Schaal TT
T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Inrijbaan 240x120cm
02 February 2026, 16:29:13
Van en voor gebruikers
Wim Mesu
(Moderator:
WimM
BNLS Werkspoor - Mesu models NS 2000
Topic: BNLS Werkspoor - Mesu models NS 2000 (gelezen 410158 keer)
rolfm
Re: BNLS Werkspoor - Mesu models NS 2000
Reactie #675 Gepost op:
23 October 2019, 23:19:00 »
Wim, hartelijk dank voor de update.
Alle vertrouwen in dat dit een hele mooie en doordachte kit wordt
En top dat je je vrije tijd en energie in dit spoor 0 project wilt steken
Groeten Rolf
Team Mitropa
Reactie #676 Gepost op:
23 October 2019, 23:40:21 »
Het zit er al prima uit zo te zien
Reactie #677 Gepost op:
24 October 2019, 07:58:16 »
Hoi Wim, je bent een tijdje weggeweest begrijp ik. Blader even door je persoonlijke berichten voor het antwoord op jouw PB aan mij van 7 september jl.
Mvg, Paul
WimM
Moderator
Reactie #678 Gepost op:
26 October 2019, 14:58:51 »
Ik ben niet weggeweest, alleen ziek en druk nog met Oersikken (is nu klaar).
Als je niet direct antwoord krijgt op mails/pb's wil niet zeggen dat ik je vergeten ben. Als ik overal direct op antwoorden moet is er van voortgang van het project geen sprake meer.
Dus er is vooruitgang.
Als het zover is ben ik van plan iedereen die geïnteresseerd is een mail te sturen met specifieke vragen wat men wil en hoe m.b.t. NS600/2000 in 0
(Ik doe af en toe stiekem ook nog wel eens iets anders dan modeltreinen, niet verder vertellen hoor. Schande.)
WimM
Moderator
Reactie #679 Gepost op:
30 November 2019, 19:01:35 »
Eindelijk weer eens een update betreffende de stand van zaken m.b.t. de spoor O loc.
Het ontwerpwerk is al een tijd geleden "afgerond" en allerlei materialen en onderdelen voor de eerste paar locs zijn besteld en ontvangen.
Ik ben nu keihard bezig om een aantal draaistellen (aandrijvingen) klaar te maken en het prototype te voorzien van de bijpassende draaistel-zijkanten. Zo hoop ik dat ik volgende week Zaterdag 7 December op de beurs in Houten het één en ander kan laten zien i.v.m. de vooruitgang.
Het ontwerp van de aandrijving is vrij eenvoudig van opzet, aanpasbaar voor verschillende motoren en bruikbaar voor zowel 1 op 45 als op 1 op 43.5. Het bestaat uit 2 stukken freeswerk en 2 lasercut delen, met één motor in het draaistel, welke beide assen aandrijft. Dus alle assen zijn aangedreven. Ik heb wat gespiekt bij SB in Duitsland op het gebied van spoor O en ik denk dat de loc met 2 aangedreven draaistellen goed zal rijden.
Het stel draaistel-zijkanten die ik nu zelf maak zijn 1 op 45 (omdat het prototype ook deze schaal heeft).
Voor de 1 op 43.5 schaal versie (meer klanten) heb ik een 3D ontwerp klaar om te gebruiken voor het messinggieten. Het wordt een universeel ontwerp, dus 4 stuks per loc.
Hierbij een foto van deel van het 3D ontwerp van dit onderdeel.
Ziet er wel aardig uit hè. Nog een weekje doorpezen
Reactie #680 Gepost op:
30 November 2019, 21:56:39 »
Dat ziet er goed uit Wim, ik ben benieuwd naar het plaatje van de complete aandrijving. Ik vermoed dat je een motor met twee aseinden wil gebruiken met aan elke kant een worm en wormwiel op een tussenas die met een wielas is verbonden met de eindoverbrenging. Dat is althans wat ze bij SB zouden doen.
Succes met het harde werk,
Paul
Team Mitropa
Reactie #681 Gepost op:
30 November 2019, 22:33:57 »
Dat gaat de goede kant op Wim
moonlicht
Reactie #682 Gepost op:
01 December 2019, 11:17:07 »
netjes, ben benieuwt naar de verdere voortgang
hellaas kan ik niet naar houten, zit dan nog op mijn werk.
maar wat of wie is nu BS, bij mij gaat er zo geen lichtje branden
Cor
WimM
Moderator
Reactie #683 Gepost op:
01 December 2019, 19:13:34 »
Geen BS maar SB. (aandrijvingen in Duitsland)
Bert van Gelder
Reactie #684 Gepost op:
01 December 2019, 19:38:04 »
Een kleine zijstap, sorry Wim...:
Reinout, dit draadje is gemeld als zijnde een van de draadjes waar afbeeldingen ontbreken. Kunnen we de "_removed"-truc nog toepassen, of moeten we wachten tot een/jouw scriptje gedraaid heeft?
