Ondervloer Fleischmann Profi door Peter J K
16 February 2026, 23:37:58
16 February 2026, 23:29:50
Ertstreinen in HO door ES44C4
16 February 2026, 22:44:16
16 February 2026, 22:40:31
16 February 2026, 22:25:54
16 February 2026, 22:07:14
Kranenberg, een exercitie in code 70 door meino
16 February 2026, 22:06:13
16 February 2026, 21:36:05
16 February 2026, 21:24:51
Toon hier je nieuwe (model-) spooraanwinst(en)... door Charles_
16 February 2026, 21:03:59
Intercity in brand bij Woerden 16-2 door Charles_
16 February 2026, 20:59:35
Randstadrail halte Voorburg ‘t Loo door phdirk
16 February 2026, 20:44:35
De bouw van mijn modelbaan in Thailand door André 1976
16 February 2026, 20:29:42
16 February 2026, 20:12:16
hoe vind ik iets terug op dit forum door Besselspoor
16 February 2026, 19:47:48
Lasersnijder voor karton door Huib
16 February 2026, 19:14:37
16 February 2026, 19:04:18
16 February 2026, 18:49:17
Welke decoder is dit? door Martijn1974
16 February 2026, 18:49:11
16 February 2026, 18:40:55
16 February 2026, 17:50:35
NS-Kameel in Spoor-0 (en misschien in Spoor-1) door Frank 123
16 February 2026, 17:49:45
Piko Diesellok D&RGW 4000 (97456-1) + SmartDecoder XP (56500) door VAM65
16 February 2026, 17:02:42
16 February 2026, 17:00:23
16 February 2026, 16:20:50
Goppenstein (CH) ontsporing (16 februari 2026) door Reinout van Rees
16 February 2026, 16:09:57
HTM PCC tram en wat gefrutsel er bij door Huibert
16 February 2026, 16:07:17
16 February 2026, 14:22:12
De bouw van Wesley's H0 baan door Arjan6511
16 February 2026, 14:21:36
Line-up foto's van modellen door Jelmer
16 February 2026, 14:17:59
Auteur Topic: Ronald’s nieuwe project: Endstation der Linie: “Bahnhof Poggendam  (gelezen 456774 keer)
Reeks77
  • Rhb is Cool !! HOm Bernina
Re: Ronald’s nieuwe project: Endstation der Linie: “Bahnhof Poggendam
« Reactie #870 Gepost op: 14 November 2020, 09:38:29 »
Alles eromheen en dingen die er bij horen is nog steeds genieten , regelmatig lees ik dingen terug ,van hoe zat het ook weer .
Dus nog steeds een grote like , of de onzichtbare like knop aangezet !!.
Ronaldk
« Reactie #871 Gepost op: 14 November 2020, 16:57:04 »
Dank!  (y)
Na de bovenbouw verder met de fundering. Het wordt een betonbak met daarover roosters. Hoe dat uit gaat pakken is nog even de vraag. De tankplaat bouw ik op uit MDF.
Poggendam-2020-027
Een ontwerpje gemaakt. In basis hetzelfde principe als bij de overwegen. Met een gat erin om de bak te creeëren. De bodem is een dunner plaatje MDF. Het ontwer met de snijder klaar gemaakt. Dan krijg je deze onderdelen waar we mee aan de gang gaan.
Poggendam-2020-028
Dan het spoor op blokken in de bak.  Ik had nog even een gedachte om het op te lossen zoals Artitec het had gedaan bij zijn inspectieputten.  Alleen die oplossing heeft heel veel frustatie opgeleverd. Iedere keer op jacht naar het goede gaatje voor de haken. Dat maar niet.  Ik had nog een stukje "betonspoor" liggen. Deze kan mooi gebruikt worden. Door het middendeel van de dwarsliggers er tussenuit te zagen. Dan ook nog aan de zijkanten een stuk eraf. Dan krijg je meer een beeld van een spoor op betonblokken.
Poggendam-2020-029
Eerst maar eens een proefplaatsing en kijken of het een beetje uitziet. Daar kwam de gedachte dat 2x 4mm te dik is. Ik had de gedachte dat het net zou kunnen door de opbouw. Goed, dat bleek niet zo te zijn. Net een millimeter te hoog. Dus even een 3mm bodem snijden. Die had ik niet meer gekleurd liggen. Dan maar even zelf op kleur brengen.
Poggendam-2020-32
Poggendam-2020-030
Aan de gang maar. Roco zaagje en dremel zijn dan je beste vrienden ;) Het spoor aanpassen.  Toch al wat bezig met de roosters. Ook een deel zeflbouw. De randen zijn van styreen, het gaas en de traanplaat zijn messingplaatjes. Dat was ook even kijken dat we in het midden geen sluiting veroorzaken. De messingplaten zijn iets minder breed dan de randen. Dan moet ik geen kortsluiting krijgen.
Poggendam-2020-033
in de put zelf maar eerst even de blokken voor de roosters plaatsen.
Poggendam-2020-034
Poggendam-2020-035
Daar rusten de roosters op. Inmiddels ook aardig met de roosters bezig geweest. Deze nu even passen voordat ik ze verder afwerk.
Groet Ronald.
  • Duitsland TP III/IV
« Reactie #872 Gepost op: 14 November 2020, 17:08:05 »
Ronald,
Je bent weer goed bezig.
Grt, Ronald.
