Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: LS models ICRm  (gelezen 244517 keer)
Petertrein81
  • Taurus en Vectron fan!!
Re:LS models ICRm
« Reactie #765 Gepost op: 14 April 2012, 11:42:39 »
En ik denk niet dat LSModels een heel nieuwe bak laat maken om 1 cijfertje van amper 3 mm hoog....
......Wat ook nog amper te lezen is als de trein op snelheid is.
En de vitrineliefhebbers kunnen gewoon het goede nummer naar de zichtkant zetten.
Groet Peter,
  • NS 1607 Vlissingen
  • Zal 't gaan, ja!
    • Tramlijn Maastricht-Vaals
Re:LS models ICRm
« Reactie #766 Gepost op: 14 April 2012, 11:55:22 »
Al iemand foto's van de BF?
Jos.
En was 1680 cm Lang
(Rotterdam, 2009)
    • Het Groterdam Project
Re:LS models ICRm
« Reactie #767 Gepost op: 14 April 2012, 12:03:10 »
In ieder geval vanavond.  8)
Re:LS models ICRm
« Reactie #768 Gepost op: 17 April 2012, 01:24:51 »
Nee, met wat vertraging : NU ! :)
Duvel
Re:LS models ICRm
« Reactie #769 Gepost op: 17 April 2012, 09:59:51 »
Chris, hoe verhoudt de vorm van de nieuwe ICRm BD zich tot die van de Benelux BD?
Met vriendelijke groeten, altijd.
Brs
    • Mat'89
Re:LS models ICRm
« Reactie #770 Gepost op: 17 April 2012, 10:28:11 »
@Duvel: Je bedoelt de kromming? Ik heb zelf inmiddels ook de Benelux ICRm BD en ik heb totaal geen last van een lichte knik zoals de foto's hier tonen.
Duvel
Re:LS models ICRm
« Reactie #771 Gepost op: 17 April 2012, 10:43:57 »
Dat bedoelde ik idd. Ik heb destijds een stuk of vier Benelux BD's bekeken, en die hadden het allemaal wel...
Re:LS models ICRm
« Reactie #772 Gepost op: 17 April 2012, 11:19:22 »
Nope, nu netjes recht, ik heb hem op zijn kop gezet :)
Duvel
Re:LS models ICRm
« Reactie #773 Gepost op: 17 April 2012, 11:20:51 »
Da's mooi!  (y)
Heb je het ooit nog met LS over de Benelux gehad?
Re:LS models ICRm
« Reactie #774 Gepost op: 17 April 2012, 11:21:53 »
Nou een email gestuurd. Daar heb ik geen antwoord op gehad.
Maar ik zie ze in Dortmund. Zal ik er eens over babbelen.
kar
Re:LS models ICRm
« Reactie #775 Gepost op: 17 April 2012, 11:48:55 »
Ruim de helft aan gratis bakken is NOOIT bij de winkeliers opgehaald....
Hetzelfde voor de Knabbel en Babbel met pesoneel ivp personeel van gutzold destijds. Ook die kapjes werden NIET afgehaald.
Ik denk dat daarin twee zaken meespelen:
1) afhankelijk van de zichtbaarheid van de fout zal de koper besluiten of hij de moeite wil nemen om de kap te vervangen (waarbij ik persoonlijk een prominente fout in klasse-aanduiding vervelender zou vinden dan een klein nummertje)
2) de bekendheid die de leverancier en modelbouwwinkels aan de omruilactie geven. Met dank aan dit forum kwam ik erachter, maar ik heb ook diverse modelspoorders gesproken die hier totaal geen weet van hadden.
Overigens dikke pluim voor de beide omruilacties, zowel van de BLX als de Knabbel & Babbel.
/Henk
Henk | H0 | Rocoline | Z21 | iTrain 5.1 icm Mac
Peter Korsten
Re:LS models ICRm
« Reactie #776 Gepost op: 17 April 2012, 12:26:15 »
Anders wat, stel dat je drie stammetjes B-A-B, een BD, een Bf en een BDs hebt (nog niet, zou onderweg moeten zijn), maakt het dan nog wat uit in welke volgorde die staan, of kan dat allemaal door elkaar.
(Dit is dus volgens mij de samenstelling zoals die begin jaren '00 tussen Noord-Holland en Limburg reed.)
- Peter
  • Zal 't gaan, ja!
Re:LS models ICRm
« Reactie #777 Gepost op: 17 April 2012, 13:46:43 »
En als de tafel nou krom is, dan weet je nog niks.  ;D ;D ;D ;D
Jos
En was 1680 cm Lang
(Rotterdam, 2009)
  • Lid Houtense Koekenclub
  • Spoor N
Re:LS models ICRm
« Reactie #778 Gepost op: 17 April 2012, 18:39:26 »
(Dit is dus volgens mij de samenstelling zoals die begin jaren '00 tussen Haarlem en Verweg* reed.
*aangepast naar bestemming
Dat reed door elkaar, de stammen werden pas na 2005 samengesteld. 11 ICR met een DDM-1 Bv was ook mogelijk.
spoorfan
Re:LS models ICRm
« Reactie #779 Gepost op: 17 April 2012, 19:25:16 »
Een vraagje voor de specialisten onder ons. Ik mis volgens mij de fietspictogrammen boven de deuren aan de D en f kant. Of heb ik het mis?? Nu zitten ze er wel, toen niet (periode zonder drukknoppen voor het openen van de deur).
Spoorfan
