Pantografen mDDM door Biesje
Vandaag om 02:27:32
Heroplage Artitec Plan W? door Peter J K
Vandaag om 01:10:07
Rondom Charlois door NS264
Vandaag om 00:40:06
Vandaag om 00:27:57
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Duikeend
Vandaag om 00:21:11
Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Auteur Topic: Vraag over vervangmotor Lima-locomotief  (gelezen 13244 keer)
Rico [momfer]
Re: Vraag over vervangmotor Lima-locomotief
« Reactie #30 Gepost op: 28 October 2025, 10:01:56 »
Als je beschikt over (of iemand kent met) een 3D printer, dan heeft thingiverse diverse downloads beschikbaar voor een rondsel/adapterring:
https://www.thingiverse.com/thing:7055715
https://www.thingiverse.com/thing:4816903
https://www.thingiverse.com/thing:4785324
https://www.thingiverse.com/thing:5100414
En er zijn er vast nog wel meer te vinden, waarvan er vast 1 passend is voor het onderhanden draaistel met aandrijving.
Rico (momfer)
Bouwbeschrijving van mijn Kerstbaantje
« Reactie #31 Gepost op: 28 October 2025, 10:06:35 »
Ik had zoiets ook gezien bij de Britse Ebay verkoper. Mooie plug and play oplossing. Ik heb zelf geen 3D printer, maar ik denk dat ik een nette beugel kan fabriceren. Een oplossing met een rol tape vind ik zelf om te huilen. Het moet goed gecentreerd zitten
Gert Arkema
  • Rhenopa / Bruggen-IG:
    • Team Mitropa
« Reactie #32 Gepost op: 28 October 2025, 13:03:15 »
Bij mijn exemplaar heb ik enkel het anker verwijderd en het motortje in de ringmagneet geschoven. Paste prima.
groet Gert
« Reactie #33 Gepost op: 28 October 2025, 13:06:14 »
Heeft het nieuwe motortje geen last van die magneet? Je verandert het veld natuurlijk. Ik kan mij voorstellen dat het meer ankerkleef oplevert
« Reactie #34 Gepost op: 28 October 2025, 13:45:46 »
Van die grijze tweecomponentenlijm werkt ook goed.
Wil uit ZO drenthe
« Reactie #35 Gepost op: 28 October 2025, 15:47:21 »
De magneet moet eruit. Je kunt de open ruimte opvullen met van alles, resten van een gietraam van een plastic bouwpakket, afgesneden stukken van een plastic muurplug, stukken hout, etc, als je het maar vastlijmt met twee componenten lijm of bison montage kit en er goed oplet, dat de motor in het midden zit.
Maar er is een klein probleem en dat is het plastic tandwieltje. Dat kan gaan slippen op de as Dat is bij mij gebeurt bij mijn met Mastica zijwanden omgebouwde Lima Hondenkop. De trein stond stil terwijl de motor draaide.
Het plastic tandwieltje zat vrij los op de as.
Ik heb toen het tandwieltje verwijderd en er een beetje bison montage kit in het tand wieltje gedaan en het tandwieltje weer op de as geschoven.
Sindsdien rijd de trein weer goed.
Ik zou er wel een diode schakeling in een van de aansluit draden plaatsen, want die motortjes draaien vrij snel.
Ik heb er een in mijn gele Lima 1314 geplaatst en met de analoge trafo vol open kantelde de locomotief in een bocht.
(Dat gebeurde op de vliering en de locomotief viel 2,5 meter naar beneden op de overloop.  :-[ Ik heb hem kunnen repareren. ;D )
Met zes diodes, drie voor de ene stroomrichting en drie voor de andere stroom richting blijft de locomotief netjes rijden in de bochten op volle kracht.
Het voordeel van zo'n motortje is, dat het minder lawaai maakt en dat het onderhoudsvrij is.
Wil
« Reactie #36 Gepost op: 28 October 2025, 15:58:39 »
Wat ik vaak hoor is dat het oorspronkelijke tandwiel van het anker wordt gezaagd en het dikteverschil wordt opgelost met een stukje krimpkous. Lijkt mij niet ideaal. Het zit niet gecentreerd en dus ook niet goed vast. Gewoon een nieuw rondsel met een boorgat van de juiste diameter. Een zakje vol kost 1,49 op Ali
Menno
    • Mijn van-alles website
« Reactie #37 Gepost op: 28 October 2025, 17:31:15 »
Nee, want dat veld komt de motorbehuizing niet binnen omdat dat een gesloten, metalen behuizing is.
