Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Halling Randstadrail Citades in model  (gelezen 65733 keer)
De Burgemeester van Hespedam
    • Hespedamse Tramweg Maatschappij
Re:Halling Randstadrail Citades in model
« Reactie #150 Gepost op: 05 May 2012, 21:57:05 »
Zie voor het rijgedrag in bochten van een Citadis Rr het filmpje bij minuut 2.00
Daar zie je hoe de bakken uitzwenken t.o.v. de rails
http://www.youtube.com/watch?v=gZ7luSxDQCo&feature=player_embedded
Niek
TreintjeDelft
« Reactie #151 Gepost op: 05 May 2012, 22:06:42 »
23 meter is de minimale boogstraal voor de citadissen in Den Haag, dit is ook volgens opgaaf van de leverancier van het voorbeeld en waarop de minimale boogstralen in de nieuwe trajecten voor de citadis worden gebouwd. In Den Haag mogen de citadissen niet overal komen, zo ook niet in Delft.
In model kun de minimale boogstraal delen door 87, dan blijft er een minimale boogstraal van 26,4 cm over.
Christoph
Tof! (y) Weten we dat het op die manier in ieder geval allemaal realistisch is.
dat de citadisen niet overal mogen/kunnen komen komt door hun breedte van 2.50m.
Hallo Martijn,
dat ze niet overal kunnen komen is niet alleen vanwege hun breedte, maar onder andere ook de andere bewegingen die het voertuig maakt tov de rails (let maar eens op in en vlak na de bogen) en de grotere minimale boogstraal dan de GTL trams.  ;)
Christoph
dat kan ook wel kloppen ja.
maar het voornaamste is de breedte omdat de rails dan te dicht bij de bovenleiding masten licht of in bogen
Inderdaad, het heeft te maken met het zwenken nadat ze uit de bochten komen of wanneer ze een bocht in gaan. Dat komt door de breedte, maar ik denk ook doordat de bakken een stuk langer zijn dan die van de GTL en mogelijk (en beredenering van mij) omdat aan de voor en achterkant de lengte tussen het draaistel en de daadwerkelijke voorkant van de cabine langer is dan bij de GTL's. Zie http://youtu.be/1YlpU3925Y8?t=21s
Edit: De Burgemeester van Hespedam was me voor.
Christoph
    • Zwetdorf in model
« Reactie #152 Gepost op: 06 May 2012, 11:19:23 »
Het zwenken dat het voertuig doet als het uit of in een boog gaat rijden komt voor een groot deel voort uit de posities van de draaistellen.
Het tweede draaistel bevind zich niet onder de geleding maar er achter, in het middenstuk. Dit in combinatie met de lange bakken en de grote overhang voor de bestuurder maken het rare profiel dat de tram nodig heeft.
Christoph
MMTB
    • Rheinberger Strassenbahn Betriebe
« Reactie #153 Gepost op: 06 May 2012, 12:47:12 »
Als je 25cm aanhoud als minimum boogstraal, dan zullen alle verkrijgbare trams hier doorheen kunnen rijden. Alleen de Utrechtse sneltram en de Stuttgart DT8 van Halling heb ik niet in bezit en deze zouden zover ik vernomen heb niet door 25cm gaan. Misschien dat een ander forumlid hier wel ervaringen mee heeft.
Groeten, Mark
Duitse tramstad in H0, een speelbaan in spoor 0 en een nieuwe beursbaan in 0e
TreintjeDelft
« Reactie #154 Gepost op: 06 May 2012, 13:00:40 »
Bedankt voor de info, ik ga nog rustig aan de slag met mijn plannen.
Wel vreemd dat die Utrechtse er misschien niet doorheen kan. Waarschijnlijk zal ik dat model toch nooit bezitten, maar het is gewoon erg raar.
MMTB
« Reactie #155 Gepost op: 06 May 2012, 14:12:27 »
Vreemd is het niet, want dit zijn geen stadstrams, maar sneltrams. Deze hebben een veel grotere afstand tussen de draaistellen dan normale trams.
Groeten, Mark
martijn v m
  • Heerwijk in H0
    • vames
« Reactie #156 Gepost op: 06 May 2012, 14:13:28 »
ik heb zelf de sunij tram en die gaat inderdaad niet door krappe trambogen
wat de radius van die is weet ik niet
TreintjeDelft
« Reactie #157 Gepost op: 06 May 2012, 14:54:10 »
Groeten, Mark
Natuurlijk, stom van me. :P ::)
Volgens mij is die bocht bij Utrecht CS wel behoorlijk scherp, als ik het me goed herinner.
martijn v m
  • Heerwijk in H0
    • vames
« Reactie #158 Gepost op: 06 May 2012, 15:00:09 »
hij kan ook wel een scherper de bocht om dan een trein ::)
Maar niet zo scherp als een stads tram :-X
TreintjeDelft
« Reactie #159 Gepost op: 06 May 2012, 15:19:27 »
Nou ja, (sommige) treinen kunnen ook wel behoorlijk scherp door de bocht, je ziet wel op sommige goederenaansluitingen dat goederentreinen hele scherpe bochten maken met bv. 6400'en en Class 66's. Maar we gaan nu een beetje off-topic. ;D
Frans van Meerwijk
« Reactie #160 Gepost op: 06 May 2012, 20:14:37 »
Mijn ervaring:
een gelede "echte tram" is betrouwbaar door een boogstraal van 250 mm te jagen, Sneltrams voelen zich pas prettig vanaf grofweg 360 mm...
Let er daarbij ook op, dat het er nog een beetje acceptabel uitziet
TreintjeDelft
« Reactie #161 Gepost op: 06 May 2012, 22:39:39 »
Dat is goed om te weten, moet wel zeggen dat het merkwaardig is dat wel HO modeltreinen gewoon door R1 kunnen terwijl sommige sneltrams dat niet kunnen. Nou ja, als we kijken naar hoe het in het echt is, is het bij modeltrams nog steeds realistischer.
