Heroplage Artitec Plan W? door Peter J K
Vandaag om 01:10:07
Rondom Charlois door NS264
Vandaag om 00:40:06
Pantografen mDDM door Deetrein
Vandaag om 00:36:43
Vandaag om 00:27:57
Miniature Project in Noordwijk ,wat is dit voor bedrijf? door Duikeend
Vandaag om 00:21:11
Faller 2026 door Floris Dilz
Vandaag om 00:13:44
Bouw van tijdperk 1 HSM en SS rijtuigen door Rob Bennis
27 January 2026, 23:25:28
27 January 2026, 23:23:59
Dubbele keerlussen in schaduwstation door RobVille
27 January 2026, 23:19:28
27 January 2026, 23:13:48
27 January 2026, 23:12:30
Interesse stamtafel/club Amersfoort? door Huib
27 January 2026, 22:58:24
17 mei Modelspoorbeurs Houten door Quinzeedied
27 January 2026, 22:11:15
27 January 2026, 22:03:24
Artitec 2026 door arnout
27 January 2026, 21:48:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door Quinzeedied
27 January 2026, 21:39:02
19 Toen door Ferdinand Bogman
27 January 2026, 20:55:10
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robert vh Prutsert
27 January 2026, 20:38:40
Molenbaan (werktitel) door basjuh1981
27 January 2026, 20:32:50
Altbau e-loc BR163 zelfbouwen in H0 door Frits C
27 January 2026, 20:21:19
Reysburg H0 (NL TP 5/6) door Chiel
27 January 2026, 19:52:15
Länderbahn en Reichsbahn locomotieven. door Ronald69
27 January 2026, 19:36:39
Positie anti-slipbanden bij zes-assige draaistel locs (Roco, DC, H0) door Klaas Zondervan
27 January 2026, 19:35:55
DaisyII door Steven Loosman
27 January 2026, 19:30:06
PIKO 2240 71096 uit de doos! door Ben
27 January 2026, 19:12:01
27 January 2026, 18:52:49
SIK Roco 72012 snelheid ijken Itrain door Steven Loosman
27 January 2026, 18:50:24
Jouef BB9201 anno 1968 door saskia
27 January 2026, 18:48:38
Plan N van Heris. door Edsko Hekman
27 January 2026, 18:35:09
Model cipressen in 1:87 door Sven
27 January 2026, 18:12:17
Auteur Topic: MARDEC, de Multifunctionele ARduino dcc DECoder.  (gelezen 415749 keer)
Goosie
    • www.henkdegans.nl
Re: MARDEC, de Multifunctionele ARduino dcc DECoder.
« Reactie #60 Gepost op: 15 February 2016, 14:58:54 »
Heb er nog even flink mee gespeeld, en ik moet zeggen dat ik dit zeer bruikbaar vind!
Niet alleen voor de servo aansturing, maar ook om verlichting of wat dan ook ergens op de baan te schakelen.
Mooi stukje werk van jou Nico! (y)
Ga vandaag wat opto's bestellen om de dcc aansturing uit te testen.
bdw. misschien wel goed te vermelden in de handleiding dat als je de servo's extern voeding geeft, de gnd van arduino en externe voeding verbonden moeten zijn! Anders doet hij het ook echt niet, en schiet tegen mechanisch eind aan!
« Laatst bewerkt op: 15 February 2016, 15:38:41 door Goosie »
Henk de Gans
Rieks
  • Helemaal opnieuw begonnen
  • Fiat Voluntas HrMs Poolster A835
« Reactie #61 Gepost op: 15 February 2016, 16:42:00 »
Hoi Nico,
Ik zal die aanpassing deze nog even testen
Beloofd is beloofd.
Ik heb net even de MM versie in een arduino geladen en voorwaar je kunt dan gewoon de ingegeven adressen invoeren in de MM.
Dit geld ook voor z/Z21. Die heeft dezelfde roco afwijking.
Blijft natuurlijk wel zo dat je nu twee versies moet onderhouden.
Mvg Rieks
Listen very carefully, I shall say this only once.
Cetero censeo birrum  bibendum esse
NTeering
    • ARduino Controlled MOdel RAilway
« Reactie #62 Gepost op: 15 February 2016, 17:38:42 »
@Henk,
Ja ik zal dat opnemen en in het aansluitschema vermelden. Wel zo duidelijk.
@Rieks,
Mooi dat het werkt.
Twee versies onderhouden? Nou liever niet.
Ik kan wel bij de eerste opstart vragen of je de MM of z/Z21 gebruikt en dan het adres aanpassen.
Hebben jullie eventueel ook interesse in het kaartje van Servé of Erwin?
