Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Reinier Z.
27 January 2026, 23:58:17
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Heroplage Artitec Plan W? door Quinzeedied
27 January 2026, 23:12:25
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Faller 2026 door Scratchbuilt
27 January 2026, 20:47:14
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
27 January 2026, 18:28:47
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Minibaan Visserskaai H0 door Sven
27 January 2026, 18:11:17
Bouw graafmachine Artitec. door Herb73
27 January 2026, 18:10:14
Auteur Topic: Herstellen ramen mastica bus na spuiten met matte lak  (gelezen 4059 keer)
  • NS tijdperk II(c)/III
    • Obdam in h0
« Gepost op: 23 January 2023, 21:03:30 »
Uit de onderdelenvoorraad van mijn zwager alle delen voor de bouw van een Mastica streekbus gekregen. Model in elkaar gezet, van een kleurtje voorzien en decals van busmodel.nl aangebracht. Ter afwerking met matte blanke lak bespoten ... en toen waren de ramen iets minder doorzichtig dan daarvoor.
Van te voren nooit bedacht dat dit het effect zou zijn. Als iemand een tip heeft hoe de ramen eenvoudig weer doorzichtige te krijgen, dan houd ik me aanbevolen.
Martijn
Moderator-opmerking: draadje afgesplitst, oorspronkelijke bericht staat hierboven.
Makkelijkste oplossing ... de bus in een winter diorama gebruiken  ;D
Botte oplossing, de bus in de Dasty mikken en alles er afweken, maar dat ben je al het werk; en de decals kwijt.
Subtiele oplossing, raam voor raam voorzichtig poetsen met een wattenstaafje en wasbenzine.
« Laatst bewerkt op: 27 January 2023, 10:09:43 door Reinout van Rees. Reden: Afsplitsing aangegeven »
Fotodijkje en fotodiorama
Obdam
martijnhaman
Re: Herstellen ramen mastica bus na spuiten met matte lak
« Reactie #1 Gepost op: 23 January 2023, 21:07:17 »
De Dasty gaat het niet worden.
Zou een laag transparante hooglans verf op de ramen een optie zijn? Lijkt me wat eenvoudiger uit te voeren dan de methode met het wattenstaafje.
Martijn
    • Obdam in h0
« Reactie #2 Gepost op: 23 January 2023, 21:11:30 »
Je bedoelt over de matte blanke lak weer glanslak spuiten?
Testen, neem een stukje transparant en spuit eerst mat en dan glans erover ...
Obdam
DJV
« Reactie #3 Gepost op: 23 January 2023, 22:16:42 »
Martijn
BRRRR krijg het er koud van.. ;D
Groeten Dirk Jan
V100 "manusje van alles".
« Reactie #4 Gepost op: 23 January 2023, 23:41:36 »
Ik wil wel kijken of ik nog Mastica ramen heb voor je....  :angel:
Ronald Visser
  • Modelspoor is emotie...
« Reactie #5 Gepost op: 24 January 2023, 11:22:33 »
Martijn, op wat voor basis was die blanke lak? Je zou kunnen proberen om met een wattenstaafje, gedoopt in wasbenzine of alcohol wat te gaan poetsen. Benieuwd wat het resultaat dan is…
Rob
Tbinnebarretije…
HuubvG
« Reactie #6 Gepost op: 24 January 2023, 12:58:42 »
In hoeverre is de bus demontabel, ofwel kunnen de ruiten eruit? Als dat kon had je het wellicht al gedaan vóór het spuiten neem ik aan. Anders nieuwe ruiten erin. Het is allemaal vlak glas / niet gebogen, maar wel ingelegd zeker? Dat zal nog niet meevallen.
Blanke lak erover, ik denk dat je dan de bobbels nog beter ziet omdat het glanst. Lijkt een geval van 'onoplosbaar' en dus wel passend in dit topic.  :'(
« Laatst bewerkt op: 27 January 2023, 13:41:22 door HuubvG. Reden: opmerking t.b.v. ander draadje verwijderd »
Carel Ruysink
« Reactie #7 Gepost op: 24 January 2023, 13:36:19 »
Heb ook wel eens geprobeerd om ramen van een blokkendoos waar ik onnadenkend matte lak op had gespoten te redden met hoogglans blanke lak. Werd alleen maar erger bij mij.
Wat wel werkt? moet ik nog steeds uitzoeken.  :(
Carel
martijnhaman
« Reactie #8 Gepost op: 24 January 2023, 13:40:44 »
@HuubG: de zijwanden van de bus bestaan uit twee delen. De onderzijde is van geel plastic, de bovenzijde transparant plastic. De zilveren strip onder de ramen is de bovenzijde van het gele plastic. Op de foto in deze bijdrage is dat goed te zien: https://forum.beneluxspoor.net/index.php?topic=53347.0
Het vervangen van ramen zoals MOVisser suggereert is dan ook niet mogelijk.
@Rob Ellerman: Ik zal thuis eens kijken wat de precieze basis is voor de lak, maar het gaat om deze spuitbus matte blanke lak: https://www.action.com/nl-nl/p/spectrum-blanke-lak-spuitverf3/
Ik ga vanavond eens een proefstukje met de matte lak bespuiten en wat van de voorgestelde oplossingen daarop uitproberen.
Martijn
« Laatst bewerkt op: 24 January 2023, 13:55:19 door martijnhaman »
spoorzeven
« Reactie #9 Gepost op: 24 January 2023, 16:28:00 »
Kan zijn dat ik mij vergis, maar was er niet een serie van deze standaard streekbussen met donker getinte ramen? Is dat misschien nog een (laatste) redmiddel.
Groet, Frank
Christoph
    • Zwetdorf in model
« Reactie #10 Gepost op: 25 January 2023, 22:10:30 »
Ik zou zeggen, laat deze bus zo en maak je modelspoorbaan in een regenachtig uiterlijk. Deze bussen zijn volledig naar waarheid in te zetten met beslagen ramen.
Groeten en sterkte met schoonmaken,
Christoph
« Reactie #11 Gepost op: 25 January 2023, 22:50:42 »
Vervangen van de ramen kan altijd.
Ik weet hoe ze in elkaar steken, want ik heb er nog een paar bouwpakketjes liggen.
Ronald Visser
Duikeend
« Reactie #12 Gepost op: 26 January 2023, 00:24:38 »
toch niet hoor.. het is zoals Martijn zegt. de ramen zijn samen met de spijlen etc 1 gietstuk
ouch! die zooi van de action hecht helaas heel goed! het is een acryl lak maar niet op waterbasis.
Ik denk dat je het beste uit bent met nieuwe zijwand deeltjes te zoeken, uit te huilen en opnieuw te beginnen.
Jammer want hij staat wel netjes in elkaar.
« Laatst bewerkt op: 26 January 2023, 00:28:23 door Duikeend »
Groetjes, Ferenc
hondekop
« Reactie #13 Gepost op: 26 January 2023, 09:14:20 »
Ik geef toch exact hetzelfde aan??
Ronald Visser
Duikeend
« Reactie #14 Gepost op: 26 January 2023, 09:20:56 »
Misschien bedoel je hetzelfde maar komt dan niet zo over ;)
Jij zegt de ramen vervangen maar dat betekend in werkelijkheid het hele ding slopen,
weer opnieuw in elkaar zetten en weer lakken. dat is wat anders dan er nieuwe ramen in zetten  ;)
Groetjes, Ferenc
hondekop
