om 00:17:44
om 00:12:33
14 February 2026, 23:59:00
Paulus1201
14 February 2026, 23:28:46
14 February 2026, 23:23:18
Fleischmann 734124
joespoor
14 February 2026, 23:19:17
Frans Peeters
14 February 2026, 23:15:05
Casmir
14 February 2026, 23:05:45
weslyr
14 February 2026, 23:04:11
eitreb
14 February 2026, 22:55:22
RIVAROSSI set R0005 - Twee Italiaanse stoomlocomotieven.
14 February 2026, 22:33:37
14 February 2026, 22:27:45
14 February 2026, 22:24:12
14 February 2026, 21:58:41
Jeroen95
14 February 2026, 21:54:37
Jeroen Trainz
14 February 2026, 21:30:58
Revier Rheinbrenner (H0)
14 February 2026, 21:29:32
MiHe
14 February 2026, 21:22:51
14 February 2026, 21:21:52
meino
14 February 2026, 21:21:34
Hobojohn
14 February 2026, 21:08:27
14 February 2026, 21:02:15
14 February 2026, 20:59:53
servo aansturing
Henk G
14 February 2026, 20:47:09
Contact met de NVBS
14 February 2026, 20:33:30
VAM65
14 February 2026, 20:16:33
Spoorwegmuseum in zwaar weer
14 February 2026, 19:32:41
14 February 2026, 18:48:27
Keska
14 February 2026, 18:48:02
guy1846
14 February 2026, 18:38:09
Digitaal
Elco voor knipperende leds in wagon
Topic: Elco voor knipperende leds in wagon (gelezen 4993 keer)
72sonett
Team encyclopedie
Re: Elco voor knipperende leds in wagon
Reactie #45 Gepost op:
13 April 2018, 19:22:06 »
24 ledjes in 8 strengen parallel van 3 ledjes in serie, per streng 20 mA, totaal dan 8 x 20 mA = 160 mA door beide weerstanden.
De spanningsval over die ene weerstand van 220 ohm is dan e = i * r = 160/1000 * 220 = 35 V, met andere woorden: je houdt niets over.
De spanningsval over beide weerstanden zou 16 - 12 = 4 V moeten zijn. De weerstand die daar bij hoort is
4 / (160/1000) = 4000/160 = 25 ohm, dichtsbijzijnde E12 waarde is 27 ohm (rood/violet/zwart).
El Carrilet
"te dom om te poepen"
MH
Timo
Team encyclopedie
Reactie #46 Gepost op:
13 April 2018, 20:32:09 »
Nogmaals, normaal doen die strippen 20mA per 3. Maar dat geeft
heel veel licht!
Dat is dan standje zonnebank + stadion verlichting in één.
Waarschijnlijk veel meer dan je in een loc wilt hebben. Ook is met zo'n stroom de invloed van de condensator ook zo'n beetje verwaarloosbaar.
En nogmaals, je kan rekenen tot je een ons weegt, hoe het er in je model uit ziet kan je dan niet meenemen. Maar voor 30cm (dus 6 stukjes met 3 leds), 12mA voor de hele strip en een baanspanning van 18V (voor de gelijkrichter) kom ik uit op zo'n 700Ω totaal. Dus met 220Ω voor R
1a
en 470Ω voor R
ben je er dan. Maar uiteindelijk moet jij kijken hoe dat werkelijk staat! Dus maak het niet moeilijk, en pak gewoon een assortiment en probeer
Timo
Andreas_______
Reactie #47 Gepost op:
13 April 2018, 21:43:54 »
Dus als ik het goed begrijp moet ik een weerstand van 220 ohm voor r1a gebruiken en een 27 ohm voor r1
Verstuurd vanaf mijn ALE-L21 met Tapatalk
Timo
Team encyclopedie
Reactie #48 Gepost op:
13 April 2018, 21:46:27 »
Nee, je moet* gewoon proberen
Timo
*je moet niets maar raad het je sterk aan
Andreas_______
Reactie #49 Gepost op:
13 April 2018, 21:52:10 »
Hier staat 330ohm, is het dan niet 330 - 220=110 ohm voor de r1 weerstand?
Timo
Team encyclopedie
Reactie #50 Gepost op:
13 April 2018, 22:03:02 »
Zucht, eigenwijs of niet
1) Je probeert WEER de leds op volle sterkte te gebruiken (20mA). Probeer eens 2mA
2) Bij verlaagde stroom is de spanningsval maar zo'n 2,8V per led.
