Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Schwarzburg-Neuffen-Bahn  (gelezen 4035669 keer)
  • Schwarzburg-Neuffen-Bahn
Re: Schwarzburg-Neuffen-Bahn
« Reactie #12090 Gepost op: 05 April 2016, 19:32:22 »
Vandaag viel de nieuwe Miba spezial 108 op de deurmat. Een boeiende aflevering over allerlei combinaties tussen spoor en straat. Zeer aan te bevelen.
Info over de inhoud: https://shop.vgbahn.info/miba/shop/spezial+108-_3553.html
« Laatst bewerkt op: 05 April 2016, 21:51:22 door Ruud K »
« Reactie #12091 Gepost op: 06 April 2016, 11:09:49 »
Een tijdje terug ging het hier over een vrachtwagencombinatie van dit type, waar Brekina een aantal versies van heeft uitgebracht of binnenkort gaat uitbrengen:
Ik schreef toen dat het onderstaande model, met opdruk Deutsche Bundesbahn, waarschijnlijk niet realistisch was:
Nu zie ik in Miba spezial 108 een foto staan van dit type vrachtwagen met de opdruk: 'Im Auftrag der Bundesbahn'. Wel iets anders dan op het model van Brekina, maar dit soort opdrukken hebben dus wel degelijk echt bestaan.
Deze foto dateert uit 1957. Het is de eerste keer dat ik een foto uit de werkelijkheid zie van dit type oplegger uit tijdperk 3. De oplegger is wel iets anders dan die in model. De wagen heeft één as, in model twee.
« Laatst bewerkt op: 06 April 2016, 11:38:27 door Ruud K »
everh003
    • Spoor en Staal
« Reactie #12092 Gepost op: 06 April 2016, 12:52:58 »
En volgens mij 2 steunen minder aan de buitenkant.
De extra lente die dat oplevert zal wellicht de reden zijn voor een tweede as.
N-spoor, Aan het switchen naar een z21 Start.
Rotterdam
  • Von den Bergen bis zur See - Lokomotiven Halle P
« Reactie #12093 Gepost op: 06 April 2016, 13:46:33 »
Heeft met de tonnage te maken.
Borgward maakte lichte bestelwagons en lichte vrachtwagens
en Buessing het voornamelijk zware spul
ik denk dat die combinatie van de Borgward wellicht 3 of 4 ton is
en de Buessing heeft 15 of 20 ton,vandaar 2 assen
die MIBA ziet er goed uit.
die Kaelble met tandem assen is de Kaelble die de duikboten naar Zwarte Zee gebracht heeft
groetjes
willem
spoor N
Tijdperk DR/DB jaren 70
5 x 103 - 110--111-140-150-194-2 X 220 - 2 X 221-1 X 216- 2x 261 3x212-3 XV180-P8-T3
2 x V180 prototype 1 x 65.10 1 x 066 1 x Ueberland tram Arnold,1 x VT98,2 x VT Piko
« Reactie #12094 Gepost op: 06 April 2016, 20:55:25 »
Hier heb je een twee-asser, volgens mij Ep.III van het zuiverste water:
Nog eentje, maar ik weet niet of het een twee- of een enkelasser betreft:
« Laatst bewerkt op: 06 April 2016, 21:04:33 door 44 »
« Reactie #12095 Gepost op: 06 April 2016, 22:11:39 »
Prachtige foto's, Jan. Dank hiervoor (y).
Rotterdam
« Reactie #12096 Gepost op: 07 April 2016, 11:32:36 »
een vraag bij die prachtige foto's?
konden die trailers met kolen via zijkant lossen?
lijkt me dat ze niet via een grijper gelost konden worden ivm beschadigingen?
spoor N
« Reactie #12097 Gepost op: 07 April 2016, 14:59:35 »
Ik denk niet dat deze trailers met een grijper gelost worden. Of de hele bak kon kiepen, weet ik niet. Het zou kunnen; op de achterkant zit een constructie die daar op wijst. Op het model zie ik verder aan één zijde een soort trekstangen, die in verbinding staan met openingen in de bodem van de trechtervormige bak. Onder die hele bak door loopt een transportband en achteraan zitten hendels voor de bediening ervan. De achterzijde van de wagen kan bij een kuil of iets dergelijks geplaatst worden en dan worden de kolen door de openingen in de bodem via de transportband daarin gekieperd.
anha70
« Reactie #12098 Gepost op: 07 April 2016, 17:48:51 »
Er zijn zelfs bakwagens geweest met deze opbouw in de jaren 60   Kohlen-Kuli werden die wel genoemd
groet anha
lex stoom
  • Niet gehinderd door enige vorm van kennis
  • stoom en diesel
« Reactie #12099 Gepost op: 07 April 2016, 19:53:17 »
Als ik het goed heb is de officiele benaming bandlosser, gewoonlijk worden ze onderlossers genoemd.
kippen kunne ze niet, alles word aan de achterkant gelost met de transportband.
gr alex.
  • NS tijdperk II(c)/III
    • Obdam in h0
« Reactie #12100 Gepost op: 07 April 2016, 20:09:42 »
Kohlen-Kuli :)
Niet mijn land, wel mijn tijdperk. Vandaar dat ik dit toch met aandacht volg :)
« Laatst bewerkt op: 07 April 2016, 20:11:41 door Eric B »
Fotodijkje en fotodiorama
Obdam
« Reactie #12101 Gepost op: 07 April 2016, 21:35:04 »
Op die manier kon tamelijk nauwkeurig gedoseerd worden. Waarbij onder het begrip "kuil" ook de opening (luik) van de kolenkelder verstaan kan worden. In m'n eigen draadje heb ik dat al eens genoemd, en ook een paar links gegeven. Deze manier van distribueren kwam op als alternatief voor de kolen in zakken of bakken, die dan die eerder genoemde kolenkelder ingetild moesten worden.
HAR 67
« Reactie #12102 Gepost op: 07 April 2016, 22:32:11 »
In het kader van de brandstof vrachtauto's heb ik hier ook nog een foto. Enige weken geleden kwamen er bij ons in het dorprp 2 opel Blitzen tevoorschijn.  De oudste was van het eerste type bouwjaar 1953. Het schijnt dat deze tot in de jaren 90 nog in gebruik was.
Het is wel Nederlands maar toch.
« Reactie #12103 Gepost op: 07 April 2016, 23:04:30 »
Wat een lekker ding!
En wat een leuke lading ook!
jerrytrein
« Reactie #12104 Gepost op: 07 April 2016, 23:35:08 »
 (y)
heb je meer foto's
Denk dat dit een 4 cilinder 1700 motor had
de latere vierkantere meest een 6 cilinder
zal jan wel een copie  van hebben  :D
