Toon hier je (model)TRAM foto's. door Huibert
Vandaag om 05:06:58
Der Akkublitz , Taschenlampen-Express , Steckdosen-IC und so weiter door Reinout van Rees
Vandaag om 02:39:43
La vie...Sud-Est; zolderbaan met thema zuidoost Frankrijk door Rik
Vandaag om 01:43:05
Noord-Hollandse Modelspoor Dagen 2026 - 28 februari & 1 maart door KoploperMau
25 February 2026, 23:16:48
25 February 2026, 22:48:29
Botsing bij SGB 29-12-2025 door 1200blauw
25 February 2026, 22:25:40
25 February 2026, 22:24:31
25 February 2026, 21:19:17
Nieuw in de winkel! door maartenvdb
25 February 2026, 20:47:23
Raadplaatje door Charles_
25 February 2026, 20:21:10
25 February 2026, 19:57:09
RailBOX Electronics RB1110 DCC Centrale uit Polen door AlbertG
25 February 2026, 19:51:57
Miniatuurcamera die fatsoenlijke foto's maakt door VAM65
25 February 2026, 19:42:59
PB Models, ICR-rijtuigen door Marcel Kirkels
25 February 2026, 19:12:45
Gekke/vreemde/rare filmpjes en video's met treinen erin. door Joz
25 February 2026, 19:06:55
25 February 2026, 18:30:31
Rheinburg, TP V/VI door System-M
25 February 2026, 18:24:50
Zermitz door maartenvdb
25 February 2026, 18:14:41
Pattex Plastic lijm, isolerend of geleidend? door Klaas Zondervan
25 February 2026, 17:42:50
Toon hier je pas gereed gekomen (model-)spoorbouwsels ... door Casmir
25 February 2026, 17:09:16
25 February 2026, 17:07:41
25 February 2026, 16:54:55
25 February 2026, 16:36:09
BNS-Thailand: Spoorbouwen onder de tropenzon door Montanbahn
25 February 2026, 16:18:29
25 February 2026, 14:17:04
25 February 2026, 13:41:42
25 February 2026, 13:28:59
25 February 2026, 10:03:24
25 February 2026, 07:58:16
25 February 2026, 07:56:58
Auteur Topic: Ronald doet de Fork Challenge!  (gelezen 40382 keer)
  • Modelrailroading is fun!
    • Team USA Metusa Junction
Re: Ronald doet de Fork Challenge!
« Reactie #15 Gepost op: 10 July 2025, 22:46:50 »
Ja, zo is het. Wacht op de bakkies  ;D
« Reactie #16 Gepost op: 11 July 2025, 11:41:27 »
Ronald,
Maak je die niet zelf?
3 feet2 is toch niet moeilijk uit te rekenen?
Waarom bakkies....? (offside train storage?).
Ronald Visser
(2790 cm2)
« Reactie #17 Gepost op: 11 July 2025, 11:51:37 »
Normaal maak ik die inderdaad zelf, Ronald. Nu maken we er een project van om het te laseren. Omdat Ronald Koerts beperkt is in de zin dat hij max 60 x 4 cm kan laseren heb ik een ontwerp gemaakt van een systeem waarbij je meerdere bakdelen tot 1 bak kunt koppelen plus in variabele maten. Zo krijg je natuurlijk retestrakke bakken waar geen mm tolerantie in zit :) Dus doe ik het zo! ;)
Ik heb zelf een visie hoe zoiets eruit moet zien. Dat wijkt soms af van de vastgelegde paden en ik doorbreek dat graag met soms wat nieuws :) Wacht rustig af, de eerste test stond 2 uurtjes geleden op onze salontafel en die zag er al heel goed uit.
Later! Eerst werken vanmiddag.
  • Klaar voor vertrek!
« Reactie #18 Gepost op: 11 July 2025, 13:25:28 »
In de voorwaarden staat: “No sector plates or traversers on the visible section”.
Als ik het goed begrijp mag het zichtbare deel niet uit verschillende delen bestaan?
Wohnzimmer Rbf
« Reactie #19 Gepost op: 11 July 2025, 14:00:40 »
Sector plate is een sector deel draaischijf en traverser is een zijdelingse rijdende treinverplaatser.
Die beide heeft Ronald Halma niet in zijn ontwerp opgenomen.
Ronald Visser
« Laatst bewerkt op: 11 July 2025, 14:02:19 door MOVisser »
« Reactie #20 Gepost op: 11 July 2025, 15:16:09 »
Jullie hebben beide gelijk  ;D Alleen komt er wel een sector plate in het ontwerp. En die komt niet in het zicht. Ik zal zo proberen een schets te produceren waarbij duidelijk wordt wat ik ga doen. Ik wil uit praktische overweging alles in 1 bakje van 130 cm houden namelijk.