Nico
Rieks
« Reactie #63 Gepost op: 15 February 2016, 19:55:37 »
Hallo Nico,
die opstartvraag zou prachtig zijn dan is dat probleem uit de wereld.
Niet iedereen denkt eraan (ik was er zelf ook al weer ingetrapt).
Voor wat betreft de printjes ik bestel een paar universele schroefconnectorprinten eventueel met servoconnector.
Voor de power heb ik een oude voeding die 5 12 -12 en 24 volt kan leveren.
Mvg Rieks
Fritsprt
« Reactie #64 Gepost op: 15 February 2016, 19:59:22 »
Hallo Nico,
Ik wil wel 2 kale printen kopen.
gr. Frits
Groet Frits
Goosie
    • www.henkdegans.nl
« Reactie #65 Gepost op: 16 February 2016, 10:25:39 »
Nico
Op dit moment nog niet, moet er zelf nog even over nadenken hoe ik het een en ander ga plaatsen op de baan. Ik zelf vind het namelijk handiger om de decoders aan de buitenzijde van mijn baan te monteren zodat ik er zicht op heb(is moduul actief enz).Hier een filmpje van mijn baan tot op heden https://youtu.be/ZbxsafN5cjA Dat zou in dit geval betekenen dat ik er eerder voor zou kiezen een shield te maken wat alle aansluitingen richting een centraal onder de baan gemonteerde verdeelprint brengt. Ik wil julie ook nog wijzen op een mooi open source software pakket met de naam Fritzing http://fritzing.org/home/. Hiermee kun je niet alleen mooie optische plaatjes maken van de arduino met aansluitingen, maar ook pcb ontwerpen maken.
Henk de Gans
Suchet
  • G5
« Reactie #66 Gepost op: 16 February 2016, 11:53:52 »
Ik heb ook wel belangstelling voor twee plaatjes, bij voorkeur inclusief de benodigde (chinese) onderdelen.
Rob
Engelse banen zijn gewoon.....  anders
NTeering
« Reactie #67 Gepost op: 16 February 2016, 11:55:25 »
Hallo Henk,
Je bent al aardig op weg met je baan. Door al dat Arduino geprogrammeer bestaat mijn baan alleen nog maar in Anyrail.
Afgezien van het testbaantje dan: http://forum.beneluxspoor.net/index.php?topic=63567.0
Alles aansluiten via een centraal verdeelpunt levert natuurlijk wel veel langere kabels op naar de servo's.
Kan misschien een probleem worden.
Fritzing kennen we wel, maar ik ben er (nog) niet erg handig in.
En over het jitteren vond ik nog deze tip:
Jitteren tegen gaan kan ook door simpel een weerstand van 4k7 op te nemen tussen de signaal draad en de +. Een smd weerstand kan vaak precies tussen de pennen van de connector.
Gerard van der Sel.
Nico
NTeering
« Reactie #68 Gepost op: 19 February 2016, 16:21:00 »
Bij deze het correcte plaatje zoals beloofd:
mvg
Nico
Goosie
    • www.henkdegans.nl
« Reactie #69 Gepost op: 20 February 2016, 19:11:54 »
Ik heb hem aan de gang mbv dcc!
Ik heb alleen pin 3 nog maar geconfigureerd als servo, maar ik kan nu op mijn centrale de servo aansturen  :)
Nu de komende weken nog wat verder experimenteren, heb al wat goedkope arduino's bij besteld bij mijn Chinese vrienden ;D
Zie een kort filmpje van mijn vorderingen op : https://youtu.be/Vzcaj-Et1vk
« Laatst bewerkt op: 20 February 2016, 19:29:45 door Goosie »
Henk de Gans
NTeering
« Reactie #70 Gepost op: 20 February 2016, 19:23:06 »
Hallo Henk,
Dat is hartstikke mooi! (y)
Nico
NTeering
Re: MARDEC II, de Multifunctionele ARduino dcc DECoder.
« Reactie #71 Gepost op: 24 February 2016, 13:34:47 »
De MARDEC is weer verbeterd!
Met een hoop gepuzzel om binnen de maximale programmagrootte van 32.256 bytes te blijven is er nu de MARDEC II.
Hierin zijn een paar bugs opgelost en nieuwe mogelijkheden toegevoegd.
Het volgende is nieuw:
 • Drie extra accessory-opties:
   1) Flikkerlicht optie. Hiermee kan bv vuur of een laslicht worden gesimuleerd. De minimale en maximale lichtsterkte zijn uiteraard instelbaar.
   2) Random on/off. Hiermee kan bv het willekeurig aan en uit gaan van binnenverlichting worden geregeld. De minimale en maximale aan en uit tijden zijn instelbaar tussen 2 en 500 seconden.
