om 19:07:12
Roco Hippel 04160C digitaliseren
De eerste Ivo
om 19:06:46
om 18:58:54
om 18:57:32
Fotowedstrijd 2025
Keska
om 18:47:05
om 18:46:46
om 18:26:24
om 18:09:36
Albert.H0
om 18:09:27
om 18:07:05
Lars Smelter
om 18:03:25
W.V. Kalender 2026
Keska
om 17:59:28
Handleiding Trix Express 2232 BLS 255
odaoda
om 17:57:21
Welke Rookvloeistof gebruik jij?
borotof
om 17:42:14
om 17:37:31
Rsd1000
om 17:35:29
Yamorc YD8116 & MP1 vraag
Bert_Apd
om 17:35:23
om 17:14:55
Brawa 2026
spoorzeven
om 17:10:07
om 16:28:33
ecos2 koppelen met handregelaar.
AlbertG
om 16:27:53
om 16:21:48
om 16:05:05
Mitteldorf, baan in H0, DR tp III
Peter.D
om 15:56:39
ANDREUS
om 15:50:27
om 15:46:30
De Projecten van RetroJack
om 15:34:19
om 15:19:43
om 14:56:40
Lagers vervangen DJH NS 3300
om 14:34:18
Modelspoorverenigingen (MSV)
Modulebaan.nl
MB-module: "Chicago Union"
Topic: MB-module: "Chicago Union" (gelezen 143211 keer)
guest7823
Re: Modulebaan: "Chicago Union"
Reactie #300 Gepost op:
17 November 2017, 22:34:30 »
Omdat "Chicago Union" even in de wachtstand staat en ik toch even wat "Google-tijd"over had .....
http://www.rrpicturearchives.net/showPicture.aspx?id=4683638
http://www.rrpicturearchives.net/showPicture.aspx?id=886023
http://www.rrpicturearchives.net/showPicture.aspx?id=886024
http://www.rrpicturearchives.net/showPicture.aspx?id=886026
http://www.rrpicturearchives.net/showPicture.aspx?id=2288132
http://www.rrpicturearchives.net/showPicture.aspx?id=1880090
http://www.rrpicturearchives.net/showPicture.aspx?id=1892367
http://www.rrpicturearchives.net/showPicture.aspx?id=2673743
http://www.rrpicturearchives.net/showPicture.aspx?id=889138
http://www.rrpicturearchives.net/showPicture.aspx?id=3325913
http://www.rrpicturearchives.net/showPicture.aspx?id=3305660
http://www.rrpicturearchives.net/showPicture.aspx?id=2888859
http://www.rrpicturearchives.net/showPicture.aspx?id=982312
http://www.rrpicturearchives.net/showPicture.aspx?id=933395
http://www.rrpicturearchives.net/showPicture.aspx?id=1937427
http://www.rrpicturearchives.net/showPicture.aspx?id=489091
nighttrain1
Team Beurzen en PR
Reactie #301 Gepost op:
17 November 2017, 23:15:06 »
Mooie plaatjes Paul.
Heb ik toch nog een vraag: als je boven op het panoramadek staat in de ex-Searstower, kan je dan op dit emplacement kijken?
Groeten Richard, nighttrain1
Bouw:
Modelbaan
modulebakken
Hendrik Jan
Reactie #302 Gepost op:
17 November 2017, 23:28:03 »
https://www.google.nl/maps/@41.8807749,-87.6356052,563a,35y,189h,57.93t/data=!3m1!1e3
Deel van het traject is nog te zien, de rest is verdwenen.
Er zijn allerlei gebouwen overheen gebouwd!
That's progress...
Ik was in '98 in Chicago. Per trein
Dus dan kom je daar aan, vanuit NYC. En daarvandaan ook weer vertrokken richting The Big Easy, "Nawlins".
see ya
Hendrik Jan
-Billy Connolly
nighttrain1
Team Beurzen en PR
Reactie #303 Gepost op:
18 November 2017, 06:23:05 »
Ik in 2003, met 2 andere collega`s bewust naar toe gereden, voor een bezoek aan de Sears tower.
Vanuit Three Rivers, Michigan, nabij Kalamazoo.
Bouw:
Modelbaan
modulebakken
Pauze
Reactie #304 Gepost op:
02 December 2017, 23:22:19 »
Dan zit je op JijBuis een beetje rare zoektermen in te tikken, en dan duikt opeens dit filmpje op....
https://www.youtube.com/watch?v=hePTXxHsOMY
Een beroerd filmpje, maar het laat wel zien dat ik toch echt een PRR S2 turbineloc moet hebben op Union. Wat het echter ook laat zien, is dat het pakhuis tot eind jaren veertig een helemaal gesloten facade aan de spoorkant had en dat de pilaren en terugwijkende muur op de begane grond pas echt later zijn gekomen.
Eens even kijken welke consequenties dat gaat hebben voor mijn bouwwerk tot nu...
Eelco
nighttrain1
Team Beurzen en PR
Reactie #305 Gepost op:
12 December 2017, 12:53:39 »
Eindelijk het hoge woord is er uit:
https://wbooks.com/winkel/geschiedenis/laatste-stoomlocomotief/
Gefeliciteerd met de aankondiging van het door jouwzelf geschreven boek.
(Ik ga er een bestellen bij mijn plaatselijke verkooppunt, die meneer moet tenslotte ook eten en wil niet dat ook hij ten onder gaat aan de internet leveranciers. Èn ben ik er zeker van dat ik dan een recht boek in handen krijg i.p.v. het boek wat Chris laatst via de post thuis gestuurd kreeg. )
Bouw:
Modelbaan
modulebakken
guest7823
Reactie #306 Gepost op:
28 February 2018, 21:37:19 »
Gewoon. Omdat het kan
Maar vooral ook omdat er dan gewoon wat meer kan qua rijden op de bak zelf tijdens een beurs. En ........ dat is toch wat mensen willen zien tijdens een beurs. Zeker als je aan de voorkant staat te bedienen.
