Vandaag om 00:15:46
03 February 2026, 23:52:50
03 February 2026, 23:23:21
19 Toen door Ferdinand Bogman
03 February 2026, 22:54:50
03 February 2026, 22:53:27
03 February 2026, 22:51:05
Bahnstrecke 5867 door Jelmer
03 February 2026, 22:38:45
03 February 2026, 22:34:39
Modelbaan in schaal TT omgeving Veluwe te bezoeken? door tothebeach
03 February 2026, 22:32:08
03 February 2026, 22:23:43
Stub switches door Frank 123
03 February 2026, 21:54:07
03 February 2026, 21:52:47
03 February 2026, 21:46:39
Toon hier je nieuwe (model-) spooraanwinst(en)... door Arjen52
03 February 2026, 21:45:35
03 February 2026, 21:18:19
Zoek site ombouw lokomotieven door Scratchbuilt
03 February 2026, 20:59:07
03 February 2026, 20:23:28
Rijnstraat door Sven
03 February 2026, 20:10:34
Exact-train 2026 door VAM65
03 February 2026, 20:09:59
Fotowedstrijd 2025 door Frank 123
03 February 2026, 20:02:50
03 February 2026, 19:37:34
03 February 2026, 19:28:42
03 February 2026, 19:28:36
03 February 2026, 19:12:23
03 February 2026, 18:47:07
03 February 2026, 18:33:38
Zermitz door maartenvdb
03 February 2026, 18:30:38
03 February 2026, 18:09:15
03 February 2026, 18:04:47
03 February 2026, 17:49:20
Auteur Topic: Am Ende der Strecke, modulebaan op 1 M2  (gelezen 306356 keer)
Re: Am Ende der Strecke, modulebaan op 1 M2
« Reactie #1425 Gepost op: 10 December 2024, 20:43:18 »
Dat is één, met nieuwe servo en 0,8 mm verenstaal uit de RC 🚙 ✈️ winkel 1 van de 3 wissels aan de praat gekregen.
Nu de andere 2 nog.
Am Ende der Strecke
Den gamla sågverket (gepland)
« Reactie #1426 Gepost op: 10 December 2024, 22:15:20 »
 (y) Prachtig wissel zo
Pfarrerwinkel de bouw:
Pfarrerwinkel
  • Eens komt het goed.
    • MIL MOD
« Reactie #1427 Gepost op: 10 December 2024, 22:31:14 »
Geweldig!
Het is net echt  (y)
DJV
« Reactie #1428 Gepost op: 10 December 2024, 23:12:28 »
Oooh gaaf Frank!! :o :o
Groeten Dirk Jan
V100 "manusje van alles".
  • Wir bauen fur Sie!! 🇦🇹
  • Bahnfahren ist ÖBB !!! 🇦🇹
« Reactie #1429 Gepost op: 10 December 2024, 23:24:04 »
Tja Frank,hoe mooi wil je het hebben of maken. (y) (y)
Gr Chris
« Reactie #1430 Gepost op: 11 December 2024, 06:29:33 »
Bedankt heren, is maar klein baantje dus wel de bedoeling dat hij beetje toonbaar wordt.
Am Ende der Strecke
« Reactie #1431 Gepost op: 13 December 2024, 18:08:07 »
Grrr 🤬 wissel naar schaduwstation kapot. Zo te zien niet meer te herstellen.
Wordt dus groot deel van de laatste modules slopen om er een nieuwe in te maken.
Hoop extra werk waar ik eigenlijk geen tijd voor heb….. even tot 10 tellen, uithuilen en opnieuw beginnen.
Am Ende der Strecke
« Reactie #1432 Gepost op: 13 December 2024, 19:40:30 »
Omdat slopen altijd nog kan eerst maar reparatie proberen. Stelbalk die kapot is zelfde die in de normale wissels zit en daar heb ik er nog genoeg van liggen.
Dus kapotte stelbalk er uit, dat was nog wel te doen
Kapotte en hele stelbalk naast elkaar
De “handjes” aan het einde van de stelbalk zijn voor de Roco magneet-aandrijving. Die gaat er dus in iedergeval aan 1 kant af anders krijg ik de stelbalk zeker niet in de wissel die al vast op de baan ligt.
Nu even rustgevend muziekje aan en kijken of ik deze weer in de wissel krijg. Omdat de wissel in de tunnel naar schaduwstation ligt is er eeg slecht bij te komen. Gaan het zien….
Am Ende der Strecke
    • MIL MOD
« Reactie #1433 Gepost op: 13 December 2024, 23:00:22 »
Zou het komen dat het vandaag vrijdag de 13e is?
« Reactie #1434 Gepost op: 13 December 2024, 23:02:11 »
Nou je het zegt Wim…..
Had ik menog niet gerealiseerd. :o
Am Ende der Strecke
« Reactie #1435 Gepost op: 14 December 2024, 08:53:14 »
Maar gisteravond nog een tijd zitten fröbelen en uiteindelijk de nieuwe stelbalk er in gekregen.
Voor zekerheid nog wat aanpassingen aan de aandrijving, iets dunnere steldraad en uitslag van de aandrijving op 3 mm (ipv 6) gezet.
Is als je hem zuiver afstelt precies voldoende. Op deze manier net wat minder krachten op de bewegende delen van de wissel.
Vandaag even bij Bentink langs om aantal dieseltjes weg te brengen die door Robert van wat vervuiling voorzien gaan worden.
Am Ende der Strecke
  • DB Tijdperk III
« Reactie #1436 Gepost op: 14 December 2024, 12:30:38 »
Goed om te lezen dat Wim wat concurrentie krijgt ;D
Die Sauerlandbahn
Mijn YouTube-kanaal
« Reactie #1437 Gepost op: 14 December 2024, 16:18:21 »
Fijn dat het wisselprobleem nog te verhelpen was. Ondanks dat het een kleine baan is, is betrouwbaarheid wel erg belangrijk voor het rijbedrijf en de afwisseling.
Pfarrerwinkel
    • Station Lemmer
« Reactie #1438 Gepost op: 14 December 2024, 16:31:30 »
Lijkt gelukkig mee te vallen.
« Reactie #1439 Gepost op: 15 December 2024, 08:33:16 »
Gelukkig wel Geert.
Gisteren nog wat onderdelen voor het industriegebouw gehaald. Heb als het goed is nu alles voor de onderste laag van het gebouw.
Nog weekje werken en dan 2 weken vakantie… dus bouwtempo maar eens wat verhogen.
Am Ende der Strecke
