Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Projekt 083-338  (gelezen 3902786 keer)
lokpaint
« Reactie #1545 Gepost op: 29 January 2013, 14:26:09 »
kom op, je kunt 'm in het duitse gewoon huren, helemaal voor jezelf:
http://www.ake-eisenbahntouristik.de/tee-rheingold/
fred
Nepper :(
Zelfs de uitzichtwagen is niet eens correct.
Bart
  • Schwarzburg-Neuffen-Bahn
« Reactie #1546 Gepost op: 29 January 2013, 15:11:32 »
De laatste opstelling spreekt mij zeer aan, Jan.
Basilicum
  • Prae-adviseur
    • Dönsdorfer Bauberichte
« Reactie #1547 Gepost op: 29 January 2013, 15:27:06 »
Mij ook.
Mogelijke, historische argumentatie: Vroeger liep de weg voor het huis langs, maar bij aanleg van de spoorlijn werd de weg omgelegd en loopt sindsdien achter het huis, om ruimte te maken voor de spoorlijn.
« Reactie #1548 Gepost op: 29 January 2013, 17:24:04 »
Ergens kan ik me daar ook wel in vinden, maar een praktisch probleem is, dat het woonhuis op die plek eigenlijk net niet past.
Zie onderstaande foto, het woonhuis wisselt dan van plaats met de schuur boven in beeld:
Maar vast staat er nog niks, dus m'n jasje kan nog alle kanten uit waaien  ;)
Jan
« Reactie #1549 Gepost op: 30 January 2013, 12:21:43 »
Het leukst vind ik toch het verzinnen van kleine verhaaltjes. Een kleine scene met een paar figuurtjes en wat toebehoren kan veel levendigheid op een modelbaan brengen, en het werkt natuurlijker dan zomaar wat Preisers her en der neer te poten.
”Ach, Guten Tag, Frau Brockejock! Sie haben heute ja tüchtig gearbeitet, wie ich sehe!“
„Moin, Herr Ammeräth! Ja, Sie sagten ja, es wurde allmählich Zeit, Rotkohl und Weißkohl muss geerntet werden.“
„Doch, aber das brauchen Sie doch nicht zu machen! Das ist ja viel zu schwer für Sie!“
„Sie halten mich doch nicht für ein altes Weib, oder? Soll ich Sauerkraut daraus machen?“
„Ja, bitte. Aber das nächste Mal überlassen Sie die Ernte mir! Ich bestehe darauf!“
Met één ander figuurtje en verder dezelfde dingen kun je het verhaaltje variëren:
“Hallo Frau Brockejock! Wie geht’s Ihnen denn?“
„Hallo Fräulein Willnitz! Mir geht’s ausgezeichnet, danke! Sieh mal hier, ich habe heute Nachmittag den Weiβkohl geerntet. Möchten Sie daβ ich daraus Sauerkraut mache?“
„Oh ja, gerne! Und den Rotkohl haben Sie auch hier… und was ist denn das, ein Korb voll Kartoffeln? Frau Brockejock, das sollten Sie doch nicht machen! Das ist viel zu schwere Arbeit für Sie! Das überlassen Sie besser den Gerhard, damit er nicht zu faul wird!“
Jan
« Laatst bewerkt op: 30 January 2013, 12:23:28 door 44 »
ANDREUS
« Reactie #1550 Gepost op: 30 January 2013, 14:22:49 »
was fur ein jockebrock die frau Brockejock
mechtig prechtig die story,
Andreus
« Reactie #1551 Gepost op: 30 January 2013, 22:54:39 »
Dankje, Andreus :D
Zei ik niet dat er een marktkraampje bij die bouwdoos zat?
Maar eens verzinnen wat ik daarmee moet....
Jan
tuurtje
« Reactie #1552 Gepost op: 30 January 2013, 23:15:00 »
uhhhh, vullen mit Rot- und WeißKohl, Kartoffelen, Gurken, Pflaumen, Himberen, Erdberen, Karotten (zou er nog een poes zijn die dikke snorharen heeft )  ;D ;D usw..
Arthur
« Reactie #1553 Gepost op: 30 January 2013, 23:34:36 »
Sie wollen Karotten?
Zwei Pfund einsfuffzig bitte
Martin Welberg
  • FYA !!!
  • OO. Organisatie OntraXS!
« Reactie #1554 Gepost op: 31 January 2013, 01:01:28 »
Huis op deplek van de schuur maar dan iets minder als een kwart slag gedraaid, ingang altijd gericht op den hof... ;)
en een beetje viezigheid mag ook wel  ;D
« Reactie #1555 Gepost op: 31 January 2013, 09:33:06 »
Ja, maar de plaats is beperkt, hier steekt het gebouw al buiten het dio:
Terwijl het aan de andere kant al haast de helling afzakt:
Ietsje meer naar de brede kant verschuiven geeft wel soelaas, maar dan wordt "den hof" wat aan de kleine kant:
De steunmuur in de spoorberm krijgt zo wel extra bestaansreden:
Beetje blijven schuiven en experimenteren nog. Komt vanzelf iets uit den busch.
Viezigheid komt nog, het dak moet ook nog een ander kleurtje krijgen.
Jan
Martin Welberg
  • FYA !!!
« Reactie #1556 Gepost op: 31 January 2013, 10:38:48 »
Jan, bedoelde eigenlijk dat de lange zijde van het pand langs de rail staat, grote schuur staat aardig, alleen een plekkie voor dat kleintje... ;)
« Reactie #1557 Gepost op: 31 January 2013, 10:59:03 »
Dan zou het zoiets als dit worden:
En dat kleintje... ach, ik ben wel getrouwd met een kleintje, maar niet met dat kleintje ;)
« Reactie #1558 Gepost op: 31 January 2013, 13:02:32 »
Een groot deel van de groente verdwijnt naar de kantine van Bw Lümmeln, een ander deel is voor eigen gebruik en wat over is kan Frau Brockejock op de markt verkopen. Zo kan ze haar kleine pensioentje een beetje aanvullen.
Basilicum
  • Prae-adviseur
« Reactie #1559 Gepost op: 31 January 2013, 20:18:34 »
De Rheingold-rijtuigen van twee bladzijden terug zijn in Dönsdorf gesignaleerd.
