Modelspoordagen VERPLAATST naar 7 & 8 maart 2026 door Frank 123
Vandaag om 00:23:35
Vandaag om 00:22:18
Vandaag om 00:18:20
Rondom Charlois door Benelux795
08 January 2026, 23:45:54
Thanks, Chat door Quinzeedied
08 January 2026, 23:34:07
08 January 2026, 23:24:58
Hoek van Holland - Warschau, samenstelling in model. Welke rijtuigen? door Huibert
08 January 2026, 22:39:54
08 January 2026, 22:34:06
MaTrix 2026 door hmmglaser
08 January 2026, 22:33:49
08 January 2026, 22:09:34
08 January 2026, 21:54:45
Bouw NTM Stationsgebouw Lemmer door gdh
08 January 2026, 21:52:38
Wat is een redelijk goedkope dcc sein decoder? door meino
08 January 2026, 21:49:32
De Hofstraat in Eindhoven (1:160) door Mitchell
08 January 2026, 21:26:48
Treinen afstellen door Hans1963
08 January 2026, 20:43:24
08 January 2026, 20:40:29
Diesellok DB221 donor motor door Freddy
08 January 2026, 20:36:12
08 January 2026, 20:35:13
08 January 2026, 20:00:04
Minitrix wissels verbranden door Patrick1977
08 January 2026, 19:54:43
Digikeijs DR5000 Centrale, vragen en antwoorden door Ben
08 January 2026, 19:36:57
08 January 2026, 19:16:12
NZH A 1001 - 1004 door Gerco van Beelen
08 January 2026, 19:12:41
stroomdoorvoer k rails door schipcas
08 January 2026, 18:58:54
08 January 2026, 18:15:18
Ombouw/Pimpen Bolle neuzen door Paulogic
08 January 2026, 18:00:19
Tandwielen Fleischmann BR 80 door Bert54
08 January 2026, 17:06:35
Leids spoor (voorheen Blauwpoortsbrug) door Gerco van Beelen
08 January 2026, 16:42:17
Botsing bij SGB 29-12-2025 door Reinier Z.
08 January 2026, 16:39:35
Aachenau West door wob
08 January 2026, 15:42:34
Auteur Topic: Schwarzburg-Neuffen-Bahn  (gelezen 4012770 keer)
Fleischmann94
  • Schönblick
  • 65 018
Re:Schwarzburg-Neuffen-Bahn
« Reactie #2100 Gepost op: 26 March 2010, 23:03:09 »
He Ruud
Mooi projectje die fabriek! (y)
En nog gefeliciteerd met nog een mijlpaal :D
MVG Nigel
Br 01, Br 50 662, Br 50, Br 64, Br 70, Br 80, Br 94 1730, Br 94 1613
V60, V100, V200, V168(br215)
E10, Br 103, E69
Köff
  • Wir bauen fur Sie!! 🇦🇹
  • Bahnfahren ist ÖBB !!! 🇦🇹
« Reactie #2101 Gepost op: 26 March 2010, 23:18:43 »
Hallo Ruud,
Geweldig man die 100000 hits op naar de 200000 hits met de prachtige baan en dito foto's. (y)
Proficiat!!!
Gr Chris
Gr Chris
Matheus 18
  • Nog iets te plat voor Profi.
  • poging tot Steentje bijdragen.
« Reactie #2102 Gepost op: 26 March 2010, 23:35:55 »
Ha, nu snap ik hem.
Het gaat hem om de kijkers, kon eventjes niet volgen.
Nogal een geluk dat deze niet allen van repliek geven op Ruud zijn topic, dan was dit gewoon niet meer te volgen.
Zoals het nu loopt is het best meegenomen.
Matheus.
Julien
    • Schwarzfelsen
« Reactie #2103 Gepost op: 27 March 2010, 08:39:53 »
Hoi Ruud,
Je bent weer prima bezig met de gasfabriek. Ik doe altijd veel ideeën op in jouw topic!
groeten,
Julien
Bezig met het bouwen van "Schwarzfelsen" in H0. Materiaal: Fleischmann / Roco / profi-rails / S88XPressNetLI / LDT Wisseldecoders / RocRail.