« Reactie #21 Gepost op: 11 July 2025, 15:19:47 »
Kijk:
20250707_084033 by Ronald Halma, on Flickr
Een sectorplate  ;)
« Reactie #22 Gepost op: 11 July 2025, 15:29:46 »
 (y) duidelijk, weer wat geleerd!
Wohnzimmer Rbf
« Reactie #23 Gepost op: 11 July 2025, 18:11:16 »
Nu ik deze challenge zo lees, beginnen mijn vingers ook te jeuken.
Of ik er tijd voor vrij kan maken kan ik eigenlijk pas eind sept half oktober beter vaststellen.
Dan heb ik nog 6 weken....
Ik blijf dit wel volgen.
Ronald Visser
« Reactie #24 Gepost op: 11 July 2025, 22:47:05 »
Mooi! :)
Vanmorgen kwam Ronald met de eerste proef aanzetten, de 40cm bak. Nog even met plakband aan elkaar maar gewoon draagbaar:
20250711_094609 by Ronald Halma, on Flickr
Al heel content mee! Betekent dat het geheel strak en netjes in elkaar zit! Samen nog wat dingetjes en ideeën gedeeld en besproken die nog aanpassing behoeven. Daarna gaan werken en vanmiddag /vanavond nog geregeld contact met elkaar gehad over die aanpassingen. De eerste 3 zijn proefklaar nu en komen morgen naar hier:
Screenshot_20250711_165908_WhatsApp by Ronald Halma, on Flickr
En de beloofde schets (hopelijk zien jullie wat ik bedoel  ;D ):
20250711_184420 by Ronald Halma, on Flickr
Een 40, een 50 en weer een 40 cm bakje. Maakt een module van 130 cm met 90 cm zichtbaar. Ze zijn koppelbaar zodat je 1 geheel krijgt wat aan elkaar gelijmd kan worden. De koppelstukjes lijnen direct uit zodat het geheel er als een strakke module uit zal gaan zien.
Stay tuned!
« Reactie #25 Gepost op: 12 July 2025, 08:38:41 »
Mooi man(nen)  (y) (y)
Vindt ik leuk die kleine modules.
Welke dikte plex heeft Ronald gebruikt ?
Am Ende der Strecke
Den gamla sågverket (gepland)
  • Het leven op de weg.
    • Midland
« Reactie #26 Gepost op: 12 July 2025, 11:09:12 »
Hoi, Ronald
Valt er zon module te regelen in de toekomst?
Miss wil ik Swalbenburg 2.0 mobiel maken.
(Zomaar een los idee)
Dat hoeft voor N geen brede bak te worden.
Gr. Koen.
Ronaldk
« Reactie #27 Gepost op: 12 July 2025, 11:28:20 »
9mm Peppelplex. Licht. Mogelijk wat zacht zullen mensen zeggen. Maar het is mooi hout om te gebruiken.
Zou geen probleem moeten zijn. Je moet rekening houden dat Peppelplex niet het goedkoopste hout is  :)
« Reactie #28 Gepost op: 12 July 2025, 11:33:29 »
9 mm. Het kan met 6 maar op mijn verzoek 9. Qua gewicht maakt het weinig uit en het is wat steviger zo.
Is wel de bedoeling om dat te doen, daar heb ik wel ideeën over. Moeten we alleen samen nog even uitwerken :) Ronald doet wel meer werk in opdracht dus ik voorzie daar geen problemen. Zelf denk ik dat er wel vraag naar dit soort bakken is, aan de andere kant heeft zo'n bakje wel een prijs. Hout is zeker niet goedkoop momenteel en ook de lasermachine draait niet voor nop. Maar blijf dit draadje volgen en over niet al te lange tijd hoop ik daar wat meer duidelijkheid in te hebben :)
De bakjes zijn vanmorgen afgeleverd! Rond koffietijd rook Koerts de koffie en stond hij voor de deur  ;D De handel stond te wachten in zijn auto:
dd396d93-cbca-4ed6-8caf-011b22bcfc32 by Ronald Halma, on Flickr
Snel naar binnen!:
20250712_093816 by Ronald Halma, on Flickr
Het systeem even samen doorgenomen, met name de verstevigingen. Die houden de bakjes straks mooi haaks:
20250712_104407 by Ronald Halma, on Flickr
Tis dat ik werken moet anders had het al bijna in elkaar gezeten! Later!
« Reactie #29 Gepost op: 12 July 2025, 12:02:54 »
Mooie opzet.
Ik denk dat de extra hoejes niet nodig zijn.
De bovenplaat, maar zeker de treinbaanplaat (zit er nog niet in/bij ?) geven de sterkte en stevigheid die je graag zou willen.
Ronald Visser
