Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Halling Randstadrail Citades in model  (gelezen 65735 keer)
Ivo tB
Re:Halling Randstadrail Citades in model
« Reactie #15 Gepost op: 05 January 2011, 22:14:06 »
Toevallig heb ik dit model vandaag in de etalage van de Wapstad zien staan. Het zag er bijzonder goed uit.
Ivo
Ivo
  • Team Beurzen en PR
  • Lid MSG Haarlemmermeer
« Reactie #16 Gepost op: 06 January 2011, 09:12:19 »
@Martijn, Bij de "Nieuw in de Winkel" rubriek heet het trammetje ook Halling/Wapstad ;)
Ik heb de tram vanmiddag, en zal proberen vanavond wat foto's te plaatsen.
Vr. groeten,
Bob
Treinhobbijist
« Reactie #17 Gepost op: 06 January 2011, 11:09:22 »
........ dankzij investering door de Wapstad (niemand anders wou 300 stuks vooruit betalen)
300 stuks, zijn er zoveel Randstadrail fans dan ....?
Overigens, ook via De Houtloods in Den Haag verkrijgbaar.
Ook Engelse treinen zijn leuk
« Reactie #18 Gepost op: 06 January 2011, 11:28:38 »
300 moet toch lukken?
Van het RandstadRail personeel zullen er ook wel een aantal zijn die er 1 wil hebben.
(Bob die nou niet gelijk een "fan" is... ;))
Vr. groeten,
Bob
Treinhobbijist
« Reactie #19 Gepost op: 06 January 2011, 11:56:47 »
Kan me haast niet voorstellen, zit je er al de hele dag in, ga je er 's avonds thuis ook nog even flink mee rijden  ;)
Edwin van Mierlo
« Reactie #20 Gepost op: 06 January 2011, 15:07:17 »
Toch leuk voor in de vitrinekast joh :D
Treinhobbijist
« Reactie #21 Gepost op: 06 January 2011, 18:34:01 »
Ik vernam dat de HTM er zelf 40 heeft gekocht, en er nog meer wilde.
Zeker voor als geschenk, als je aldaar met de VUT gaat......
martijn v m
  • Heerwijk in H0
    • vames
« Reactie #22 Gepost op: 06 January 2011, 18:36:52 »
het is een erg leuk model geworden als ik de foto's zie.
« Reactie #23 Gepost op: 06 January 2011, 19:32:02 »
Mijn eerste Halling randstadrail foto:
Vr. groeten,
Bob
martijn v m
  • Heerwijk in H0
    • vames
« Reactie #24 Gepost op: 06 January 2011, 19:35:36 »
en ik zie helaas al een groot minpunt  :(
de bakken sluiten niet mooi aan op de geleding.
 of zie je dat niet als je er gewoon naar kijkt?
groet Martijn
Machinist Johan
  • gevorderd beginner
« Reactie #25 Gepost op: 06 January 2011, 19:47:35 »
ik vind die neus niet je van het...
« Reactie #26 Gepost op: 06 January 2011, 20:57:47 »
Wapstad en SKIPtram hebben dus in samenwerking met Halling als producent een model van de Randstadrail Alstom Regio Citadus uitgebracht.
Het grote voorbeeld:
Deze Alstom Regio Citadus rijd tussen Den Haag (waar hij ook als echte tram tussen het gewone verkeer komt) en Zoetermeer.
Den Haag Centraal
Leidschendam
De tram is afgeleid van de tram die in Kassel rijd:
Het model:
Zoals we gewend zijn zit het model in een plastic bakje waar je normaal een flink broodje hotdog in verwacht ;D
Keurig maar simpel ;)
Op de baan staat dan een erg mooi model met maar enkele minpunten:
Het is weer een typisch Halling product.
3 kappen van bedrukt doorzichtig stevig plastic, met een volledig open interieur.
