Rsd1000
om 01:50:53
Oudere Marklin S3/6 opleuken
hmmglaser
om 00:18:17
om 00:02:10
29 January 2026, 23:52:57
reinderlf
29 January 2026, 23:21:21
29 January 2026, 23:18:11
reinderlf
29 January 2026, 23:13:59
29 January 2026, 23:08:32
meino
29 January 2026, 23:00:52
29 January 2026, 22:34:20
Dirk
29 January 2026, 22:34:00
29 January 2026, 22:29:42
29 January 2026, 22:27:19
29 January 2026, 22:20:32
BrightonBelle
29 January 2026, 22:20:11
29 January 2026, 22:05:05
Stub switches
29 January 2026, 22:02:56
marctrein
29 January 2026, 21:41:24
29 January 2026, 21:28:18
weslyr
29 January 2026, 21:11:59
Vroeger
29 January 2026, 20:55:42
Gare de Tannay, Frans N-spoor
Rik
29 January 2026, 20:52:30
29 January 2026, 20:46:35
Modelspoorbeurs MSC Spijkspoor 7 februari 2026
Suchet
29 January 2026, 20:11:43
29 January 2026, 19:59:56
Igra model 2026
TGVfreak
29 January 2026, 19:55:08
Oosthoek
29 January 2026, 19:32:06
Slijptrein
29 January 2026, 19:31:43
Mte korting
barry1972
29 January 2026, 19:10:50
Steven Loosman
29 January 2026, 18:35:56
Swalbenburg, N modulebaan
Topic: Swalbenburg, N modulebaan (gelezen 115382 keer)
Het leven op de weg.
Re: N-rijder in spe. 2,80 mtr x 60 cm.
Reactie #45 Gepost op:
31 January 2021, 11:34:55 »
Hoi, Kees
Vannacht bedacht ik me om van 1 van de bungalows een halte te maken.
Bij het losspoor vooraan wil kijken of er nog ruimte is voor een kraan of kleine kolenverlading in hout.
Misschien nog een klein spoortje splitsen.
Gr Koen.
Laatst bewerkt op: 31 January 2021, 12:11:45 door NS264
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #46 Gepost op:
31 January 2021, 12:08:51 »
Leuk plan zover! Kan niet wachten tot de bouw
Train-Science.com
Train-Science github
It ain't rocket science ;-)
Reactie #47 Gepost op:
31 January 2021, 12:12:12 »
Ikzelf ook niet
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #48 Gepost op:
31 January 2021, 13:33:53 »
Nu even babbelen over de constructie, aangezien dat moment dichterbij komt
Ik denk dat ik de baan in 3 modules deel aangezien 2 meter 80 gedeeld door 2 op 1 meter 40 komt.
Dus 3 bakjes bouwen.
Er komen plankdragers strips op de muur. 4 stuks want je moet ze om de meter aan de wand bevestigen.
Dan moet ik ff kijken hoe het uitkomt met de diepte de enkele drager is tot 60 cm max en de dubbele gaan tot 50 cm max.
Er komen dan twee banen aan te hangen onderop op tafelhoogte de Demka baan en erboven de N baan.
Ruimte wat overschiet onder de tafel en tot plafond opvullen met schappen.
Dan creëer ik gelijk opslagruimte.
Is een linkje nodig of is het duidelijk wat ik bedoel?
Gr Koen.
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #49 Gepost op:
31 January 2021, 14:20:56 »
Hoi Koen,
je gaat het nu op 2 "fronten" proberen lees ik
Even over je geplande baanplan,daar zie ik wat dingen die wellicht iets "handiger" kunnen.
Ik gooi ze maar even op,dan kun je er is over denken
Rechts bij de swalbe see heb je een spoor met brug over het water dat zwabbert door het landschap.
Is het misschien niet handiger om te proberen die zwabber eruit te halen en dan vanaf je bovenste bocht bij de bovenste brug,het spoor in een schuine rechte lijn te verbinden aan dat wissel bij de swalbe see ?
Dan zag ik nog een stuk weg wat wel erg zwabbert,links van stadt mitte en net voor de enkelsporige halte,daar moet verkeer straks haaks de bocht om.
Nu weet ik niet hoe breed die straat zal worden,maar een vrachtwagen zal daar niet blij worden als die het stadje in of uit wil
Wellicht helpt het als je de weg daar iets minder extreem/haaks maakt.
Tot zover de hints/suggestie's
Ben benieuwd hoe dit verder tot stand gaat komen.
Reactie #50 Gepost op:
31 January 2021, 15:09:25 »
Hoi Floris,
Dat Swalbe spoortje ligt idd niet helemaal zuiver maar daar kijk ik tijdens de bouw wel naar.
Die weg linkse deel is idd een haarspeld bocht en kruipt langs een muur van de keerlus rond Mittelstadt-Oben naar beneden.
Het station komt op een Arcaden verhoging te liggen en de weg zal eronder door gaan.
