontsein vooruit
Aux2 Frontsein achteruit
Aux3 vrij
Aux4 niet aanwezig
De binnenverlichting is dus aangesloten op Aux4 die niet op de decoder aanwezig is. Ik bedoel, wel op de printplaat van de DE I (met bijbehorend pinnetje), maar niet op de decoder. Klopt dat of snap ik het toch niet?
Falkenberg
Re: Projekt 083-338
« Reactie #20027 Gepost op: 05 June 2020, 17:12:04 »
Klopt inderdaad
dimo1_dimo1
Re: Projekt 083-338
« Reactie #20028 Gepost op: 05 June 2020, 17:15:17 »
Een draadje van mtc21 pin 13 naar 4 zou dan eventueel uitkomst kunnen bieden
groeten,
Auke
Falkenberg
Re: Projekt 083-338
« Reactie #20029 Gepost op: 05 June 2020, 17:22:32 »
Maar niet getreurd. Zie de foto
Ter hoogte van de eerste coupé van rechts zie je drie soldeereilandjes midden op de printplaat. Daarvan zijn de middelste en als het goed is de linker met elkaar verbonden. Als je de verbinding doorsnijdt en in plaats daarvan de rechter met de middelste verbindt, zal de binnenverlichting op Aux3 hangen. (Hidden feature)
Re: Projekt 083-338
« Reactie #20030 Gepost op: 05 June 2020, 21:11:52 »
Kijk, soms is het heel simpel. Als je maar weet hoe.
Falkenberg
Re: Projekt 083-338
« Reactie #20031 Gepost op: 05 June 2020, 21:18:12 »
Mooi zo. Nou hup, die pupkes drin  :D
Re: Projekt 083-338
« Reactie #20032 Gepost op: 05 June 2020, 21:21:18 »
Inderdaad. en dan meteen even een beetje ouderen. Istie helemaal tiptop voor het eerstvolgende Fremotreffen  :)
Re: Projekt 083-338
« Reactie #20033 Gepost op: 06 June 2020, 23:01:54 »
Vandaag niet zo best aan tijd gehad maar:
daar komen de pupkes!
Echt druk in de trein wordt 't niet, maar met 17,3 mm onderlinge afstand wil dat ook niet zo goed.
Falkenberg
Re: Projekt 083-338
« Reactie #20034 Gepost op: 06 June 2020, 23:19:52 »
alles in het wit, essentiële beroepen zeker 8)
Re: Projekt 083-338
« Reactie #20035 Gepost op: 07 June 2020, 10:05:27 »
Ja, typistes, lantaarnopstekers, hondemeppers, voddenboeren, turfstekers en melkboeren. We moeten tenslotte wel een beetje epochaal blijven denken, nietwaar?
Re: Projekt 083-338
« Reactie #20036 Gepost op: 07 June 2020, 19:35:21 »
Even een testopstelling:
Eén van de conclusies is dat als je twee Preisertjes knus naast elkaar op een bankje wil hebben, dat dan beide Preisertjes wel wat aan gewicht en vooral omvang in moeten leveren. Sommige (eigenlijk de meeste) pupkes nemen zo'n hele tweepersoonsbankje voor zichzelf in beslag.
Enfin, eenmaal de kap erop zie je er sowieso niet zo heel veel van, dan moet je er al met de neus bovenop gaan staan om te kunnen zien hoe de ruimte is verdeeld.
Re: Projekt 083-338
« Reactie #20037 Gepost op: 07 June 2020, 21:57:19 »
Niet dat je er echt veel van terug ziet, maar dat wist ik van te voren. Met de interieurverlichting aan wordt het wel wat duidelijker, maar dan nog, je moet er echt met de neus bovenop zitten om wat te zien.
De Inquisiteur-Generaal van de Kerk der heilige Moederen brengt een werkbezoek aan Tjuchem, terwijl Oma Geurtje terugkeert van een bezoek aan Stad, waar ze bij de V&D een tweetal nieuwe directoires heeft aangeschaft:
Het lnummer 40 moet nog worden vervangen. Treinstel nummer 40 schijnt ergens in Limburg thuis te horen, nummer 39 is, als ik goed geïnformeerd ben, een Groninger DE I.
Boer Harms is vanwege zijn kiespijn door zijn tandarts verwezen naar het Academisch Ziekenhuis in Stad, waar zijn laatste verstandskies op vakkundige wijze is verwijderd. Schipper Henk Hero van de coaster Noordborg heeft in Stad het arbeidsbureau bezocht om te kijken of er niet een geschikte lichtmatroos in het bestand zat:
Geesje Huivers tenslotte keert huiswaarts na haar laatste praktijkexamen tandheelkunde. Uiteindelijk heeft ze, met veel pijn en moeite, de verstandskies die ze kreeg voorgeschoteld kunnen verwijderen.
« Laatst bewerkt op: 07 June 2020, 22:19:20 door 44 »
Gert van Opbroek
Re: Projekt 083-338
« Reactie #20038 Gepost op: 08 June 2020, 00:26:49 »
Mooi beschreven, de passagiers in de trein, gaat wel leven zo!
Ric
Re: Projekt 083-338
« Reactie #20039 Gepost op: 08 June 2020, 10:42:46 »
Jan heeft zijn kennissen kring weer aardig uitgebreid lees ik ;D
Grt. Ric