Rolando
  • Modelspoorbaan Fleischmann
  • Het kind in jezelf blijven
« Reactie #873 Gepost op: 14 November 2020, 18:14:35 »
Erg gaaf om te zien wat jij allemaal zelf maakt met de 3d printer en ook de rest vanuit een tekening en knutselen maar.
Inspirerend om te volgen en ook weer dingen te leren.  (y)
Groet van Roland
Mijn HO analoge Fleischmann modelbaan volgen  : http://modelspoorbaan.jouwweb.nl/
Ronaldk
« Reactie #874 Gepost op: 14 November 2020, 18:41:00 »
@Ronald69 en Rolando: Dank  (y)
Geen 3D-printer ... Meer iets van een (laser)snijdertje...  :) Dat zijn twee hele verschillende apparaten.  ;)
Groet Ronald.
Ronaldk
« Reactie #875 Gepost op: 15 November 2020, 13:08:53 »
Verder met de verlichting.
In de abri wil ik iets van een TL-bak maken. Simpel van een profieltje met twee SMD-leds en en doorzichtig buisje.
Poggendam-2020-036
Poggendam-2020-037
Monteren in de abri. De draadjes langs de zijkanten naar beneden. In de fundering zitten al een paar gaten om de draden door te leiden.
Poggendam-2020-038
De pomp is inmiddels voorzien van een kleurtje. Dan de pomp voorzien van de led. Dat past allemaal net.
Poggendam-2020-039
De ruitjes zijn inmiddels geplaatst. Dat ging nog vrij gemakkelijk. De boel maar eens op de plek zetten en testen of alles wil branden. Het dak moet nog vast gezet worden.
Poggendam-2020-040
Na het vast zetten van het dak is het ding klaar om op de baan te zetten. Moet nog wel de draadjes even aan te passen door netjes een printje en een stekkertje aan te freubelen.
Poggendam-2020-042
Poggendam-2020-041
Groet Ronald.
« Reactie #876 Gepost op: 15 November 2020, 15:25:05 »
Een geslaagd project  (y)
  • Modelrailroading is fun!
    • Team USA Metusa Junction
« Reactie #877 Gepost op: 15 November 2020, 15:50:08 »
 (y) (y)
« Reactie #878 Gepost op: 15 November 2020, 16:00:34 »
De bouw is al in de zomervakantie begonnen… ik vond het nu
maar eens tijd om het een ander hier op het forum te zetten. Ik kijk...
Word het niet is tijd om Bert van Gelder te
vragen de topictitel te wijzigen in...
Ronald's langdurige project: Endstation der Linie: “Bahnhof Poggendam"
Mvh Steef
« Reactie #879 Gepost op: 15 November 2020, 16:17:02 »
 ;D ;D :) ;)
« Reactie #880 Gepost op: 15 November 2020, 17:04:38 »
Hahaha, lol.  ;D
Rolando
« Reactie #881 Gepost op: 15 November 2020, 18:17:07 »
Zelfs met het laser snijertje is het toch knap allemaal (y)
Mooi geworden en wat een gepriegel, maar het is het wel waard.
Zo maak je wel iets unieks wat alleen op jouw baan staat.
Groet van Roland
Ronaldk
« Reactie #882 Gepost op: 15 November 2020, 19:12:34 »
Hoi  ;D
Die had ik kunnen verwachten Steef  ::)  ;D  ;D Ben al lang weer blij dat ik weer wat aan het prutsen ben... Probeer nu wat jij altijd roept "Een half uurtje per dag geeft vorderingen" dus iedere dag wel iets te doen. Wat aan bouwen. Niet altijd zin gehad om nog op zolder bezig te zijn als je daar een hele dag gezeten hebt .... Nu komt die zin gelukkig weer.... Gewoon projectjes afvinken. Als het goed is krijg ik binnenkort het spul van Kotol binnen. Dan kan de verlichting ook geplaatst worden.
Groet Ronald.
  • DB Tijdperk III
« Reactie #883 Gepost op: 15 November 2020, 20:29:03 »
De pompinstallatie ziet er goed uit (y)
Die Sauerlandbahn
Mijn YouTube-kanaal
Ronaldk
« Reactie #884 Gepost op: 17 November 2020, 17:08:41 »
De laatste loodjes voor de tankplaat.
Nu is het inbouwen in de baan. Eerst de exacte locatie te bepalen. Dan is het verwijderen van de oude rails en de ondergrond. Daardoor kom ik op de juiste hoogte uit voor het inbouwen.
Poggendam-2020-043
Poggendam-2020-044
Even passen en meten:
Poggendam-2020-045
Dan ook weer een ondergrond aanbrengen bij de betonbielzen. Achteraf had ik de MDF ondergrond iets moeten laten doorlopen. Dat is iets minder geklooi met een klein stukje ondervloer. Straks zie je daar niets meer van  :)
Poggendam-2020-046
Wat gaten boren voor de verlichting en de aansluitingen van de rails. Dan kan ik ook zien wat er onder de baan gebeurd. Er lopen al wat kabels daar. Een klein beetje geluk geeft een precieze passing tussen de draden. Dat gaat nog wat worden met de plaatsing van de lichtmasten :)
Poggendam-2020-047
De boel aansluiten en dan even testrijden:
Poggendam-2020-048
Weer een stapje verder .... Nu de rest van de omgeving afwerken.
Groet Ronald.
« Laatst bewerkt op: 17 November 2020, 19:31:57 door Ronald Koerts »
