Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Rottershausen TP IIIb(1956 - 1968) H0  (gelezen 28423 keer)
  • Duitsland TP III/IV
Re: Rottershausen TP IIIb(1956 - 1968) H0
« Reactie #60 Gepost op: 15 November 2020, 13:52:56 »
Het busstation nadert zijn voltooiing. Alleen nog even de puntjes op de i zetten. Ook zijn er nieuwe spullen aangekomen.
Vollmer 45616 en een Chinese Grassaplicator. Deze laatste is puur gekocht om wat uit te proberen.
« Laatst bewerkt op: 18 November 2020, 12:25:50 door Ronald69 »
Grt, Ronald.
« Reactie #61 Gepost op: 18 November 2020, 12:27:20 »
Overgenomen van Forumgenoot "Tijgernootje": 3 x Viessmann 4501 en Auhagen 41618.
Grt, Ronald.
« Reactie #62 Gepost op: 28 November 2020, 18:25:20 »
Intussen was ik ook al bezig met de Stahl- und Röhrenlager.
De stellingen eerst geschilderd met H110, vervolgens met Rambo Beits Teak.
Onderzijde dak gemaakt van karton, plankmotief ingesneden en geschilderd met Rambo beits Teak.
Pallets zijn gemaakt uitstrookjes karton 1 mm x 1 mm, geschilderd met interieurbeits rustiek grenen(Karwei)
Linksonder een pallet welke in de bouwdoos zat, kan eventueel nog op de achtergrond dienst doen.
Zo gaat hij straks dienst doen op de baan, de stellingen nog leeg neergezet voor de beeldvorming.
De stellingen zijn gevuld met staalimitatie buizen, balken e.d.
De houten balkjes zijn weer gemaakt van strookjes karton 1 mm x 1 mm versterkt met secondelijm voor de stevigheid.
Grt, Ronald.
EricZmS
  • Buiten de lijntjes is veel meer ruimte
« Reactie #63 Gepost op: 28 November 2020, 19:27:46 »
Hele gave stellingen  (y)
Met vriendelijke groet, Eric
ZmS staat voor mijn koffie, Zwart met Suiker.
3x links is ook rechtsaf
« Reactie #64 Gepost op: 03 December 2020, 21:59:51 »
Dank Eric voor je reactie.
Staalhandel even terzijde geschoven en de soldeerbout even opgestookt om te het volgende te komen:
Stations borden. Inspiratie had ik Hier weggehaald.
Onderstaande pogingen had ik al ondernomen, links karton en rechts styreen, maar het was het net niet.
Vond het net iets te grof. Hij moet nog wel iets hoger komen te staan anders stoot Heinrich zijn hoofd elke keer weer.
Grt, Ronald.
« Reactie #65 Gepost op: 04 December 2020, 17:43:37 »
Doos paracetamol doet wonderen daar tegen  ;)
Lekker bezig zo  (y)
« Reactie #66 Gepost op: 07 December 2020, 16:50:22 »
Dank Floris  (y).
Had een vraag uitstaan over Kibri perronbanken. Tot op heden geen antwoord op gehad dus zelf maar aan de slag gegaan.
Bovenste rij zijn originele banken zonder het reclamebord, middelste 3 rijen zelfbouw en onderste rij links zelfbouw en rechts originele bank alvast geschilderd(H119).
Grt, Ronald.
« Reactie #67 Gepost op: 10 December 2020, 14:34:40 »
In MIBA Modelbahn Praxis "Rund um den Bahnsteig" kwam ik dit artikel tegen:
Een standaard koersborden op te hangen. Heb zelf 1 gietboompje met 6 koersborden maar ben op zoek naar meerdere exemplaren. de vraag heb ik Koersborden gezocht in desbetreffende topic gesteld maar nog geen reactie gehad.
Op het perron ziet het er dan zo uit:
Zoals te zien is kan ik dan wel een aantal borden gebruiken. Bij deze nogmaals de vraag: wie heeft ze en gebruikt ze niet? Ik wil ze wel overnemen.
Grt, Ronald.
« Reactie #68 Gepost op: 10 December 2020, 15:05:02 »
Ik heb ze zelf niet, maar is printen en daarna plastificeren (lamineren) een optie?
Pfarrerwinkel de bouw:
Pfarrerwinkel
« Reactie #69 Gepost op: 10 December 2020, 15:28:58 »
Hoi Jelmer,
Dank voor je reactie.
Dat zou een oplossing kunnen zijn want ik heb ze ooit gemaakt voor mijn rijtuigen maar een kant en klare variant leek mij de makkelijkste oplossing. Mocht er na volgende week geen reactie op mijn vraag meer komen maak ik ze zelf wel.
Grt, Ronald.
Modellbahnwagen
« Reactie #70 Gepost op: 10 December 2020, 16:17:02 »
Zelf maken lijkt mij het mooiste, als je ziet hoe dik die meegeleverde koersborden zijn :-\
Richard
« Reactie #71 Gepost op: 10 December 2020, 16:45:36 »
Richard,
Daar heb je gelijk aan maar dan heb ik wel het volgende probleem, hoe of waar maak ik de handvaten?
Grt, Ronald.
Ric
« Reactie #72 Gepost op: 10 December 2020, 17:12:56 »
Hallo Ronald,
Je zou er een nietje voor kunnen gebruiken. Verder zoals Jelmer al schreef nietje tussen het laminaat?
Grt. Ric
Deetrein
« Reactie #73 Gepost op: 10 December 2020, 18:05:41 »
Artitec heeft ze, wel met Nederlandse bestemmingen
Mvg, Erich
bestelnr. 10.357
« Laatst bewerkt op: 10 December 2020, 18:11:49 door Deetrein »
« Reactie #74 Gepost op: 10 December 2020, 19:44:39 »
Erich,
Dat van Artitec wist ik wel, bij mijn toenmalige Plan E's zaten ze er ook bij. In ieder geval dank voor het meedenken.
Ric,
Ik denk dat nietjes iets te groot er voor zijn, dank voor je reactie.
Zelfbouw, dat is wat het gaat worden dus. Ik had ooit een x aantal zakjes met geëtste koersborden gekocht van RST modelbouw via Wagenwerk, te zien op pagina 2 van dit draadje Foto (stuk naar beneden scrollen) maar die wil ik behouden voor mijn rijtuigen.
Ze kunnen wel dienst doen als mal voor de geprinte bestemmingen die ik eerder had gemaakt voor diezelfde rijtuigen.
Benodigdheden:
Stuk installatiedraad met getwiste kern.
Print van bestemmingen.
Geëtste of model koersbord.
Op de foto v.l.n.r. is het zelfbouw koersbord te zien, dan de geëtste en het model koersbord.
Voor een eerste poging ziet het er redelijk uit, eenmaal geschilderd en hangend vallen de grote handvaten een stuk minder op denk ik.
Grt, Ronald.
