Heroplage Artitec Plan W? door Peter J K
Vandaag om 01:10:07
Rondom Charlois door NS264
Vandaag om 00:40:06
Pantografen mDDM door Deetrein
Vandaag om 00:36:43
Vandaag om 00:27:57
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Duikeend
Vandaag om 00:21:11
Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Auteur Topic: Vraag over vervangmotor Lima-locomotief  (gelezen 13181 keer)
Re: Vraag over vervangmotor Lima-locomotief
« Reactie #15 Gepost op: 27 October 2025, 14:34:19 »
Oh das goed om te weten Gert!
« Reactie #16 Gepost op: 27 October 2025, 14:48:41 »
Is er een Mabuchi code voor 12 volt? Ik heb 300F (5,9 volt) 300-E (9 volt, al veel beter) en een onbekende met 300CA.
Break! Ik vind nog een Mabuchi met 300E voor 5,9 volt. Dit zegt dus niks  :'(
« Reactie #17 Gepost op: 27 October 2025, 15:11:51 »
@Arjen, ik heb in mijn voorraad, naar aanleiding van de opmerking van Bessel en Gert, 1 Mitsumi CD motor gevonden die veel rustiger loopt dan de rest. Zelfs rustiger dan het exemplaar waar 9 volt op staat. Dus dat kon er wel eens eentje zijn.
Als je er mee geholpen bent mag je hem van mij hebben tegen verzendkosten.
Mvg, Paul
  • Team Mitropa - OHMB
« Reactie #18 Gepost op: 27 October 2025, 15:13:09 »
Hier staat het voltage van de motortjes.
RETROBAHN A.G.
« Reactie #19 Gepost op: 27 October 2025, 15:14:44 »
Niet altijd, ik heb ook exemplaren waar dat niet staat. De Mitsumi en merkloze exemplaren
« Laatst bewerkt op: 27 October 2025, 15:23:53 door Pauldg »
gerhards
« Reactie #20 Gepost op: 27 October 2025, 15:57:25 »
beste  Arjan  kijk eens op   ( ebay.uk ) en type  vervang motor lima in en je komt van alles tegen   6 volt   12 vollt  en montage kits
Arjen52
  • Oude meuk in h0
« Reactie #21 Gepost op: 27 October 2025, 16:08:11 »
Bedankt, ga ik eens naar kijken  (y)
« Reactie #22 Gepost op: 27 October 2025, 16:15:45 »
Mijn aanbod nog gezien of overheen gelezen?
Rico [momfer]
« Reactie #23 Gepost op: 27 October 2025, 16:30:35 »
Vandaag motortjes binnengekregen uit China voor een dergelijke ombouw van Lima (en/of Hamo) ombouw:
Net getest met een 9V batterij, lopen stil en met een nette omloopsnelheid.
Type: RF-300C Micro 300 Motor
Spanning: DC 12V
toeren: 7200RPM
Asdikte: 2mm Shaft
Diameter 24,2mm
Hoogte: 12mm (!!) -> minder geschikt voor de CoCo bogies, dan is een 9mm beter!
Geleverd met een 10T tandwiel.
Om te voorkomen dat het een racemonster wordt, heb ik tandwielen besteld:
* gat 2mm, 7 tanden , modulus 0,5 (niet geschikt)
* gat 2mm, 8 tanden , modulus 0,5
Verder nog messing buisjes om het later aan te passen van 2,5mm naar 2mm
* OD 2.5 x ID 2mm**
**(aanpassen naar de maten van betreffende motor!!!)
« Laatst bewerkt op: 31 October 2025, 15:37:49 door Rico [momfer] »
Rico (momfer)
Bouwbeschrijving van mijn Kerstbaantje
Arjen52
  • Oude meuk in h0
« Reactie #24 Gepost op: 27 October 2025, 18:48:57 »
Inderdaad overheen gelezen, want tussen de berichten door lag ik onder de tafel om een nieuwe voedingskabel aan te leggen.
Maar bedankt voor het aanbod. Ik heb intussen bij die Engelse leverancier een kant en klare motor besteld. Gezien mijn eerdere ervaringen heb ik het idee dat ik daar mee uit de voeten kan, gezien mijn gebrek aan technische kwaliteiten.   ;D
Het is overigens mijn eerste bestelling na de Brexit, dus ik ben benieuwd hoe dat afgehandeld gaat worden.
« Reactie #25 Gepost op: 27 October 2025, 19:14:07 »
Ben benieuwd, ik heb sindsdien daar ook niks meer besteld. Ik ga mijn motortje dan maar in een oude Lima Hondekop zetten. Durfde het eerst niet aan omdat ik dacht dat het allemaal zes volt was. Viel dus mee.
Arjen52
  • Oude meuk in h0
« Reactie #26 Gepost op: 27 October 2025, 20:30:36 »
Dan ben ik benieuwd hoe die verbouwing verloopt.
De kans is groot dat ik er nog wat van opsteek.
« Reactie #27 Gepost op: 27 October 2025, 22:15:04 »
Het is niet zozeer technisch, maar mechanisch. Er moet een geschikte beugel of tussenring worden gefabriekt om de motor op zijn plek te houden en er is een rondsel nodig met 8 tanden , moduul 0,5, boorgat 2mm. Het rondsel van het oorspronkelijke anker hergebruiken lijkt mij niet ideaal
Arjen52
  • Oude meuk in h0
« Reactie #28 Gepost op: 27 October 2025, 22:52:56 »
Bij dat motortje dat ik in Houten gekocht had zat een strook plakschuim (leek op isolatieband, maar dan veel compacter) als opvulling.
Het rondsel zat al op de as, maar was te breed waardoor het niet volledig in de behuizing past.
Bij de Lima-motoren moet de as nog uit het rondsel steken en het lukt mij niet om het tandwiel verder op de as te drukken. En door gebrek aan goed gereedschap ben ik er maar mee gestopt.
« Reactie #29 Gepost op: 28 October 2025, 09:13:24 »
Niet helemaal plug and play dus....
Je zal voor de mijne nog even geduld moeten hebben. Ik had geen enkel kunststof rondsel meer met het correcte aantal tanden dus er is een zakje onderweg uit China  :)