Kan nog wel eens een eigen schets maken tzt. Dan wordt het wat duidelijker.
Gr Koen.
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #51 Gepost op:
02 February 2021, 16:59:29 »
Und jetzt geht loss!
De nieuwe generatie N valt me niet tegen super veel detail.
En het scheelt de helft ruimte
Supertoll.
Laatst bewerkt op: 02 February 2021, 18:01:51 door NS264
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
nkob
Reactie #52 Gepost op:
02 February 2021, 17:17:53 »
LEUK HE
geheel herkenbaar !
Veel plezier er mee
Kees
Testrit
Reactie #53 Gepost op:
04 February 2021, 13:26:32 »
En fun hebben we zeker!
Plug en
play
Veel kijkplezier!
Laatst bewerkt op: 07 February 2021, 00:37:47 door NS264
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Eens komt het goed.
Reactie #54 Gepost op:
04 February 2021, 13:33:05 »
Hallo Koen.
Het is me helemaal ontgaan maar ga je met N-spoor aan de gang? Leuk en weer eens wat anders.
Ik las over topic heen omdat het om een N-spoor gaat. Die had ik niet gelinkt aan jou
Reactie #55 Gepost op:
04 February 2021, 13:39:26 »
Dat klopt maar HO blijf ik ook bouwen.
Pas me volledig aan de ruimte die ik heb aan.
Gr Koen.
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
meino
Reactie #56 Gepost op:
04 February 2021, 15:17:04 »
Koen
Ik had ook niet gezien dat je opeens met N spoor aan de gang bent gegaan. Ik ben benieuwd.
Groet Meino
A clean desk is a sign of an empty mind
Kranenberg een exercitie in code70
De CanBus komt naar Kranenberg
Reactie #57 Gepost op:
06 February 2021, 10:51:12 »
Geeft niks, Meino.
Er moet nog gebouwd worden maar het plan blijft zoals ie nu is.
Gr Koen.
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #58 Gepost op:
07 February 2021, 00:31:32 »
N
als aanvulling op het plan is deze week uiteindelijk het bestelde kerkje van MP binnengekomen afgelopen vrijdag.
Het past allemaal prima binnen de R1 keerlus van dit deel van de baan(links).
Bij alle verkregen tweedehandsjes moet wel iets gedaan worden, schilderen, lijmresten verwijderen, werk aan de winkel.
Wel wat details te bespeuren bij deze Kibri kerk.
Het dorpje Mittelstadt-Oben is nagenoeg compleet.
De verdere invulling volgt later wel.
Ik heb deze verzameling huisjes aangeschaft om ook het schaalverschil een beetje in de vingers te krijgen voor als ik zelf items ga bouwen.
Dan heb ik wat formaat voorbeelden om me heen.
Ook de bouwdoos van de goederenloods is binnengekomen om echt wat te kunnen plakken.
Ik maakte daarstraks de doos open om te spieken voor de foto, wat blijkt:
Voorlopig niet veel plakken dus.
Gr Koen.
Laatst bewerkt op: 07 February 2021, 00:38:56 door NS264
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
Reactie #59 Gepost op:
11 February 2021, 12:49:39 »
Nog even een beloofd getekend plan voor meer duidelijkheid.
Het ontbrak nog beetje aan dieptewerking.
Hier in close-up:
Mittelstadt-Oben ligt op een terrasvormige heuvel/helling
Alle wegen in de buurt kronkelen er langs naar boven of beneden dus ik wil een beetje spelen met de hoogteverschillen in landschapschapsopbouw.
De rails zelf komt slechts op 1+ (de bruggen) niveau misschien dat ik de basis beneden wel ophoog op de onderbouw van piepschuim.
Dan kun je in hoogte en dieptes wat creëren wat in N dan wel iets makkelijker is dan HO.
En nog in zijn geheel, hier en daar wordt nog wat bijgeschaaft.
De halte ligt tegen een rotswandje en de hoofdweg naar het centrum komt onder station binnen.
Maar ook daar ben ik nog niet helemaal uit hoe het dan weer uitkomt met de rest van het station.
Vooralsnog geen stationsgebouw, meer perron dan dat, ik bouw liever een stukje stad.
Gewoon beetje kijken hoeveel ruimte eroverblijft.
Wel het losspoor weten te splitsen.
Eerder dacht ik nog aan een kolenoverslagje maar aangezien er ws toch geen stoomlocs rond gaan rijden en meer tijdperk IV, V en VI gaat rijden ben ik nu eerder geneigd er een kleine dieseltank te plaatsen.
Dit is dan het voordeel van alvast die huisjes te hebben, geeft wat meer ruimtelijk inzicht.
Nu nog eens snuffelen naar een mooie houtzagerij in N.
Maar eerst wat rails erbij lijkt me ook wel handig
gr. Koen.
Laatst bewerkt op: 11 February 2021, 13:39:43 door NS264
Swalbenburg in N
de pauze stand.
Johnny Cash:
All I do is drive
