NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
Betrouwbare Stroomafname met Trix C-Rail door Floris Dilz
Vandaag om 00:01:16
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
28 January 2026, 19:55:14
Auteur Topic: Bezet/terugmelder maken  (gelezen 4691 keer)
gvandersel
  • Als het maar elektrisch is.
    • Homepage Gerard van der Sel
Re: Bezet/terugmelder maken
« Reactie #15 Gepost op: 22 February 2016, 13:43:24 »
Perfect, als je tenminste de blokken 3 en 4 opdezelfde manier aansluit  ;D (y)
Je kunt nu in twee richtingen door je blok heen rijden.
Gerard van der Sel.
Holzburg (IIIb/IVa) schaal N.
christiaanw
  • dcc
« Reactie #16 Gepost op: 25 February 2016, 12:44:58 »
Bedankt allemaal voor de reactie  ik heb hem aangesloten het werk met koloper en ik kan handmatig rijden.
ik heb nu een blok gemaakt alleen weet ik niet hoe ik de bezetmelder in koploper krijg.
heb al een handleiding uitgeprint (zeer duidelijke handleiding)
alleen als de trein op 1.1 komt zou die moet reageren alleen dat doet die niet.
weet iemand hier iets meer van?
mvg Christiaan W
« Reactie #17 Gepost op: 25 February 2016, 13:11:46 »
Dan is het dus een kwestie van de handleiding volgen  ;D
Staat het echt in hoe je dat moet doen.
Waarschijnlijk nog niet alles ingevuld en/of goed opgestart.
Maar voor dit soort vragen is het handiger om die gelijk op het koploperforum te stellen.
kan je er ook je database bijvoegen zodat we in detail kunnen kijken.
Gr.
Eric
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #18 Gepost op: 25 February 2016, 22:32:47 »
Beste Christiaan,
Hier vind je de juiste instellingen voor Koploper te samen met de s88xPressNetLI
http://www.rosoft.info/KoploperXPressNetLI.html
Koploper begint dan niet bij punt 1.1 te tellen maar bij punt 65.1
Anders gezegd 1.1 is 65.1 als je dat invult zal koploper de meldingen zien en doen wat jij verwacht.
Mvg
Wim.
christiaanw
  • dcc
« Reactie #19 Gepost op: 26 February 2016, 13:18:37 »
Beste Wim,
Ik heb het precies zo gedaan.
Hij gaf net wel aan 1.1 en 1.2 bezet in blok 1.
Alleen in het testprogramma doet hij het niet.
Mvg Christiaan W
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #20 Gepost op: 26 February 2016, 13:38:20 »
Beste Christiaan,
In testprogramma zal hij ook de punten of melders 1.1 en 1.2 niet aangeven als de s88xPressNetLi met de default instellingen gebruikt.
Wil je de melders in testprogramma zien werken dan zul je naar beneden moeten scrollen in het vak met getallen en dan zo ver dat de nummers 65.1 en verder in beeld zijn. Koploper geeft alleen de getallen op het scherm weer die in focus zijn.
Mvg
Wim.
christiaanw
  • dcc
« Reactie #21 Gepost op: 26 February 2016, 15:47:59 »
Beste Wim,
Vriendelijk bedankt voor uw hulp hij werkt.
MVG Christiaan W
