VERPLAATST: Fleischmann v60 1380 hekjes vervangen door Duikeend
Vandaag om 02:45:17
Vandaag om 01:06:59
Upgrade van analoge Roco V200 loc naar DCC. door saskia
Vandaag om 00:40:48
Vandaag om 00:29:33
Vandaag om 00:19:16
US diorama in H0 door ArjanB
Vandaag om 00:09:11
10 February 2026, 23:45:27
10 February 2026, 23:36:59
10 February 2026, 23:25:02
Raadplaatje door Karben
10 February 2026, 22:40:39
10 February 2026, 22:38:07
10 February 2026, 22:28:13
10 February 2026, 22:01:44
10 February 2026, 21:48:11
10 February 2026, 21:46:22
10 February 2026, 21:28:16
10 February 2026, 21:22:06
Zermitz door maartenvdb
10 February 2026, 21:12:22
10 February 2026, 20:55:01
10 February 2026, 20:35:28
10 February 2026, 20:09:00
10 February 2026, 18:37:46
10 February 2026, 18:34:09
10 February 2026, 17:52:43
10 February 2026, 17:20:56
10 February 2026, 17:14:11
10 February 2026, 16:07:03
10 February 2026, 15:52:59
10 February 2026, 15:52:30
Z21 newGen door bask185
10 February 2026, 15:50:43
Auteur Topic: Ronald doet de Fork Challenge!  (gelezen 40024 keer)
  • Modelrailroading is fun!
    • Team USA Metusa Junction
Re: Ronald doet de Fork Challenge!
« Reactie #60 Gepost op: 14 July 2025, 20:31:02 »
Graag gedaan (y)
« Reactie #61 Gepost op: 16 July 2025, 11:14:23 »
Ok, rustig verder. Gisteren absoluut geen fut om iets te doen, de nachten trekken er toch aardig aan als je er een 6 voor hebt staan ;) Dus vandaag het lijf weer in het normale ritme zien te drukken.
De gelijmde poothouder was droog:
20250714_160211 by Ronald Halma, on Flickr
En even passen... eh:
20250714_160906 by Ronald Halma, on Flickr
Komt een oplossing voor ;)
De 2e eergisteren gedaan:
20250715_155339 by Ronald Halma, on Flickr
Modificatie set van Ronald:
20250715_204715 by Ronald Halma, on Flickr
Met tevens verlengingen van de daken.
De verhoging in de bak passen:
20250715_204750 by Ronald Halma, on Flickr
Past! Vanmorgen even proefpassen nadat de verhoging erin gelijmd is:
20250716_104245 by Ronald Halma, on Flickr
Aftekenen waar ik ga lijmen:
20250716_104338 by Ronald Halma, on Flickr
En lijmen! Paar dikke klemmen er op om het even goed vast te houden:
20250716_104611 by Ronald Halma, on Flickr
Straks weer meer uit dit theater! ;)
  • Eton Wick, UK
    • Ga naar de Tramfabriek
« Reactie #62 Gepost op: 16 July 2025, 13:06:47 »
Grappig. Zo'n modulair compact systeem had ik ook al bedacht. Het waren Ronald Koerts en Harald van Laserchef die me aangaven dat het met 3mm MDF te doen is, dus dat had ik hier gedaan. Dat gaat inderdaad prima. Maakt voor een licht en draagbaar systeem. Ik ben benieuwd of Ronald zich door mijn ontwerp heeft laten inspireren.
« Reactie #63 Gepost op: 16 July 2025, 13:10:32 »
Ja, mooi.
En dan weet je nooit of dat inderdaad zo is.
Het is wel een geëigende vorm.
Ronald Visser
« Reactie #64 Gepost op: 16 July 2025, 13:13:18 »
Kan ik je niet zeggen... tis gemaakt met wat ik als tekening aangeleverd heb  ;) En dit zie ik voor het eerst. Het had idd met dunner materiaal gekund en Ronald stelde 6 mm voor. Ikzelf gaf de voorkeur aan iets dikker dus 9 mm is het geworden.
Ik werk al met U-tjes sinds 2009 ;) En ik geloof niet dat ik de 1e was. Maar wel een van de weinigen toen. Het is een mooie bouwwijze en uitermate geschikt als het transportabel moet zijn. Kost meer ruimte maar eenvoudiger van opzet.
« Reactie #65 Gepost op: 16 July 2025, 15:47:15 »
Klaar! De bak zit als geheel aan elkaar en is geschuurd. Maar.... hoe ging dat? Komt ie!
Het 3e bakje moest nog in elkaar dus daar mee begonnen. Zelfde procedure als de andere 2:
20250716_133629 by Ronald Halma, on Flickr
Nu direct met dakverlenging:
20250716_135801 by Ronald Halma, on Flickr
In een versie 2.0 wordt dat 1 geheel.
