Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Baanplannen
Servé's baanplan, 3,65m x 2,05m H0
Topic: Servé's baanplan, 3,65m x 2,05m H0 (gelezen 8421 keer)
Servé
Team encyclopedie
Niks kan tippen aan een E1700
Re: Servé's baanplan, 3,65m x 2,05m H0
Reactie #30 Gepost op:
16 September 2013, 11:56:35 »
Vergeten te vertellen
Is een FiddleYard
Vriendelijke groet, Servé.
De Stoker
H0 - TC - Digirails - KL 8.2 1920-1950
Reactie #31 Gepost op:
16 September 2013, 12:21:00 »
Maar dan moet je aan de voor kant toch de sporen kunnen benaderen?, of wordt het 1 grote fiddle yard, zo ja waar heb je dan ruimte om je treinstellen heen en weer te schuiven? om voor het toegangsspoor uit te komen en de draaischijf?
Gtrz
Gerwin
Station Eibergen
Station Eibergen - Digitaliseren
Servé
Team encyclopedie
Reactie #32 Gepost op:
16 September 2013, 12:36:33 »
Het wordt 1 grote fiddle-yard. Alleen de linker 4 sporen hebben toegang tot de draaischijf en het stukje uithaalspoor, de 4 rechter sporen niet. Ik kan de fiddle-yard zo ver schuiven zodat elk spoor verbonden kan worden met het toegangsspoor. Snappez-vous?
Krokodil68
Reactie #33 Gepost op:
16 September 2013, 12:45:19 »
plankjes met rail en dan twee optilbeugels zodat je ze desnoods op een plank hoger kunt zetten is ook een optie. Je kunt toch maar met 1 trein tegelijk wegrijden. de plankjes kan je dan op een hogere plak of alleen dragers wegleggen. Link.
http://www.eisenbahnecke.de/flb05.htm
effe iets omlaag scrollen. is een leuk idee.
Groeten Jeroen
Leubachtalbahn
https://forum.beneluxspoor.net/index.php?topic=77672.msg3221814460;topicseen#msg3221814460
Servé
Team encyclopedie
Reactie #34 Gepost op:
16 September 2013, 12:48:41 »
Het kan aan mij liggen, maar ik snap 'm niet helemaal? Het is de bedoeling dat alles vrijwel automatisch gaat straks via koploper.
Servé
Team encyclopedie
Reactie #35 Gepost op:
28 October 2013, 14:40:16 »
Tijdje stil geweest, maar binnenkort ga ik met de modelspoorhobby verhuizen van de kelder naar een kamer op de tweede etage en daar moet een nieuw baanplan voor gemaakt worden.
Dit is een eerste schets.
Links is het kopstation met v.l.n.r. de sporen 1, 2, 3 en 4. Spoor 1, 3 en 4 liggen aan het perron, spoor 2 is voor goederen.
Ook deze baan staat in het teken van veel rangeren, lokwissels etc.
Vragen/Suggesties? Graag!
[edit] Ik heb gezien dat er nog 1 wissel op een module-overgang ligt, dat wordt tijdens de bouw opgelost [/edit]
Laatst bewerkt op: 28 October 2013, 14:44:38 door Servé
Reactie #36 Gepost op:
28 October 2013, 18:07:25 »
Miss een idee om is in de tekening te laten zien,wat wat moet worden ?
Wat wordt zichtbaar,wat komt bv bij de sporen aan bedrijven te staan,zit er nog hoogte verschil in/schaduwstation enz enz.
En wat is dat voor een rare spoor constructie rechtsboven in ,aan het buiten spoor/doodlopende rechte spoor
Servé
Team encyclopedie
Reactie #37 Gepost op:
28 October 2013, 19:52:57 »
Rood = perron
Groen = perron voor arbeiders
Paars = tunnelingang, dus de 5 sporen helemaal links zijn niet te zien.
Ik heb een spoortje naar een fabriek aangelegd, ligt ongeveer op + 10 cm hoogte. Er zal hier alleen goederenvervoer zijn en zo af en toe de DE2 die de arbeiders naar het werk brengt.
Nog andere suggesties/vragen?
Marc Riswick
Reactie #38 Gepost op:
29 October 2013, 02:13:58 »
Ik zou het wissel naar de fabriek wat verder omhoog leggen. Nu heb je een perron van ca 35 cm, daar past geen DE2 langs.
Marc
Servé
Team encyclopedie
Reactie #39 Gepost op:
29 October 2013, 11:26:43 »
Het perron is 45 cm, daar past die DE2 toch wel langs?
SuperSylvester
Reactie #40 Gepost op:
30 October 2013, 18:49:02 »
Hey medeLimbo
Ik ben nog niet zo thuis in rangeer en opstelsporen, wat ik me afvraag wat is de functie van
het middelste spoor tussen de perrons in het station rechts? Of stel ik nu een hele domme vraag
Jack
Groeten, Jack. Don't only practice your art, but force your way into it's secrects. For it, and knowledge can raise man to the Divine - Ludwig Van Beethoven
Servé
Team encyclopedie
Reactie #41 Gepost op:
30 October 2013, 18:53:22 »
Hoi Jack,
Op dat spoor komen de goederentreinen binnen. Die worden dan van een nieuwe lok voorzien en vertrekken dan weer
SuperSylvester
Reactie #42 Gepost op:
30 October 2013, 18:58:34 »
Ja natuurlijk! vandaar die Engelsman met dat stukje spoor. Capito!
Baanplannen