3) Je vergeet dat je iedere 5cm een setje parallel hebt. Voor 30cm zijn dat dus 6 setjes van 5cm parallel met ieder 3 ledjes in serie. Dat kan deze calculator niet aan.
4) De ledstrip heeft ook al een weerstand, deze moet je meenemen in je uiteindelijke berekening
Met andere woorden, die weerstand calculators zijn leuk om de minimale weerstand te bepalen als je een ledje gebruikt maar meer ook niet. En ronduit niet te gebruiken bij kant en klare ledstrips.
Timo
René 4312
Reactie #51 Gepost op:
13 April 2018, 22:20:40 »
Ja......
Mechiel, bestel de gelijkrichters, condensatoren en
zo iets
, pak er 1 weerstand van 220 Ohm uit voor R1a ga een avondje lekker zitten en pak een weerstand van 10 Ohm voor R1.
Denk dan: dit lijkt wel stadionverlichting!
Pak dan de volgende weerstand en test deze dan, net zo lang tot je bij de 1 MOhm bent. Als je die aangesloten hebt denk dan: zie ik een kaarsje branden in dat rijtuig?
Eén van de tussenliggende waarden was vast beter, gebruik die dan. Hier kan je niet tegen rekenen!
(het kaarsje zal bij een lagere waarde waarschijnlijk al uitgeblazen zijn
René
René
Timo
Team encyclopedie
Reactie #52 Gepost op:
13 April 2018, 22:24:01 »
Inderdaad, assortimentje
Had ik eerder ook naar gelinkt.
Mijn inschatting is dat de gewenste waarde waarschijnlijk tussen de 220Ω en 560Ω ligt. Let wel, dat is incl 220Ω R
1a
en gevoed via gelijkgerichte baanspanning.
Timo
Reactie #53 Gepost op:
13 April 2018, 23:05:33 »
Het internet wemelt van de weerstandscalculators voor leds. Ze zijn bedoeld voor mensen die het niet zelf kunnen uitrekenen, maar juist die mensen kunnen behoorlijk de mist in gaan, zeker bij wat complexere situaties.
Je kan je beter verdiepen in de achtergronden en dan zelf gaan rekenen. Daardoor krijg je een beter gevoel voor de materie. Bij complexere situaties zoals in dit geval met meerdere parallelle strengen van leds in serie kan je het beste eerst het hele schema uittekenen. In dat schema vul je dan de gewenste stromen in, en daaruit volgen de spanningen. en uit die spanningen volgen dan de waardes voor de weerstanden.
HansQ
Daar waar de rook is, is de kortsluiting...
Reactie #54 Gepost op:
14 April 2018, 13:36:41 »
...als je wilt kan ik wel wat spul voor je in een envelop stoppen:
- condensatoren stuk of 3
- weerstanden stuk of 100, verschillende waarden
- gelijkrichters paar stuks
- krimpkous
- metertje draad 2 kleuren, als je dat niet hebt
met postzegels zijn de kosten een paar Euro, doe me maar een PM...
soldeer en soldeerbout moet je zelf regelen, koop gelijk ook en multimeter (Action heeft ze).
HansQ, RailClub Utrecht
bellejt
Reactie #55 Gepost op:
14 April 2018, 15:39:57 »
calculators zijn voor ledstrips goed bruikbaar als je rekening houd met de reeds bestaande weerstand op de strip.Bereken gewoon zoals je normaal zou doe en trek er dan de waarde van de weerstand op de strip af.Je krijgt dan de juiste waarde van de voorschakelweerstand.Zelfs als je meerdere delen parallel hebt.Je moet natuurlijk de juiste calculator gebruiken en de juiste waarden van je ledstrip weten.Maar die zijn zelfs bij deze van de chinees terug te vinden.
Reactie #56 Gepost op:
14 April 2018, 15:50:30 »
Ja, maar als je zo ver bent dat je dit allemaal snapt dan kan je het net zo goed op een stukje papier uitrekenen.
Andreas_______
Reactie #57 Gepost op:
02 June 2018, 14:08:28 »
Hallo, ik ben weer terug van weggeweest. Ik heb nu samen met de 220 weerstand er 1k bij gedaan voor 24 leds, ik heb nu een wagon die 6 leds nodig heeft. Moet ik dan een weerstand van 4K doen om het licht even fel te houden als de grote wagons?
Digitaal
