Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Delft: cabinerit van Delft-zuid naar D-aansluiting (14-01-2015)  (gelezen 17818 keer)
Sander.
« Gepost op: 15 January 2015, 15:13:47 »
Voor de liefhebber.....:
Nu het nog kan een cabine rit van Delft Zuid naar Delft aansluiting.
14-01-2015
Cabine rit Delft: http://youtu.be/H55MF_e4KzI
Mvg
Sander
« Laatst bewerkt op: 15 January 2015, 15:21:25 door Bert van Gelder. Reden: Titel aangepast »
Re: Delft: cabinerit van Delft-zuid naar D-aansluiting (14-01-2015)
« Reactie #1 Gepost op: 15 January 2015, 16:22:59 »
Mooi, Delft zoals je het als reiziger nooit ziet.
Het sein op het eind van het perron is wel apart, met de groene lamp in het midden.
Sander.
« Reactie #2 Gepost op: 15 January 2015, 17:23:53 »
Klaas ea,
Groen in het midden is nog niet zo heel uniek. Dat komt wel meer voor. Het aparte is in mijn ogen juist dat dat  hoge sein zijn naam niet echt eer aan doet....
Hoe dan ook, een mooi stukje spoor (bekijk de gebouwen en gevels maar eens goed) staat op het punt te verdwijnen. Na het Rotterdamse luchtspoor en de Hofpleinlijn wordt ook dit vervangen door een betonnen put.
(Alle begrip voor natuurlijk, maar uit het oogpunt van Eisenbahn Romantiek blijft er nu bar weinig meer over in ons land)
Mvg
Sander.
« Reactie #3 Gepost op: 15 January 2015, 19:24:53 »
Ik weet het, dat groen in het midden stamt nog uit de tijd dat een sein ook dubbelgeel kon tonen. Het lage hoge sein staat er ook al heel lang. Ik heb daar lang geleden eens "misbruik" van gemaakt om het op te meten.
Toen ik voor het eerst in Delft kwam waren ze juist bezig met de bouw van dat viaduct. Het spoor van Den Haag naar Delft liep toen al over het viaduct, het andere spoor lag nog laag. En nu gaat dus alles onder de grond.
« Reactie #4 Gepost op: 15 January 2015, 19:58:44 »
Als oud Delvenaar leuk om te zien.
Kom er alleen nog voor familiebezoek en dan kijk je links of rechts naar buiten.
Wel een uniek stuk spoor.
Eerst op maaiveldniveau (heel vroeger nog langs het water).
Toen omhoog.
En binnenkort (volgens planning eind Februari) omlaag. Komt ook de oude singel weer terug  8)
Hebben we alle smaken wel gehad  ;D
En dat lage hoge sein staat er sinds mensenheugenis. Stukje perronkap wat anders in de weg staat  ;D
Gr.
Eric
dh3201
« Reactie #5 Gepost op: 16 January 2015, 09:26:34 »
Nog vroeger door het water (per trekschuit) ?  ;D
rjz222
    • Treinenwereld.eu
« Reactie #6 Gepost op: 16 January 2015, 11:29:42 »
Een sein met een groene lamp in het midden komt uit de tijd dat er ook vierhoogseinen geplaatst werden. Die bestaan nu niet meer, maar die seinen konden dubbel-geel tonen, en om dat dubbel geel duidelijk te maken, zaten de gele lampen zo ver mogelijk van elkaar: boven en onder.
Zie ook http://nicospilt.com/lichtseinen.htm en scroll dan door naar 'Volgorde van de kleuren'.
Peter Kleton
« Reactie #7 Gepost op: 16 January 2015, 11:49:00 »
 Het is afgelopen met het bekijken van de oude stad ,
Geen Kapper Zonder Afspraak, en geen Wasmiddel Zonder Fosfaat. :)
 Ik vraag me wel af ,of de singel weer terug komt.
 Men zal wel heel graag willen parkeren daar .
 Peter
NS 1924-heden.
« Reactie #8 Gepost op: 16 January 2015, 12:41:13 »
Volgens de planning wel:
Tussen Phoenixstraat en Spoorsingel komt een singel, aan de kant van de Spoorsingel. Onder de singel komt een ondergrondse parkeergarage met ongeveer 650 plaatsen.
geplukt van www.spoorzonedelft.nl
Gr.
Eric
TimoD
« Reactie #9 Gepost op: 16 January 2015, 13:23:37 »
Mooie beelden van Delft!  :D
Wat mij opviel is dat bij 1:07 er een (hoog) sein staat, met een cijferbak aan de paal, en daarvoor ook nog zo'n bak. Weet iemand waarom die dubbel is? (heeft dat misschien te maken met goederentreinen en de komende tunnel?)
Timo
Machinist Johan
  • gevorderd beginner
« Reactie #10 Gepost op: 16 January 2015, 14:06:17 »
Dat is inderdaad een sein met cijferbak en losstaande X/G regimebord voor goederentreinen
Sander.
« Reactie #11 Gepost op: 16 January 2015, 14:30:20 »
... mocht het zo zijn dat ik bij daglicht nog een keer in de andere richting rijd, dan zal ik daar ook een filmpje van proberen te maken...
Is toch leuk voor over tig jaar in het draadje 20toen   :)  (y)
Mvg
Sander.
Peter Kleton
« Reactie #12 Gepost op: 16 January 2015, 14:33:41 »
Heel goed Sander!
Denk wel aan het tegenlicht dat je hebt in die rijrichting.
 Mss 's morgens doen of anders als er geen zon is?
 Sukses,
 Peter
NS 1924-heden.
Corny121
« Reactie #13 Gepost op: 16 January 2015, 15:24:23 »
Ondertussen wordt er ondergronds druk geoefend door de hulpdiensten deze weken..
PKM
    • Trainsandtrucks.nl
« Reactie #14 Gepost op: 16 January 2015, 15:41:59 »
Erg leuk om te zien!
