Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
De Oosthoek (lokaalspoorlijn periode III, diesel) door Ronald Halma
25 January 2026, 19:50:32
Auteur Topic: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.  (gelezen 83958 keer)
    • nulpunt
Re: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.
« Reactie #540 Gepost op: 29 January 2024, 00:06:45 »
Tijd voor een lijstje "to do": UPDATE
1. zwaailicht
2. voetpedaal rem.
3. hijsoog/seinijzer voorzijde
4. ontluchtingspijpje op het dak voor de dieseltank
5. borging (anti-draai) middenstuk HIAB
6. remwerk achterzijde.
7. aanslagstand handbediende rem, dus niet tegen de uiterste aanslag (die heb ik al gemaakt).
8. diverse handels aan zijkant machinistenhuis
9. stangenstelsel voor de bediening van de zandbakken
tzt.:
1. geperforeerd plaat als treeplank. (ik zoek nog)
2. meterpaneel machinistenhuis (voor zover je die kan zien en dat is niet veel.)
Morgen:
- het 2e stangenstelsel, zandbak achter. Uurtje werk
- 2e zwaailicht. 2 minuten werk.
- ontluchtingspijpjes dieseltank op het dak. 10 minuten werk.
- onderzoeken of en hoe de remversteller aan de achter/onderzijde te maken zou kunnen zijn.
Maar dan zijn de Sikjes afgebouwd en klaar voor het aflakken en eindmontage.
« Laatst bewerkt op: 02 February 2024, 19:34:23 door FritsT »
    • nulpunt
« Reactie #541 Gepost op: 29 January 2024, 10:25:06 »
Heeft iemand nog vragen ? Nu kan het nog want binnenkort ga ik me met andere modellen bezig houden en zal dit draadje onder een laag stof komen.
moonlicht
« Reactie #542 Gepost op: 29 January 2024, 10:37:39 »
Heb je al een idee wat je voor het bed ga gebruiken (welk soort gaas)
Of word het er een zonder het bed ?
Cor
« Laatst bewerkt op: 29 January 2024, 10:39:26 door moonlicht »
« Reactie #543 Gepost op: 29 January 2024, 11:17:48 »
Ik denk dat de vragen pas komen als anderen aan het bouwen gaan.
Dus nog minstens een maand wachten schat ik in.  8)
    • nulpunt
« Reactie #544 Gepost op: 29 January 2024, 11:32:47 »
Cor
Ik hoef me daar niet druk om te gaan maken want ik ga geen "bed" maken.
In 1:1 zie je dat ding van onderaf en blijf je de Sik zien. In model kijk je voor 99,99% niet van onderaf en dan zie je iets wat je eigenlijk niet kent.
Het testmodel heb ik gemaakt en weer verwijderd, smoelt gewoonweg niet..
Tenslotte zijn er ook Sikken met HIAB zonder "bed".
« Laatst bewerkt op: 29 January 2024, 11:38:13 door FritsT »
    • nulpunt
« Reactie #545 Gepost op: 04 February 2024, 14:26:08 »
Voor de Sik met de plastic HIAB hebben we zelf de accubak en hydrauliek-tank geprint.
37538
Stootjuk
« Reactie #546 Gepost op: 05 February 2024, 16:50:25 »
Gisteren heb ik een foto van de bovenkant aan de voorzijde van de huif van locomotor 362 gemaakt. Daar zie ik een uitsparing net voor de schoorsteen in het plaatwerk zitten.
Is dit de plek waar de radiator gevuld wordt.
    • nulpunt
« Reactie #547 Gepost op: 05 February 2024, 17:03:59 »
 (y) (y) (y) (y) Ja , dat gat bedoel ik.
Ik heb er maar een rechthoekig afdekplaatje op gezet.
« Reactie #548 Gepost op: 05 February 2024, 17:06:45 »
Het ziet er meer uit als het gat waar de opwindsleutel in moet  ;D
    • nulpunt
    • nulpunt
« Reactie #550 Gepost op: 07 February 2024, 12:39:55 »
Vanmorgen de lampsteunen (Spoor-1) voor op de voetplaat ontvangen.
Passen perfect.
    • nulpunt
« Reactie #551 Gepost op: 07 February 2024, 12:40:32 »
Voor de Spoor-0 uitvoering:
1. Buffers met binnenvering. (geen gaten in de buffferbalk nodig)
Bufferplaten moeten, zoals verwacht, nabehandeld worden.
2. Olielamp.
37971
« Laatst bewerkt op: 07 February 2024, 12:42:24 door FritsT »
moonlicht
« Reactie #552 Gepost op: 07 February 2024, 12:48:55 »
Wil je nog een uitleg geven hoe deze buffers in elkaar moeten .?
Cor
    • nulpunt
« Reactie #553 Gepost op: 07 February 2024, 13:26:17 »
Ja hoor Cor, dat wil ik best.  ;D
1. los snijden en ontbramen zodat ze zonder hapering in elkaar passen.
2.tapeind M1,4 in de bufferplaat solderen/plakken
Te koop bij bv Knupfer. https://knupfer.info/shop/index.php/gewindestangen/messing/m-g-ms-14.html
3. veertje om het tapeind. Dit is een veertje 2,5mm in diameter en 5 mm lang
Ook bij Knupfer te koop.
4. huls over het tapeind schuiven en moertje M1,4 plaatsen.
Moertjes zijn ook bij Knupfer te koop.
5. Bufferplaat zover mogelijk indrukken en tapeind gelijk met de achterkant van de bufferhuls slijpen.
NIET VERGETEN het moertje met een druppie 10-secondenlijm of Loctite vast te zetten.
en dat was alles.
« Laatst bewerkt op: 07 February 2024, 15:34:34 door FritsT »
moonlicht
« Reactie #554 Gepost op: 07 February 2024, 13:37:57 »
Dank je voor de duidelijke uitleg
Cor