In beide buitense bakken zit een motor die vrij lawaaiig is, maar als er niet met een rotvaart mee gaat rijden valt dat wel mee.
(Binnenkort zal ik een filmpje maken)
Als je schuin naar het model kijkt kan langs de balg je het interieur zien, als die balg wat breder was geweest dan had dat een stuk minder opgevallen.
Dat vind ik het grootste minpunt van dit model.
Het gewicht zit in de daken van de 2 buitenste bakken.
Het interieur is 2 kleurig en de cabine van de tram bestuurder zit in de bak vast.
De aandrijving zit op beide buitenste draaistellen.
De rijeigenschappen zijn uitstekend, geen enkele boog is te krap, maar het is dan ook een model van een tram  ;)
Op het dak alle apparaten, maar de "doosjes"zijn vlak met bedrukking om te doen lijken dat er reliëf op zit.
De tram heeft wisselende rood/wit verlichting en is digitaal voorbereid.
Er worden koersborden voor verschillende bestemmingen meegeleverd die aan de binnenzijde en op de voor en achterkant geplakt moeten worden.
Ook zitten er achteruitkijkspiegels bij die je in de voorgeboorde gaatjes kunt plaatsen.
Ook kun je een motorloze versie kopen die je met de meegeleverde koppelstangen kunt koppelen.
Of dat een beetje volgens werkelijkheid is ?
Plus en min:
+Model heeft goede rijeigenschappen
+Is mooi bedrukt.
+Volledig interieur door de keuze voor 2 kleine motoren
-vrij lawaaiig
-Grote inkijk als je schuin naar het model kijkt.
-Vrij pittig geprijsd, (maar er zijn er dan ook maar 300 geproduceerd)
Eindconclusie:
Ik ben er blij mee, een model met weinig problemen en vrij uniek die zowel inzetbaar is op een trambaan als op een treinbaan.
Jammer van de inkijk, daar maar niet te veel op letten ;) ;D
« Laatst bewerkt op: 06 January 2011, 20:59:20 door Bob Rodenburg »
Vr. groeten,
Bob
MMTB
    • Rheinberger Strassenbahn Betriebe
« Reactie #27 Gepost op: 06 January 2011, 21:12:35 »
Ik heb hem ondertussen ook op de baan staan en het is een mooie aanwinst. De vrije inkijk tussen de bak en de geleding valt best mee, maar de kopvorm is minder geslaagd. In het echt is het gedeelte wat onder de voorruit zit afgerond en in model is het bijna vierkant.
De bedrukking is zeer goed en actueel uitgevoerd. Alle denkbare bestemmingen zitten erbij en in het juiste lettertype uitgevoerd. De rijeigenschappen zijn zoals we van een Halling model gewend zijn en dat is goed. De kap resoneert enigszins, maar niet storend op normale snelheden. Een boogstraal van 25cm red hij prima.
De koppeling is iets voor later, want er zijn plannen voor gekoppeld rijden in Den Haag.
Ik hoop zelf dat het Kasselse model nog een keer wordt uitgebracht en dan in de dieselversie.
Groeten, Mark
Duitse tramstad in H0, een speelbaan in spoor 0 en een nieuwe beursbaan in 0e
ronald1956
  • OHMB Team Mitropa
  • Tram&Trein NL- H0
    • Haagse Modelbouw Club
« Reactie #28 Gepost op: 06 January 2011, 21:19:24 »
Als aanvulling kan ik nog vermelden dat er nog een heel klein minpuntje is.
Op de kop ontbreekt het kleine zilveren Alstom logo.
Rob van Biezen is nu bezig om dit als losse transfer alsnog beschikbaar te krijgen.
Niet gelijk naar de Wapstad hollen , dit kost wat tijd .( ik heb nog niemand gehoord die het al opgevallen was )
Machinist Johan
« Reactie #29 Gepost op: 06 January 2011, 21:25:39 »
niet op elke tram zit een alsthom logo ;)
