Hlv53
om 08:22:13
om 08:17:33
Hans Grasmaijer
om 07:40:53
13 en 14 december PFT-TSP naar Aachen
om 01:02:37
DJV
18 January 2026, 23:30:25
Station Arnhem jaren '80'
RICROO
18 January 2026, 22:34:52
18 January 2026, 22:26:14
Whis
18 January 2026, 22:17:19
DJV
18 January 2026, 21:56:03
18 January 2026, 21:43:53
18 January 2026, 21:39:29
Rolf S
18 January 2026, 21:35:21
Gare de Tannay, Frans N-spoor
Wim1969
18 January 2026, 21:22:06
18 January 2026, 21:11:20
664470
Die Bahn
18 January 2026, 20:43:26
18 January 2026, 20:13:14
18 January 2026, 19:38:53
Elotrains Plan K pimpen.
18 January 2026, 19:28:44
18 January 2026, 18:48:49
Openen Piko 1100 "botsneus"
Hennie
18 January 2026, 18:07:25
phdirk
18 January 2026, 17:11:54
Maarten-1-14
18 January 2026, 16:43:37
18 January 2026, 16:30:10
ES44C4
18 January 2026, 16:21:20
18 January 2026, 16:02:53
Tjalling
18 January 2026, 15:45:12
18 January 2026, 15:30:56
18 January 2026, 15:17:22
Trix DXI van DC naar AC
18 January 2026, 14:48:44
roco
18 January 2026, 14:34:31
NL-baan in Canada
Topic: NL-baan in Canada (gelezen 160629 keer)
Eens komt het goed.
Re: NL-baan in Canada
Reactie #585 Gepost op:
02 July 2025, 10:29:44 »
Mooie aanwinst!
Misschien nog wat vervuilen.
Reactie #586 Gepost op:
02 July 2025, 21:44:10 »
Vervuilen is niet echt mijn ding en met een witte ketelwagen al helemaal niet
Arjan
NL baan in Canada
https://forum.beneluxspoor.net/index.php?topic=71130.msg3221692419#msg3221692419
Reactie #587 Gepost op:
19 October 2025, 03:45:20 »
Dit weekend de goederenloods vervangen. De kartonnen Markenburg loods vervangen door een Tilly loods. De verlichting moet nog aangesloten worden.
NL baan in Canada
Reactie #588 Gepost op:
19 October 2025, 05:53:18 »
Dat ziet er perfect uit Arjan.
Groet, Ed
Mijn modelbaan in Thailand
Video-ritten DB
einte
Tijdperk II - III
Reactie #589 Gepost op:
19 October 2025, 07:48:37 »
Hallo Arjan, mooi geheel geworden!
Mooie foto!
Groeten Einte
Mijn draadje
Reactie #590 Gepost op:
19 October 2025, 12:06:03 »
Die is heel fraai ingepast!
Moest je daarvoor nog veel aanpassen rondom of hebben de loodsen exact dezelfde maten?
Pfarrerwinkel de bouw:
Pfarrerwinkel
Reactie #591 Gepost op:
19 October 2025, 14:21:38 »
De voetprint van bijde loodsen is niet hetzelfde. de Tilly loods is iets langer en smaller. Eigenlijk het enigste was om aan de rechterkant een stukje “straat plaat” te verwijderen. Dat was een Faller foam plaat en makkelijk te verwijderen. Tussen de bestaande bestrating en de loods moest ook nog een strip Faller foam ingepast worden. Maar daar zie je verder niks van.
Het spoor voor de loods heb ik ook opnieuw geballast.
Omdat alles op zacht woodlands railbedding foam ligt was alles vrij rap los en weg.
Ik had eerst nog het idee om nog een spoor aan de voorkant van de loods te maken maar daarvoor moest de hele laad en los weg op de schop en dat was me te veel werk.
Arjan
NL baan in Canada
AndrevdG
Reactie #592 Gepost op:
20 October 2025, 11:03:22 »
Mooi gedaan !
Twentelijn 1968-1980
Reactie #593 Gepost op:
20 October 2025, 11:10:40 »
Fraai!
Wat was er mis met de Markenburg-loods (ik heb niet teruggelezen)?
Reactie #594 Gepost op:
20 October 2025, 11:26:34 »
Met de Markenburg loods was in principe niks mis. Maar soms wil je weleens iets anders
NL baan in Canada
Reactie #595 Gepost op:
21 October 2025, 02:17:48 »
Toch nog ergens een woodlands just plug kastje gevonden voor de verlichting van de loods. De sterkte lijkt feller dan in de werkelijkheid. Denk te veel leds op elke string. Misschien dat de stroom bron opsplitsen nog wat verbetering opleverd. Voorlopig is het goed
Ondanks dat ik alles getest had voor het afwerken en dak er oplijmen deed 1 lampje aan het laad perron het niet. Gelukkig 1 waar ik net bij kon en alternatief kon aansluiten.
Laatst bewerkt op: 21 October 2025, 02:47:01 door ArjanB
NL baan in Canada
de hondsrug baan
Reactie #596 Gepost op:
21 October 2025, 08:42:00 »
Hoi Arjan,
Heel mooi gedaan ziet er geweldig fraai uit moet er ook maar eens mee aan de gang (volgende stap) .
mvg Evert en Bas
AndrevdG
Reactie #597 Gepost op:
22 October 2025, 14:22:21 »
Mooie beschaafde, niet overheersende belichting !!
NL-baan in Canada
