Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
De Oosthoek (lokaalspoorlijn periode III, diesel) door Ronald Halma
25 January 2026, 19:50:32
Auteur Topic: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.  (gelezen 83971 keer)
    • nulpunt
Re: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.
« Reactie #555 Gepost op: 07 February 2024, 13:45:39 »
Graag gedaan.
    • nulpunt
« Reactie #556 Gepost op: 08 February 2024, 12:25:21 »
Kers op de taart? Voor mij wel. :D
38297
« Laatst bewerkt op: 08 February 2024, 16:40:18 door FritsT »
    • nulpunt
« Reactie #557 Gepost op: 08 February 2024, 17:50:25 »
Aan de achterzijde wordt het modelbouw technisch wat lastiger. Heeeeeeeeeeeeeeeeel weinig ruimte en bij functioneel gebruik... ???
Dus een compromis. Stukje van de steun van de HIAB er af. Helaas, maar ik denk dat dat de beste oplossing is.
    • nulpunt
« Reactie #558 Gepost op: 08 February 2024, 19:25:54 »
Om het ontstane "gat"  te camoufleren heb ik er een stripje 0,2 overheen gezet.
38314
    • nulpunt
« Reactie #559 Gepost op: 09 February 2024, 19:18:06 »
Nog een optie voor flexibel slang (heb ik net binnen gekregen, perfect)
binnendiameter 0,5 mm
buitendiameter 1,0 mm
rol van 5 meter.
https://nl.aliexpress.com/item/1005006411573469.html?spm=a2g0o.order_detail.order_detail_item.4.78816d76FKb0Pl&gatewayAdapt=glo2nld
    • nulpunt
« Reactie #560 Gepost op: 13 February 2024, 17:24:00 »
De laatste 2 componenten voor de groene HIAB in plastic zitten er nu ook op.
38870
« Laatst bewerkt op: 13 February 2024, 17:25:39 door FritsT »
    • nulpunt
« Reactie #561 Gepost op: 13 February 2024, 21:17:37 »
Kleuren.... altijd lastig om te verschalen en uiteindelijk te zeggen "het smoelt". En dan vooral niet vergelijken met andere (fabrieks)modellen.
Gewoon begonnen met een kleur waarvan ik denk dat die aardig in de buurt kan komen. Vallejo Modelair 71.289 US Dark Green en 71.057 Black. Niet met de airbrush, maar uit de hand met de kwast.
De kraan is nog steeds Tamiya XF-5, Flat green
Morgen de andere kant in de zwarte primer zetten en die daarna aflakken met dezelfde groen en dan het verschil beoordelen
« Laatst bewerkt op: 13 February 2024, 21:20:08 door FritsT »
  • Stroomlijners, mijn favorieten
    • Mijn YouTube filmpjes
« Reactie #562 Gepost op: 13 February 2024, 21:40:47 »
Ik zou dezelfde spuitbus gebruiken voor het groen als die je hebt gebruikt voor je 8500
Rob
YouTube
Mat 46
Mat 40
    • nulpunt
« Reactie #563 Gepost op: 13 February 2024, 22:30:08 »
Ik heb nooit een 8500 gemaakt. ???
Op een paar van mijn stoomlocs (NS-61, NS-5500 en NS-8100) heb ik spuitbus RAL 6020. Deze kleur is dat ook maar dan niet uit de spuitbus ivm de vele details. Maar het smoelt zo nog niet. De gele kleur van het messing schijnt er nog door dus volgende stap is zwarte primer.
Een test met ModelAir vergt maar 2 druppels verf en je leert zo de eigenschappen van de verf en de opbouw van de kleur. En niet onbelangrijk, de voorkeur van de toekomstige eigenaar (ben ik niet zelf) bepaald veel.
« Laatst bewerkt op: 13 February 2024, 22:33:28 door FritsT »
Thowra
« Reactie #564 Gepost op: 13 February 2024, 22:40:40 »
Frits,  horen er boven de buffers aan de achterzijde geen vierkante afdekplaatjes te zitten waar de lantaarnhouders als een geheel op gemonteerd zaten?
Dat kom ik op verschillende afbeeldingen tegen van de 'Sik' met Hiab kraan. Dan had je dat stukje van de steun er ook niet af hoeven te halen.  :o
    • nulpunt
« Reactie #565 Gepost op: 13 February 2024, 22:55:51 »
@Jeroen,
Op de 2e lok heb ik overlappend HIAB-voet/voetplaatsteun gemaakt. Dus dunne lampvoet en half ingevijlde HIAB-voet ipv een stukje afzagen en afdekken. Het verschil tussen de twee opties zie je nauwelijks.
Maar welke steun je er ook opzet, die moet wel stevig zitten en de beschikbare ruimte om dat stevig te solderen is er nauwelijks. Met de vingertjes druk je al snel te hard als je er een lamp op wilt plaatsen en dan heb je brekie-brekie.
Ik heb deze lampsteunen nagemaakt. Nu alleen nog die kleine lampen 3D tekenen (of geen lampen, kan ook).
« Laatst bewerkt op: 13 February 2024, 23:01:56 door FritsT »
« Reactie #566 Gepost op: 13 February 2024, 22:57:51 »
Frits,
Mijn oeps ik bedoelde inderdaad de de 8100. Ik gebruik voor groen ook de RAL 6020. Ik gebruik de rode primer van Motip en in die combinatie zie ik geen messing doorschijnen. Als je zwart als primer gebruikt ben ik bang dat groen dan donker gaat tonen, tenzij je dat geen probleem vind.
Rob
YouTube
Mat 46
Mat 40
    • nulpunt
« Reactie #567 Gepost op: 13 February 2024, 23:02:45 »
Dan ga ik ze toch allebei proberen.....no problem. Grappig dat anderen weer adviseren om zwart er onder te spuiten, wat ik zelf ook doe. Persoonlijke voorkeur. Maar ik ga het gewoon proberen.
Mijn suggestie aan de nieuwe eigenaar...wheateren.
« Laatst bewerkt op: 13 February 2024, 23:06:29 door FritsT »
becasse
  • http://becasse-weathering.blogspot.nl/
« Reactie #568 Gepost op: 14 February 2024, 12:29:22 »
Sowieso ;)
Waar gaan we heen voor spoor 1?
    • nulpunt
« Reactie #569 Gepost op: 18 February 2024, 23:03:20 »
Wheateren en reparatieplekken. Mogelijk ook de kozijn van de ramen in 2 kleuren. Ik heb er foto's van.
Ik twijfel erg aan RAL 6020, te geel naar mijn idee.
« Laatst bewerkt op: 18 February 2024, 23:05:10 door FritsT »