20250716_135811 by Ronald Halma, on Flickr
Ophoog stukje plus poothouder er in:
20250716_141013 by Ronald Halma, on Flickr
Even passen. Klemstukje boven tijdelijk er in:
20250716_141446 by Ronald Halma, on Flickr
Dan gaan ze aan elkaar. Ik doe dat met slotbouten, moeren en de 4 klemstukjes:
20250716_143246 by Ronald Halma, on Flickr
De linkse en middelste aan elkaar:
20250716_144230 by Ronald Halma, on Flickr
En alle 3:
20250716_145135 by Ronald Halma, on Flickr
Voorkant:
20250716_145144 by Ronald Halma, on Flickr
Achterkant:
20250716_145212 by Ronald Halma, on Flickr
Onderkant:
20250716_150518 by Ronald Halma, on Flickr
Daarna alles even glad geschuurd met 180 in de mouse. Voorkant:
20250716_152030 by Ronald Halma, on Flickr
Kop linkerkant:
20250716_152042 by Ronald Halma, on Flickr
Schuin voorkant:
20250716_152050 by Ronald Halma, on Flickr
Ik ben tevreden! Paar kleine dingetjes die we nog moeten tunen en tweaken maar verder ziet het er meer dan prima uit!
Later meer!
« Laatst bewerkt op: 16 July 2025, 15:48:59 door Ronald Halma »
« Reactie #66 Gepost op: 16 July 2025, 16:01:12 »
strak  (y)
Pfarrerwinkel de bouw:
Pfarrerwinkel
Ronaldk
« Reactie #67 Gepost op: 16 July 2025, 16:10:54 »
Ha Sven,
Nee, ik heb geen inspiratie opgedaan bij jouw ontwerp. Ik heb inderdaad de tekening van Ronald H aangehouden.  Die heb ik eerst uitgewerkt. En Ronald H had wat ontwerpeisen. Daar maar eerst eens rekening mee gehouden. Daarna ben ik gaan uitkleden naar minder hout. In de eerste ontwerpversie zat nog wel wat meer hout dat is er nu inzit.
Zelf denk ik dat het ook wel met 6mm kan. Zelf heb ik een soort van bakkie met 6mm gedaan. Dat was een eerste experiment voor mij. Zonder fries / koof. Die gaat traditioneel met achterplaat. Eens zien hoe dat gaat. Goed Ronald H wilde graag 9mm. Nu is het wel mooi stevig. Nu kan je wat hout besparen door te zeggen bepaalde onderdelen gaan uit 6mm worden. Dan ga je wat in kosten omlaag.
Het bakje van jou in MDF ziet er goed uit  (y) Er zitten een paar goede punten in waarvan ik denk: "dat is interessant"  ;D
« Laatst bewerkt op: 16 July 2025, 16:17:13 door Ronaldk »
« Reactie #68 Gepost op: 16 July 2025, 16:26:56 »
Ofwel; beter goed gejat dan slecht verzonnen  ;D
6 mm had zeker gekund. Was het geheel ook wat lichter geworden. Maar het is nog steeds niet heel zwaar. Ik zal het vanavond eens wegen.
« Reactie #69 Gepost op: 16 July 2025, 17:30:24 »
Ik kreeg net een opmerking binnen dat het niet moeilijk zou zijn het model aan te passen aan de hout dikte.
Van 12 naar 9 en dan 6 mm is een kwestie van verschalen....... :angel:
Jammer,
Nee, natuurlijk niet.
Met het verschalen worden anders de buiten maten ook mee verkleind.
Het is dus uitgaan van de buitenmaten en daar de tabs op aanpassen naar gelang de hout dikte.
Soms wordt er wel heel gemakkelijk gedacht over ontwerpwerk en wordt vergeten hoeveel tijd je er feitelijk mee kwijt bent.
Ronaldk is er dan ook druk mee, maar levert mooi werk af.
Succes verder met het project.
Ronld Visser
« Reactie #70 Gepost op: 16 July 2025, 17:46:52 »
Tuurlijk is het niet moeilijk. Alleen was het van mij uit nooit de bedoeling dunner te gaan. 9 it is, 9 it stays :) Daar zit een filosofie (lees eigen inzicht) achter en het zal uiteindelijk in de kosten niet zo heel veel schelen.
Nu baanplan uit gaan zetten en de rest van het ontwerp inmeten. Tevens moeten er nog wat wandjes en schotjes ingemeten worden.
Later!
« Reactie #71 Gepost op: 16 July 2025, 20:39:51 »
Mooie bak geworden Ronald (en Ronald natuurlijk)  (y) (y)
Am Ende der Strecke
Den gamla sågverket (gepland)
« Reactie #72 Gepost op: 16 July 2025, 21:13:12 »
Dank u! We hebben de meeste dingen even doorgesproken en gaan het naast mijn bouwactiviteiten hier productierijp maken. Dus stay tuned!
« Reactie #73 Gepost op: 16 July 2025, 21:14:40 »
strak  (y)
Sorry, niet gezien ;) Dank je!
Lobomotion69
  • Confusius zei het al.
« Reactie #74 Gepost op: 17 July 2025, 02:52:27 »
OH?? Meen je dat nu echt? Weet nu niet wat dat spul in NL moet kosten maar hier kost een plaat van 3mm minder dan de helft van een plaat van 9mm. En het geheel bestaat alleen maar uit plaatmateriaal, ok en een heel klein beetje lijm.
Dus dat moet je me toch even uitleggen.
Ben het overigens wel met je eens dat 3mm erg dun is maar ook 6mm plaat is aanzienlijk goedkoper dan 9mm en, ook niet geheel onbelangrijk, lichter. Om iets preciezer te zijn 33% lichter.
Met vriendelijke groet, Henk.
Als het niet kan zoals het moet, dan moet het maar zoals het kan.
