Betrouwbare Stroomafname met Trix C-Rail door Floris Dilz
Vandaag om 00:01:16
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
28 January 2026, 19:55:14
28 January 2026, 19:42:00
Auteur Topic: Bezet/terugmelder maken  (gelezen 4685 keer)
christiaanw
  • dcc
« Gepost op: 17 February 2016, 11:13:30 »
ik wil mijn spoorbaan gaan programeren.
is er de mogelijkheid om zelf een bezet/terugmelder te maken?
mvg Christiaan
Re: Bezet/terugmelder maken
« Reactie #1 Gepost op: 17 February 2016, 11:31:59 »
Ja, dat kan. Als je voldoende kennis van zaken hebt is het zelfs vrij eenvoudig.
Maar de vraag is wat voor soort bezetmelder je wil hebben.
eric10nl
    • OV Website
« Reactie #2 Gepost op: 17 February 2016, 11:40:43 »
kijk eens op de site Rosoft http://rosoft.info/.
Hier kun je van alles vinden.
Tegenwoordig volgens mij nog alleen nog gebouwd leverbaar. Maar even een mail naar Wim, hij kan je alles vertellen.
Eric
H0 (Fleischmann Profi), IB, Loconet, S88 en I-train
« Reactie #3 Gepost op: 17 February 2016, 13:01:29 »
Alles kan  ;D
Neem eens een kijkje in de encyclopedie
Vindt je diverse voorbeelden van detectieschakelingen en wat er meer bij komt kijken.
Gr.
Eric
HansQ
  • Daar waar de rook is, is de kortsluiting...
« Reactie #4 Gepost op: 17 February 2016, 13:20:27 »
Als je zelf wilt solderen, kijk dan es hier, ook goeie uitleg (en een hele mooie modelbaan): http://www.floodland.nl/aim/info_bmd16n_1.htm
HansQ, RailClub Utrecht
gvandersel
  • Als het maar elektrisch is.
    • Homepage Gerard van der Sel
« Reactie #5 Gepost op: 19 February 2016, 15:36:57 »
Vanaf hier wordt er door een forumgenoot een gemaakt.
Gerard van der Sel.
Holzburg (IIIb/IVa) schaal N.
christiaanw
  • dcc
« Reactie #6 Gepost op: 20 February 2016, 23:15:36 »
Bedankt allemaal,
Heb inmiddel een startset bij wim gekocht alleen weet ik niet hoe ik de bezetmelder moet aansluiten op de rails ;D
ChristiaanW
krab
  • N spoor dat spoort
« Reactie #7 Gepost op: 21 February 2016, 00:02:19 »
Zoiets misschien Christiaan
http://people.zeelandnet.nl/rosoft/s88SD16-n_handboek.pdf
m.v.g. Sjaak
Zie ook mijn baan op n-spoorforum.nl
« Reactie #8 Gepost op: 21 February 2016, 10:52:53 »
@Christiaan
Zou er ook geen handleiding bij de startset zitten  ::)
Zoals Sjaak aangeeft kan je die ook gewoon downloaden en anders even wachten tot je e.e.a. geleverd hebt gekregen  ???
Uit je andere draadje blijkbaar geen handleiding bij de koop gekregen?
Beetje slordig.
En dat van Wim die al gauw roept "lees de handleiding".
Of zit er een verwijzing bij dat je de handleiding van zijn site kan downloaden.
« Laatst bewerkt op: 21 February 2016, 10:55:26 door Remunj »
Gr.
Eric
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #9 Gepost op: 21 February 2016, 22:02:03 »
Inderdaad Eric,
Lees de handleiding, en die kun je gewoon online lezen zonder deze uit te printen, kost geen inkt en ook geen extra papier.
Op de factuur staan de url's.
Mvg
Wim.
eric10nl
    • OV Website
« Reactie #10 Gepost op: 22 February 2016, 09:58:07 »
Christiaan,
Zoals Wim schreef de handleiding staat op zijn site met foto's erbij.
De eerste keer is het misschien wat lastig, maar zeker te doen.
Zie dat je pas 14 bent, dus snap best dat het lastig is. Soms moet je dingen gewoon even zien.
Je kunt altijd even een PM sturen.
Heb er al voldoende aangesloten.
« Laatst bewerkt op: 22 February 2016, 10:00:26 door eric10nl »
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #11 Gepost op: 22 February 2016, 13:06:52 »
Ronaldk
« Reactie #12 Gepost op: 22 February 2016, 13:14:42 »
Ik denk het probleem zit in: Hoe maak ik de draadjes aan de rails vast? ;) Of niet Christiaan? Het meest eenvoudige is het solderen van de draadjes aan de rails. Dan heb je meteen een goede verbinding. Is het de eerste keer dat je iets soldeert: Oefen even op een oud stukkie rails en wat losse draden ;)
Succes!
Groeten Ronald.
christiaanw
  • dcc
« Reactie #13 Gepost op: 22 February 2016, 13:35:32 »
Bedankt  voor uw reactie Ronald ik ga het proberen
Verstuurd vanaf mijn Hol-U19 met Tapatalk
christiaanw
  • dcc
« Reactie #14 Gepost op: 22 February 2016, 13:40:33 »
Is dit een goede aansluitschema?