Andere mod, Bert
Draadje was/is gemeld aan de mods)
WimM
Moderator
Reactie #685 Gepost op:
01 December 2019, 21:26:15 »
Hallo.
Ik heb nu net in dit NS2000 draadje 2 van de minst oude foto's, die er niet meer waren of beschadigd (o.a. op pagina 17), naar beste weten kunnen kopiëren van andere locaties op de site.
Ik heb de orginele foto's niet meer: crash.
Idem voor "Photobucket" foto's in het begin van de draad. Ik kan er niet meer in. Kunnen jullie er nog wat aan doen?
Groet Wim Mesu
Team forummoderators
Forummoderator
Reactie #686 Gepost op:
01 December 2019, 21:32:26 »
Het is me een kwartiertje geleden gelukt om uit m'n lokale kopie van de database te krijgen dat er 391 berichten zijn waar de "_removed" truc is toegepast. Dus... dan krijg ik de rest van de info er ook wel uit. Normaliter zou ik zeggen dat de boel binnen een paar dagen wel hersteld is.
Edoch, ik wil sinterklaassurprises maken voor vrijdagavond en gezien mijn normale megalomanie wat dat betreft.... Ergens halverwege volgende week?
Photobucket: dáár kan ik niets aan doen.
Reinout-als-systeembeheerderprogrammeurhersteldingus
Bouw v/d EifelBurgenBahn
(h0, zijlijn in de Eifel)
Eifelgeschiedenis
Modelspoor is emotie...
Reactie #687 Gepost op:
01 December 2019, 22:21:09 »
Je aftiteling doet me een beetje denken aan de Duitse omschrijving voor rangeerder:
‘ Eisenbahnknotenpunkt-hin-und-her-Schieber....’
Rob
Tbinnebarretije…
rolfm
Reactie #688 Gepost op:
09 December 2019, 13:53:12 »
Marcel Geurtjens is in Houten op bezoek geweest bij Wim Mesu om de vorderingen te bekijken van de NS2000 in spoor 0
Hij heeft oa foto's gemaakt van de aandrijving. Ziet er allemaal veelbelovend uit
Voor de plaatjes en aanvullende info kijk op
https://www.spoornul.nl/forum/viewtopic.php?f=8&t=817374&start=15
onderaan de pagina.
Met dank aan Marcel.
Groeten Rolf
WimM
Moderator
Reactie #689 Gepost op:
04 February 2020, 04:06:40 »
Ik zou jullie op de hoogte houden van vorderingen. Helaas gingen de vorderingen niet zo snel als ik gehoopt had.
Ik heb een set draaistel zijkanten gefabriceerd voor de 1 op 45 loc. Maar dat duurde een maand langer dan gedacht.
Zodoende heb ik stevig door gepeesd en heb ik geen tijd gehad voor het maken van goede foto's. En zonder foto's heb je er ook niet veel aan.
Ik heb de draaistel-binnenwerken met de motoren/aandrijvingen klaar gemaakt en met draaipunten onder de loc aangebracht.
Daarna de draaistel zijkanten aangebracht. De loc staat dus nu op eigen "benen".
Het zie er best al aardig uit.
Wat nog ontbreekt op de foto zijn de stekkerdozen, de handrails aan het front en eind van de loc, de trekhaak-koppelingen, de luchtslangen en nummerplaten.
Ik ben daar nu al weer een eind mee gevorderd.
Nummerplaten moet ik nog laten etsen. Een cabine interieur moet er ook nog in. En iets om de doorkijk in de motorhuiven te voorkomen. En spuiten enz.
Het elektrische gedeelte moet ik nog aan gaan pakken, stoomafnemers en verlichting enzovoorts.
Ik heb in het ene draaistel een Faulhaber 1331 motor en in het andere een Canon motor. Ik weet nog niet zeker of de loc met 2 van de laatst genoemde goedkopere motoren het gaat trekken.
Er is dus vooruitgang. Nog effe volhouwen........
Met vriendelijke groeten,
Wim Mesu
Wim Mesu
(Moderator:
WimM