Het spoor dat nu naar rechts wegloopt wordt vervolgd als uithaalspoor wat achter de buurbak langs gaat en aan de eigen BB hangt
guest7823
Reactie #307 Gepost op:
18 March 2018, 19:02:20 »
Tijdens Eurospoor 2017 wat van gedachten gewisseld met Eelco. Daar kwam uit dat het misschien wel mogelijk zou zijn om de wisselstraat dusdanig te verlengen naar de BB (en mogelijk zelfs verder) waardoor er wat meer (rangeer)beweging mogelijk zou zijn op Chicago Union. En dit zonder het verkeer op de hoofdbaan te verstoren.
Het idee was om op de een of andere manier "iets" te maken waardoor er een uithaalspoor "achterlangs" zou komen.
Het eerste idee was enkel een uithaalspoor op de eigen BB en eventueel de BB van de buren
Vervolgens ...... kunnen we niet iets maken wat achter de bak van de buren langs gaat
Daarna ....... als dat lukt, kunnen we dan niet een opstelspoor achter je bak maken
Als we het rechts doen ......... waarom dan ook niet links
Als we nog toch gaan zagen, waarom dan niet ook nog "even" twee verlengbakjes zodat er thuis ook nog een beetje geshuttled kan worden
Hmmmm ...... als we nu links en rechts "achterlangs" gaan, waarom dan niet een omloopmogelijkheid
Tja...... als we nu toch bezig zijn ...... laten we het dan maar zo maken dat Chicago Union ook "autonoom" kan draaien .....
De complete opstelling, incl. twee BB-panelen en rok. In deze opstelling kan er gerangeerde worden en kan de baan thuis (of op beurzen ed in Denemarken) autonoom gebruikt worden
Van links naar rechts:
- linker uithaalbak
- linker verlengbak
- linker BB
- inbreng
- rechter BB
- rechter verlengbak
- rechter uithaalbak
De rechter kant
(Sorry voor de draaiing
Het rechter uithaalspoor en het achterlangs omloopspoor
Een overzichtje van de rechter kant
De linkerkant. Helaas lukt het enkel om het spoor "in het gebouw" naar de achterkant te halen. Het zou nog mooier / leuker zij indien het spoor voor het gebouw ook naar het achterspoor zou kunnen gaan, maar dat worden wel hopeloos krappe bogen
Hier is te zien dat ook het gebouwspoor al redelijk versleept moet worden om naar achteren te komen
En de oplossing aan de achterkant. De uithaalbakken zijn in principe vrijdragend. Maar die kunnen, voor de zekerheid, met lijmklemmen aan de naastgelegen bak geklemd worden
Eerst maar even wachten totdat de Benarolie weer een beetje is opgedroogd.
Laatst bewerkt op: 18 March 2018, 19:25:00 door guest7823
nighttrain1
Team Beurzen en PR
Reactie #308 Gepost op:
18 March 2018, 19:20:09 »
Wat een gaaf idee Paul! Geniaal
@ Eelco, jij wordt zo wel heel erg verwend, vind je niet?!?
Bouw:
Modelbaan
modulebakken
Pauze
Reactie #309 Gepost op:
18 March 2018, 19:21:57 »
Laat ik het zo zeggen, er vinden regelmatig Nederlands-Deense sparringsessiesplaats
De bedoeling was om de hele zooi in april op te halen, maar het lijkt er veel op dat ik dan moet staken. En dan mag je niet op vakantie....
nighttrain1
Team Beurzen en PR
Reactie #310 Gepost op:
18 March 2018, 19:40:07 »
Citaat van: NS8714 op 18 March 2018, 19:21:57
zooi
Mooie spullen zul je bedoelen!
Bouw:
Modelbaan
modulebakken
guest7823
Reactie #311 Gepost op:
18 March 2018, 19:44:56 »
Hou het, gemakshalve, maar op "zooi"
Eelco en ik weten wat d'r inmiddels allemaal in de Hwp Rtd ligt wat naar Denemarken moet.........
Simon Stenneberg
Dieselpower rules!
Reactie #312 Gepost op:
18 March 2018, 21:30:14 »
Wel vernuftig, maarre, is het niet eenvoudiger om het te verlengen met een tweede, eventueel kortere, modulebak?
Diesel- en smalspoorliefhebber. Modelbaan: Grensstation Broeksittard-Tüddern met Selfkantbahn (H0m) en ZLSM (H0):
https://forum.beneluxspoor.net/index.php?topic=90136.msg3222058526#msg3222058526
Edsko Hekman
Nooit uitgeklust....
Reactie #313 Gepost op:
18 March 2018, 21:57:45 »
Dan nog blijft de wens van velen om ook zelfstandig rondjes te kunnen gaan rijden.
Mooie oplossing.
Graag nog wel wat detail foto's van de bevestiging. Als ik nu helemaal wild ga denken, kun je zo ook helemaal achterlangs en op verschillende baantjes rangeren. Maar ik vrees dat er dan ook een dienstregeling voor achterlangs moet komen. Daarnaast is er nog een "beperking" in de vorm van de formelen opstelbakken.
Desalniettemin, prachtige oplossing.
Grasland
guest7823
Reactie #314 Gepost op:
18 March 2018, 22:44:00 »
“Achterlangs rijden” is lang geleden al begraven. Forget about it.
Modulebaan.nl