   3) Disco lights. Hierbij gaat een aangesloten led een willekeurige, korte tijd (20-500 milliseconden) aan en uit. Ook hier zijn de tijden weer instelbaar.
• Terug naar configuratiestand middels reset knop op Arduino indien het DCC circuit het (nog) niet doet.
• Mogelijkheid tot correctie van de adres offset bij Roco centrales (MM, z/Z21)
Daarnaast zijn er de volgende wijzigingen:
• Er hoeft geen pin meer gekozen te worden voor de puntstukpolarisatie. Deze wordt automatisch toegewezen als je kiest voor puntstukpolarisatie.
• Ook bij de accessory's waarbij twee pinnen nodig zijn wordt deze 'buddy'-pin automatisch toegekend.
De nieuwe downloads:
Handleiding MARDEC II decoder
Alle MARDEC II software inclusief de Arduino IDE 1.6.6
MARDEC Installatie handleiding (volledig)
MARDEC II software zonder Arduino IDE
Deze moet je gebruiken als je de vorige versie al een keer hebt geïnstalleerd of de Arduino IDE al hebt.
Verwijder eerst de USB kabel alvorens de installatie te starten en gebruik dezelfde USB poort.
Installatie handleiding (MARDEC only)
Alleen CH340 drivers
Deze zijn nodig als je een Chinese Arduino hebt. Ze worden ook mee geïnstalleerd bij de volledige en update installatie.
De MARDEC II is geheel compatibel met de vorige versie. Je hoeft dus niet eerst te resetten en alles opnieuw te configureren.
Succes,
Mvg
Nico
« Laatst bewerkt op: 24 February 2016, 13:36:29 door NTeering »
bentomiz
« Reactie #72 Gepost op: 24 February 2016, 14:26:27 »
Hola Nico, tegen het einde van het jaar hoop ik zover te zijn met de digitalisering te kunnen beginnen,en was blij verrast jouw Arduino mogelijkheden te hebben ontdekt want daar was ik naar op zoek.
Zelf ben ik een onbenul opelectronica maar dacht het te kunnen redden met het leren van de " arduino taal" , heb ook ng maar weinig idee wat ik nodig heb allemaal.
Had al wel n arduino beginnersset gekocht en wat geleerd. Ben n marklin jongen die voor het eerst in 55 jaar zijn baantje kan uitleggen omdat ik nu de ruimte heb.
werk metde oude m rails en reageer omdat ik nu zie hoe jij je programma uptodate houdt en uitbreid.
Ik wileven laten weten dat ik dat heelerg mooi vindt en over n tijdje met waarschijnlijk heel veel "domme" vragen zal komen
Groet vanuit Arenas
Martin Rummens
Goosie
    • www.henkdegans.nl
« Reactie #73 Gepost op: 27 February 2016, 16:33:15 »
Hallo Nico,
Ik heb de update gedownload en uitgepakt in de arduino directorie.
Vervolgens installmardec.cmd uitgevoerd, en na dat ik de compoort heb aangegeven start de installatie.
Ik krijg dan een foutmelding dat er in ieder geval een schetsbestand moet opgeven.
Daarna wordt installatie afgebroken met een foutmelding.
Enig idee wat hier fout gaat?
gr
Henk
ps de schets staat wel in de editor, en heb ik daarvandaan geïnstalleerd.De configurator geeft echter foutmelding dat hij com 8 waar de arduino aan zit niet kan openen
« Laatst bewerkt op: 27 February 2016, 16:38:17 door Goosie »
Henk de Gans
NTeering
« Reactie #74 Gepost op: 27 February 2016, 17:37:00 »
Hallo Henk,
Voor alleen de sketch-update was het op zich voldoende om alleen de nieuwe MARDEC.ino te openen in de editor en te uploaden.
De drivers werkten immers al.
Met de installMARDEC.cmd gaat het uiteraard ook, maar dan moet je wel  exact de handleiding volgen (HowToInstall.pdf)
Alle bestanden worden dan vervangen en je krijgt dan dus ook de nieuwe handleiding geïnstalleerd.
Maar ik begrijp dat je de upload nu inderdaad vanuit de editor gedaan hebt.
Als putty.exe (de configurator) de com-poort niet kan openen kan dat twee oorzaken hebben:
1) De com poort is niet de juiste. Dat kun je eventueel aanpassen in de putty settings
Kontroleer ook de com-poort in de Windows configuratie
2) de com poort is 'bezet' door de Arduino IDE of iets anders. Maar dat is eigenlijk alleen tijdens het uploaden.
Kijk ook eens in de handleiding: Overige zaken -> problemen.
Succes,
Nico