  • Schwarzburg-Neuffen-Bahn
« Reactie #2104 Gepost op: 27 March 2010, 14:31:48 »
Dank allemaal, en inderdaad op naar de 200.000.
Vanmorgen een tijdje bezig geweest met het kantoorgebouwtje van twee verdiepingen dat bij de gasfabriek moet komen. Het Faller-modelletje zat al in elkaar, en niet zo fraai gelijmd, dus het verouderen is dan wat lastiger.
Het onbehandelde gebouwtje:
Tussenfase behandeling (overigens de andere kant):
Eindresultaat:
Dit was dan nog maar één wandje. Op naar de rest :).
« Laatst bewerkt op: 06 November 2014, 16:48:55 door guest7823 »
« Reactie #2105 Gepost op: 27 March 2010, 14:45:15 »
Even op de baan gezet om te zien hoe het oogt. Is wel naar m'n zin, past qua uitstraling goed bij de rest van de gasfabriek:
« Laatst bewerkt op: 06 November 2014, 16:49:05 door guest7823 »
Basilicum
  • Prae-adviseur
    • Dönsdorfer Bauberichte
« Reactie #2106 Gepost op: 27 March 2010, 15:05:55 »
Dat verouderen gaat je goed af, Ruud.
Ik zou het kantoorgebouw omdraaien, zodat de trap aan de kant van de gasfabriek komt. Dat geeft een logischer beeld. De arbeiders hoeven tenslotte minder ver te lopen. De bovengrondse leiding ziet er goed uit. De bochten bij gasfabriek zelf kun je achterwege laten. Hoe minder bochten, hoe beter de vloeistof loopt. Ter verduidelijking een schetsje:
Basilicum
« Laatst bewerkt op: 06 November 2014, 16:49:14 door guest7823 »
« Reactie #2107 Gepost op: 27 March 2010, 15:20:45 »
Dank je, Basilicum. Het gebouwtje staat alleen voor de foto even zo. Ik had het plan het met de korte kant naar het spoor te zetten, dus met de trap naar de tanks toe. Maar eens zien als het helemaal verouderd is.
De bovengrondse leiding moet inderdaad nog aangepast worden, ter afwachting van de definitieve plek van de gebouwen. Ik heb overwogen hem felgeel te schilderen, zoals op de link die je postte, maar is dat niet te modern? Ik ga nog eens zoeken op andere jaren zestig-banen.
Johnnytrein
« Reactie #2108 Gepost op: 27 March 2010, 15:42:54 »
Dat wordt steeds mooier om te zien  (y)
Johnny
« Reactie #2109 Gepost op: 27 March 2010, 16:25:52 »
Ja, beetje bij beetje komt het eruit te zien zoals ik in m'n hoofd had.
Weer even tijd voor een trein.
Van de vijf diesels uit Dönsdorf zijn er twee doorgereden naar Schwarzburg:
« Laatst bewerkt op: 06 November 2014, 16:49:22 door guest7823 »
Bruce!!!
  • MK III
« Reactie #2110 Gepost op: 27 March 2010, 16:33:43 »
Ah , en wat zullen ze straks achter ze aan hebben? gemengde goederentrein?
Groet Bruce
Passat driver:)
« Reactie #2111 Gepost op: 28 March 2010, 17:56:10 »
Het hele kantoorgebouwtje geweatherd en neergezet zoals voorlopig het plan is:
« Laatst bewerkt op: 06 November 2014, 16:49:31 door guest7823 »
m de deugd
« Reactie #2112 Gepost op: 28 March 2010, 18:40:16 »
Hoi Ruud.
Zeer mooi gedaan.
Complimenten.
Martin
Jos001
  • N en G rijder
« Reactie #2113 Gepost op: 28 March 2010, 20:14:11 »
Ziet er prachtig uit hoor Ruud! Misschien iets meer ruimte tussen kantoorgebouw en grote tanks? Dan krijg je meer een binnenplaats idee.
Groetjes,
Jos
N-spoor, digitaal met TC
G-spoor, digitaal met LGB-MZS
RobbertJan
  • Mcn NSR Groningen.
« Reactie #2114 Gepost op: 28 March 2010, 20:35:55 »
Als of het er voor gemaakt is  (y)
Wederom super!
Gr.
Robbert Jan.
Cranmore Road. Brits 1:43,5