Zelf heb ik de magneet met een plaatboor (het spijt me, ik heb het zo geleerd, veel anderen noemen het een stappenboor) opgeruimd naar de diameter van het motortje. Daarna past de motor er mooi bijna klemvast in (hij blijft in ieder geval op z'n plek) en hoef je alleen nog maar een beugeltje te maken om 'm in het motorhuis te houden met magneet en al.
Arjen52
  • Oude meuk in h0
« Reactie #38 Gepost op: 06 November 2025, 19:18:29 »
Zoals eerder gemeld heb ik toch maar een ombouwset in Engeland gekocht.
Na anderhalve week werd het bezorgd door de postbode, zonder enige problemen en toestanden, zoals importheffingen e.d.
Dit motortje is, op wat soldeerwerk na, plug-and-play.
Albert de Heer
« Reactie #39 Gepost op: 07 November 2025, 19:15:54 »
En loopt ie nu mooi?
Arjen52
  • Oude meuk in h0
« Reactie #40 Gepost op: 07 November 2025, 22:38:38 »
Ik heb nog geen tijd gehad voor de montage.
« Laatst bewerkt op: 10 November 2025, 16:02:13 door Arjen52 »
Arjen52
  • Oude meuk in h0
« Reactie #41 Gepost op: 10 November 2025, 14:40:13 »
Vanochtend gelegenheid gehad om het motortje in te bouwen. Dat ging zonder problemen. In een kwartiertje gedaan.
Het resultaat is overweldigend  ;),  want de loc was nu té enthousiast. Dat heb ik middels een set diodes weten te temperen.
Het probleem van te hard rijden zou je ook kunnen oplossen door de trafo lager te zetten, maar omdat meerdere locs (na elkaar) gebruik maken van de sector die door de trafo wordt bediend,  gaan die locs te langzaam.
Voor de goede orde, ik rij analoog.
« Laatst bewerkt op: 10 November 2025, 16:03:35 door Arjen52 »
Albert de Heer
« Reactie #42 Gepost op: 30 November 2025, 20:58:18 »
Ik zie je laatste post nu pas....
Die motortjes zijn er volgens mij in meerdere types, ik bedoel voor 6,9 of 12Volt. Misschien heb jij een 6Volt exemplaar?
Het motortje lijkt trouwens ook erg veel op een standaard RF300 motortje. Ik kan niet zien hoe dik jouw motortje is. De RF300 is vrij dik, wellicht te dik voor een draaistel. Ik heb ooit eens een RF300 in een Fleischmann O&K diesellocje gebouwd. Het ding stond bij stroom onderbreking pas na 25cm stil. Was eigenlijk best een succes!
Arjen52
  • Oude meuk in h0
« Reactie #43 Gepost op: 30 November 2025, 22:20:24 »
Ik heb geen idee voor hoeveel Volt dit motortje gebouwd is. In mijn naïviteit ga ik ervan uit dat het motortje, dat als vervanging voor de oorspronkelijke Lima-motor wordt verkocht, ook ergens tussen de 12 en 16 Volt nodig heeft.
De Fleischmann-trafo levert maximaal 14V DC.
Maar jouw opmerking over de O&K-loc brengt mij wel op een idee. Ik heb het op mijn to-do-lijst gezet.
janw
  • Bruggen-IG:
« Reactie #44 Gepost op: 01 December 2025, 01:07:52 »
Ha Arjen,
Ik ben heel benieuwd naar je ervaringen met de trekkracht van deze vervangingsmotoren.  Ik heb iets dergelijks als waar dit draadje over gaat geprobeerd met een motor van Ali (met hetzelde uiterlijk maar met een toerental van 2400 rpm) en vond dat die zeer geschikt zijn voor treinstellen van 1 - max 4 wagens, maar niet voor meer. Voor een loc waarmee je treinen van 5 of meer rijtuigen wil trekken, moet de motor wel wat kunnen leveren.
Heel benieuwd om te horen of deze vervangingsmotor dat kan!
